L3V7 with Li-Ion install outdoor also in Winter
(@nokellner)
a general question:
Li-ion batteries must not be charged at sub-zero temperatures. The TP4056 has a temperature input on PIN 1 to control the charging current. Is this input available on the L3V7?
Posted : 24/11/2026 12:29 pm
On Witty Pi 4 L3V7, the TEMP pin of the TP4056 is connected to GND, which disables its battery temperature sensing.
The board does not monitor the battery temperature, so charging will not be suspended at low temperatures. If your application requires low-temperature charge protection, it needs to be provided by the battery pack or elsewhere in your system.
Posted : 24/11/2026 1:52 pm
(@nokellner)
ok thx for fast reply. i'm planning futhermore MINI 4 with the adafruit AF4755 charger.
Posted : 24/11/2026 6:04 pm
