Witty Pi 4 - running the schedule forever?
(@adam-p-hajduk)
Hi All,
Apologize if that concern has been resolved already, if that's the case, please point me to proper forum topics.
I would like to use Witty Pi schedule, where RPi wakes up each day after midnight, forever (so no constraint like maximum year 2038 etc). I understand that RTC controller has limitation to year 2099, but that would be ok.
What would be most witty-way to achieve it?
Posted : 13/01/2026 10:58 am
This is a typical scenario to use schedule script.
Please read page 16-21 in the user manual, if you have not done so yet.
The example below wake your Pi up at 1:30 AM everyday for 15 minutes.
BEGIN 2026-01-14 01:30:00
END 2037-07-31 23:59:59
ON M15
OFF H23 M45
You may use this web application to create schedule script and run simulation.
https://www.uugear.com/app/wittypi-scriptgen/
Posted : 13/01/2026 12:11 pm
(@adam-p-hajduk)
Hi @admin, thanks for your prompt response. As I mentioned I would like to run script like this one:
BEGIN 2026-01-01 00:15:00
END   2099-12-31 00:15:00
ON    S0 WAIT
OFF   S0
but I found some information that Witty firmware will either reject year 2099 or will fail silently after 2038?
So how to make sure the schedule runs fine till 2099?
Posted : 13/01/2026 12:58 pm
(@adam-p-hajduk)
After consulting different AI models it looks like the end date 2099 should not be a problem.
Can someone please verify if that script for Witty Pi 4 would work as expected?
BEGIN 2026-01-01 02:00:00
END   2099-12-31 23:59:59
ON    H24 WAIT
The goal is to boot RPi at 2am every day, the os-level script executed after the boot will do its job, and will shutdown RPi programmatically by itself.
Posted : 23/01/2026 3:04 pm
