Hello , I recently bought a Witty Pi 4 L3V7 , I use it with a RPIe zero 2W I installed it , but each time i try to start the pie by pushing the button , it starts up but shutdown in 10 sec , I have no time to understand or to launch any command
Posted : 06/10/2025 10:54 pm
OK I found the problem , I had to disable 1 Wire
Posted : 07/10/2025 9:10 am
@zanzeoo 1-wire by default uses GPIO-4, which is also used by Witty Pi 4 (all models).
If you still need 1-wire, you may assign a different GPIO to 1-wire.
Posted : 08/10/2025 12:06 pm
