[Mark Solved / Archieved] GPSDRPP - Network output and rigctl support
(@arodd)
I’m not positive if these can be enabled separately but it would be great to support the network output and rigctl options of SDRPP so that the signal from my vivid unit could be passed to another box for processing and analysis.  I’m imagining these are compilation flags that could be added during the GPSDRPP build to enable this functionality.
Posted : 11/11/2025 10:24 pm
The server part is included in GPSDR++, inherited from SDR++, but the client-side plugin isn’t included by default in GPSDR++.
If your "another box" will run SDR++ instead of GPSDR++, they should be able to connect and work.
It should also be possible to port the client-side plugin to GPSDR++.
We have not tested this,  and I am not sure if there is something need to be adjusted. You are welcome to share your finding after trying.
Posted : 12/11/2025 11:08 am
