Witty Pi 4 vs EDT/EST
(@blakebr)
Is there a fix in the works for the firmware / software to fix the handover between standard time and saving time, e.g. USA Eastern Time Zone?
My WP4 turned off and stopped at 2:00 AM at the time of the switch back to standard time.  I had to push the button to turn on the RPi and then run sync time two or three times to get the times synched.  I also had to reselect the Schedule Script to get it to reflect local time not DST.  Log attached.
Bruce
[xxxx-xx-xx xx:xx:xx] Witty Pi daemon (v4.23) is started.
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 13 (trixie), Kernel: Linux 6.18.59-v8+, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x77
[2026-11-01 01:40:29] Done :-)
[2026-11-01 01:40:29] Firmware ID: 0x36
[2026-11-01 01:40:29] Firmware Revison: 0x07
[2026-11-01 01:40:29] Current Vout=5.08V, Iout=0.25A
[2026-11-01 01:40:29] System starts up because scheduled startup is due.
[2026-11-01 01:40:34] Send out the SYS_UP signal via GPIO-17 pin.
[2026-11-01 01:40:34] Pending for incoming shutdown command...
[2026-11-01 01:40:34] Schedule next shutdown at: 2026-11-01 01:55:00
[2026-11-01 01:40:35] Schedule next startup at: 2026-11-01 01:00:00
[2026-11-01 01:55:01] Shutting down system because scheduled shutdown is due.
[2026-11-01 01:55:01] Halting all processes and then shutdown Raspberry Pi...
[2026-11-01 11:46:22] Done :-)
[2026-11-01 11:46:22] Firmware ID: 0x36
[2026-11-01 11:46:22] Firmware Revison: 0x07
[2026-11-01 11:46:22] Current Vout=5.08V, Iout=0.34A
[2026-11-01 11:46:22] System starts up because the button is clicked.
[2026-11-01 11:46:27] Send out the SYS_UP signal via GPIO-17 pin.
[2026-11-01 11:46:27] Pending for incoming shutdown command...
[2026-11-01 11:46:27] Schedule next shutdown at: 2026-11-01 11:55:00
[2026-11-01 11:46:28] Schedule next startup at: 2026-11-01 12:00:00
[2026-11-01 10:50:31] Internet detected, apply network time to system and Witty Pi...
[2026-11-01 10:50:31] Applying network time to system...
[2026-11-01 10:50:31] Done :-)
[2026-11-01 10:50:31] Writing system time to RTC...
<2026-11-01 10:50:31> Done :-)
<2026-11-01 10:51:18> Copying "on_15m_every_20m.wpi" to "schedule.wpi"...
<2026-11-01 10:51:18> Running the script...
<2026-11-01 10:51:19> Schedule next shutdown at: 2026-11-01 10:55:00
<2026-11-01 10:51:19> Schedule next startup at: 2026-11-01 11:00:00
<2026-11-01 10:51:19> Done :-)
[2026-11-01 10:54:59] Shutting down system because scheduled shutdown is due.
[2026-11-01 10:54:59] Halting all processes and then shutdown Raspberry Pi...
[2026-11-01 11:00:29] Done :-)
[2026-11-01 11:00:29] Firmware ID: 0x36
[2026-11-01 11:00:29] Firmware Revison: 0x07
[2026-11-01 11:00:29] Current Vout=5.09V, Iout=0.27A
[2026-11-01 11:00:29] System starts up because scheduled startup is due.
[2026-11-01 11:00:34] Send out the SYS_UP signal via GPIO-17 pin.
[2026-11-01 11:00:34] Pending for incoming shutdown command...
[2026-11-01 11:00:34] Schedule next shutdown at: 2026-11-01 11:15:00
[2026-11-01 11:00:35] Schedule next startup at: 2026-11-01 11:20:00
pi@RPi-Zero-W-72:~/wittypi $
Posted : 01/11/2026 5:08 pm
The behavior shown in your log is consistent with the known DST limitation of Witty Pi 4.
At 01:40, the software scheduled the next shutdown for 01:55 and the next startup for 01:00. The latter was intended to occur after the EDT-to-EST transition. However, Witty Pi 4 does not automatically adjust its RTC for DST, so the scheduled startup was missed.
We have explained this limitation in an earlier forum topic:
https://www.uugear.com/forums/technial-support-discussion/witty-pi-4-about-daylight-saving-time-dst/
Implementing reliable DST handling across different regions, especially when the Raspberry Pi may be powered off during the transition, would require substantial changes and testing.
We do not have a plan to implement automatic DST handling for Witty Pi 4.
Posted : 02/11/2026 8:36 am
(@blakebr)
Thank you for your reply and information.  I may try auto DST update.  My bash skills are limited.
Bruce
This post was modified 1 week ago by blakebr
Posted : 02/11/2026 9:04 pm
