[Mark Solved / Archieved] WittyPi4 L3V7 - pi zero 2w fails to fully shutdown
(@jannsta)
Hardware: WittyPi4 L3V7 <-> pi zero 2w
power supply: reliable usb-c power supply (no battery atm)
schedule: on_5m_every_20m.wpi
The issue I'm having is that after around 24 hours, the pi appears to not (fully) shutdown and the schedule seems to cancel.
In this state, the red LED on the witty is on constantly and the green LED on the pi is also on but the pi is no longer reachable via SSH.
The button on the witty doesn't produce any action, I have to unplug the witty unit from the mains to recover.
I would like to get to a state where I can run the routine for several weeks without this happening, is that a realistic goal?
Any tips on things that I could try to identify why the pi isn't fully shutting down? (as far as I can see, the header connections are all good.). I guess my next step would be to try hooking it up to a monitor next time its in this state.
I'm including the last 2 entries in wittyPi.log below (the shutdown at 12:05 did not complete):
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 13 (trixie), Kernel: Linux 6.12.62+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] Witty Pi is not detected, retry in one second...
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x77
[2026-03-03 11:40:27] Done :-)
[2026-03-03 11:40:27] Firmware ID: 0x37
[2026-03-03 11:40:27] Firmware Revison: 0x07
[2026-03-03 11:40:27] Current Vout=5.21V, Iout=0.17A
[2026-03-03 11:40:27] System starts up because scheduled startup is due.
[2026-03-03 11:40:32] Schedule next shutdown at: 2026-03-03 11:45:00
[2026-03-03 11:40:33] Schedule next startup at: 2026-03-03 12:00:00
[0:00:30.849001029] [1104]  INFO Camera camera_manager.cpp:340 libcamera v0.6.0+rpt20251202
[0:00:30.941143685] [1422]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/vc4/imx477.json
[0:00:30.961356237] [1422]  INFO Camera camera_manager.cpp:223 Adding camera '/base/soc/i2c0mux/i2c@1/imx477@1a' for pipeline handler rpi/vc4
[0:00:30.961485091] [1422]  INFO RPI vc4.cpp:445 Registered camera /base/soc/i2c0mux/i2c@1/imx477@1a to Unicam device /dev/media3 and ISP device /dev/media0
[0:00:30.961551289] [1422]  INFO RPI pipeline_base.cpp:1111 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:00:30.983413789] [1104]  INFO Camera camera.cpp:1215 configuring streams: (0) 1920x1080-BGR888/sRGB (1) 640x480-YUV420/sYCC (2) 2028x1080-SBGGR12_CSI2P/RAW
[0:00:30.984199414] [1422]  INFO RPI vc4.cpp:620 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected sensor format: 2028x1080-SBGGR12_1X12/RAW - Selected unicam format: 2028x1080-pBCC/RAW
[2026-03-03 11:40:50] Send out the SYS_UP signal via GPIO-17 pin.
[2026-03-03 11:40:51] Pending for incoming shutdown command...
[2026-03-03 11:44:59] Shutting down system because scheduled shutdown is due.
[2026-03-03 11:44:59] Halting all processes and then shutdown Raspberry Pi...
[2026-03-03 12:00:27] Done :-)
[2026-03-03 12:00:27] Firmware ID: 0x37
[2026-03-03 12:00:27] Firmware Revison: 0x07
[2026-03-03 12:00:27] Current Vout=5.22V, Iout=0.1A
[2026-03-03 12:00:27] System starts up because scheduled startup is due.
[2026-03-03 12:00:33] Schedule next shutdown at: 2026-03-03 12:05:00
[2026-03-03 12:00:33] Schedule next startup at: 2026-03-03 12:20:00
[0:00:30.099797123] [1104]  INFO Camera camera_manager.cpp:340 libcamera v0.6.0+rpt20251202
[0:00:30.197503217] [1424]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/vc4/imx477.json
[0:00:30.216501446] [1424]  INFO Camera camera_manager.cpp:223 Adding camera '/base/soc/i2c0mux/i2c@1/imx477@1a' for pipeline handler rpi/vc4
[0:00:30.216629779] [1424]  INFO RPI vc4.cpp:445 Registered camera /base/soc/i2c0mux/i2c@1/imx477@1a to Unicam device /dev/media3 and ISP device /dev/media0
[0:00:30.216696706] [1424]  INFO RPI pipeline_base.cpp:1111 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:00:30.238443842] [1104]  INFO Camera camera.cpp:1215 configuring streams: (0) 1920x1080-BGR888/sRGB (1) 640x480-YUV420/sYCC (2) 2028x1080-SBGGR12_CSI2P/RAW
[0:00:30.239219727] [1424]  INFO RPI vc4.cpp:620 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected sensor format: 2028x1080-SBGGR12_1X12/RAW - Selected unicam format: 2028x1080-pBCC/RAW
[2026-03-03 12:00:44] Send out the SYS_UP signal via GPIO-17 pin.
[2026-03-03 12:00:44] Pending for incoming shutdown command...
[2026-03-03 12:04:58] Shutting down system because scheduled shutdown is due.
[2026-03-03 12:04:59] Halting all processes and then shutdown Raspberry Pi...
Posted : 05/03/2026 2:02 pm
It is likely that your Raspberry Pi crashed during the shutdown, and its TXD pin was stuck at HIGH state. Witty Pi checks the TXD pin voltage to know if your Pi is really off.
Posted : 05/03/2026 3:31 pm
(@jannsta)
so has the wittypi been tested to work over long periods without hitting these kind of problems?
What I found is that when I don't run my python script from "afterStartup.sh" the setup seems to run longer without crashing (went for 3 days before I stopped it). On this basis I've been trying some mitigations by adding a backup mechanism to ensure the python process has completed before the shutdown command is sent - e.g. in afterstartup.py I run `shutdown 180 python3 myscript.py` instead if just `python3 myscript.py` - unfortunately I get in the same stuck state as before though. The python script is opening the camera and taking an image so perhaps the difference could be something more hardware related?
Is there a possibilty of triggering a poweroff from the wittyPi when the raspi crashes during shutdown? I know this isn't ideal but I would prefer to take the risk rather than ending up in the hung state.
Posted : 13/03/2026 9:15 pm
@jannsta we have tested Witty Pi for weeks without any problem. However, given the fact that our testing eniroment may be different than yours, it doesn't mean you will not met any problem. It is important to find the root cause of the problem and solve it.
The user has the biggest chance to find the root cause, while we can only see the log content, and a lot of information has been lost there.
Posted : 16/03/2026 12:31 pm
