ZERO4U usb ports droping out
(@thuffaker)
I am seeing Zero4U USB ports dropping out on my Raspberry Pi 2 Zero.  They are working, then drop out and come back in a few seconds. This keeps the GPS on USB from working and also the CM108 audio chip to stop and restart.  I am using this for APRS, and I am wondering whether the Raspberry Pi's power supply does not provide enough current.  if not how do I power the board, and can it power the Raspberry Pi 2 zero?
Posted : 30/01/2026 2:33 am
Does your Raspberry Pi 2 Zero have WiFi ability?
It seems the USB stack gets reset due to interference. Have you installed the ferrite ring and metallised PET membrane included in the package?
Posted : 30/01/2026 10:53 am
(@thuffaker)
@admin Yes I am running wifi to control the raspberry pi 2 zero w.  This is running digirig software. I have the ferrite installed as shown in the manual.  I do not have the membrane installed and I will look for it. I can see what the ferrite does but not the membrane.  I do think the USB stack is being interrupted and I thought it was power but maybe not.
Posted : 30/01/2026 1:30 pm
(@thuffaker)
I found the membrane, and I assume it goes on the Zero4U board?  I will test and see if this resolves the issue.  Note, this is an outdoor application, and it could be >95 dec F the day it has to work.
Posted : 30/01/2026 3:06 pm
(@thuffaker)
Adding the membrane fixed it and thank you for letting me know.
Tim
Posted : 01/02/2026 8:39 pm
