[Mark Solved / Archieved] Witty Pi4 - Scheduler not executed from time to time - no shutdown
(@robert-krueger)
I have a problem with a Witty Pi4 setup (Pi Zero W, configured to run 3min every 15min) , which doesn't shut down sometimes.
From the log i identified the scheduler to be the problem, as it is not executed in such cases.
Any ideas?
--------------- 2025-08-28 10:00:57 ---------------
Schedule next shutdown at: 2025-08-28 10:03:00
Schedule next startup at: 2025-08-28 10:15:00
--------------- 2025-08-28 10:15:57 ---------------
Schedule next shutdown at: 2025-08-28 10:18:00
Schedule next startup at: 2025-08-28 10:30:00
--------------- 2025-08-28 10:30:58 ---------------
Schedule next shutdown at: 2025-08-28 10:33:00
Schedule next startup at: 2025-08-28 10:45:00
--------------- 2025-08-28 10:46:01 ---------------
Schedule next shutdown at: 2025-08-28 10:48:00
Schedule next startup at: 2025-08-28 11:00:00
--------------- 2025-08-28 11:01:01 ---------------
Posted : 28/08/2025 12:59 pm
You need to look into the wittyPi.log file. The log you provided is from the schedule.log file, which only tells what happened/not happened, but does not give any hint about why.
Posted : 28/08/2025 2:15 pm
(@robert-krueger)
The content of the logfile is posted below. It contains the log from the last succesful run and the last, where the pi won't shut down due to the not updated alarms.
For me it gives no real hint why the Scheduler is not run.
[xxxx-xx-xx xx:xx:xx] System: Raspbian GNU/Linux 11 (bullseye), Kernel: Linux 6.1.21+, Architecture: armhf
[xxxx-xx-xx xx:xx:xx] Witty Pi is not detected, retry in one second...
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x79
[2025-08-28 10:45:46] Done 🙂
[2025-08-28 10:45:46] Firmware ID: 0x26
[2025-08-28 10:45:46] Firmware Revison: 0x06
[2025-08-28 10:45:46] Current Vout=4.1V, Iout=0.17A
[2025-08-28 10:45:46] System starts up because scheduled startup is due.
[2025-08-28 10:45:52] Send out the SYS_UP signal via GPIO-17 pin.
[2025-08-28 10:45:53] Pending for incoming shutdown command...
[2025-08-28 10:46:12] Schedule next shutdown at: 2025-08-28 10:48:00
[2025-08-28 10:46:13] Schedule next startup at: 2025-08-28 11:00:00
[2025-08-28 10:45:59] TIME-LAPSE LOW-COST SYSTEM
[2025-08-28 10:46:01] USB Drive mounted
now: 10:46:02 +04
Sunrise: 05:52:46 +04
Sunset: 18:33:49 +04
capturing image/videos
[2025-08-28 10:46:03] Camera V2 detected. Resolution: 3280x2464
[2025-08-28 10:46:05] Image: 20250828_1046_1 successfully captured
[2025-08-28 10:46:15] Video: 20250828_1046_ successfully captured
[2025-08-28 10:46:16] WittyPi log files copied to USB
[2025-08-28 10:47:55] Shutting down system because scheduled shutdown is due.
[2025-08-28 10:47:56] Halting all processes and then shutdown Raspberry Pi...
[2025-08-28 11:00:46] Done 🙂
[2025-08-28 11:00:46] Firmware ID: 0x26
[2025-08-28 11:00:46] Firmware Revison: 0x06
[2025-08-28 11:00:46] Current Vout=4.36V, Iout=0.17A
[2025-08-28 11:00:46] System starts up because scheduled startup is due.
[2025-08-28 11:00:52] Send out the SYS_UP signal via GPIO-17 pin.
[2025-08-28 11:00:53] Pending for incoming shutdown command...
[2025-08-28 11:01:00] TIME-LAPSE LOW-COST SYSTEM
[2025-08-28 11:01:01] USB Drive mounted
now: 11:01:02 +04
[2025-08-28 11:01:03] Camera V2 detected. Resolution: 3280x2464
[2025-08-28 11:01:05] Image: 20250828_1101_1 successfully captured
[2025-08-28 11:01:16] Video: 20250828_1101_ successfully captured
[2025-08-28 11:01:16] WittyPi log files copied to USB
Posted : 01/09/2025 9:57 am
The runScript.sh should be run after the "Pending for incoming shutdown command..." line got printed in the log, which will schedule the next shutdown and startup.
However this didn't happen after this line:
Indeed there was no more information about why. However you may modify the runScript.sh and let it output more verbose log. For now we can not confirm if this script was executed.
Posted : 01/09/2025 3:37 pm
