[Mark Solved / Archieved] GPSDR++: no sound and unable to open the speaker on the screen
(@test27)
I got a new VU GPSDR unit and hooked it up to the Vivid, it plays but I have no sound and unable to open the speaker on the screen both knobs are inoperable no matter what I set them to. I have removed and re installed the vue and the gpsdrpp software. still not working.
Posted : 04/12/2025 7:43 am
(@test27)
Both encoders are not responding to any setting
Posted : 04/12/2025 8:06 am
(@test27)
You can also see in the pic that the demodulation choices are not displayed
Posted : 04/12/2025 8:33 am
It is possible that you turned on the ADS-B mode. You can turn it off in the "Mode S/ADSB" side page, by unchecking the "Mode S/ADS-B" checkbox, as shown in the attached screenshot.
If it is the case, your GPSDR++ is version 1.07 or older, because I can see the tuning frequency can be changed. In version 1.08, the tuning frequency will be locked to 1090MHz in ADS-B mode. You can run these commands to update it:
sudo apt update
sudo apt install gpsdrpp
Another possibility is that you accidently disabled the Radio module (in the SDR++ menu). You can fix it in the config.json file (after closing GPSDR++):
nano /home/vivid/.config/gpsdrpp/config.json
Alternatively, you can just delete it (after closing GPSDR++), so it will be re-created when you run GPSDR++ again:
rm /home/vivid/.config/gpsdrpp/config.json
Posted : 04/12/2025 8:36 am
(@test27)
Thank you so much for your help it's working great now
Posted : 04/12/2025 10:13 am
