I have 3 vivid unit. When I boot them up, 2 of them has the same MAC address, and the third has another one. Do anyone know why this could've happen.
Posted : 12/05/2025 3:20 pm
After flashing the system, the Linux kernel will generate the MAC address during the first boot. It seems the kernel may give the same MAC for different devices.
It is possible to write the new MAC address into RK Vendor Storage (a special region on the eMMC).
You may create such a BASH script, and run it to generate a MAC address from the eMMC chip serial number, which should be unique:
#!/bin/bash
ROOT_PART_DEV=$(findmnt / -o source -n)
echo "ROOT_PART_DEV=${ROOT_PART_DEV}"
ROOT_PART_NAME=$(echo "$ROOT_PART_DEV"| cut -d "/" -f 3)
echo "ROOT_PART_NAME=${ROOT_PART_NAME}"
ROOT_DEV_NAME=$(echo /sys/block/*/"${ROOT_PART_NAME}" | cut -d "/" -f 4)
echo "ROOT_DEV_NAME=${ROOT_DEV_NAME}"
ROOT_DEV="/dev/${ROOT_DEV_NAME}"
echo "ROOT_DEV=${ROOT_DEV}"
ROOT_PART_NUM=$(cat "/sys/block/${ROOT_DEV_NAME}/${ROOT_PART_NAME}/partition")
echo "ROOT_PART_NUM=${ROOT_PART_NUM}"
MACH="face"
EMMCSERIAL=$(cat /sys/class/block/${ROOT_DEV_NAME}/device/serial)
MACL=${EMMCSERIAL#0x}
MAC=${MACH}${MACL}
echo "MAC=${MAC}"
sudo /usr/bin/vendor_storage -w VENDOR_LAN_MAC_ID -t string -i $MAC
You will need to reboot your device to see the new MAC address.
Posted : 13/05/2025 8:13 am
Thank you so much! Worked perfectly.
Posted : 13/05/2025 1:12 pm
