[Mark Solved / Archieved] Witty Pi L3V7 won't wake up
(@konstantinos-belivanis)
Hello all.
Although it was working well and on schedule after I switched the schedule on my assembly Witty Pi L3V7 won't wake up my pi.
The device is on a full battery bank and powered by a USB-C, as before. Any idea what could be going on?
[2025-05-25 19:07:26] Set to "Default ON"!
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-05-25 19:08:36] Done :-)
[2025-05-25 19:08:36] Firmware ID: 0x37
[2025-05-25 19:08:36] Firmware Revison: 0x07
[2025-05-25 19:08:36] Current Vout=5.2V, Iout=0.43A
[2025-05-25 19:08:36] System starts up because it previously reboot.
[2025-05-25 19:08:41] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-25 19:08:41] File "schedule.wpi" not found, skip running schedule script.
[2025-05-25 19:08:41] Pending for incoming shutdown command...
[2025-05-25 19:23:22] Writing system time to RTC...
<2025-05-25 19:23:22> Done :-)
<2025-05-25 19:23:26> Writing system time to RTC...
<2025-05-25 19:23:26> Done :-)
<2025-05-25 19:23:44> Copying "test_schedule.wpi" to "schedule.wpi"...
<2025-05-25 19:23:44> Running the script...
<2025-05-25 19:23:45> Schedule next shutdown at: 2025-05-25 19:40:00
<2025-05-25 19:23:45> Schedule next startup at: 2025-05-25 19:45:00
<2025-05-25 19:23:45> Done :-)
[2025-05-25 19:40:00] Shutting down system because scheduled shutdown is due.
[2025-05-25 19:40:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-25 19:45:17] Done :-)
[2025-05-25 19:45:17] Firmware ID: 0x37
[2025-05-25 19:45:17] Firmware Revison: 0x07
[2025-05-25 19:45:17] Current Vout=5.18V, Iout=0.38A
[2025-05-25 19:45:17] System starts up because power supply is newly connected.
[2025-05-25 19:45:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-25 19:45:22] Pending for incoming shutdown command...
[2025-05-25 19:45:22] Schedule next shutdown at: 2025-05-25 20:00:00
[2025-05-25 19:45:23] Schedule next startup at: 2025-05-25 20:05:00
[2025-05-25 19:59:59] Shutting down system because scheduled shutdown is due.
[2025-05-25 19:59:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-25 20:05:17] Done :-)
[2025-05-25 20:05:17] Firmware ID: 0x37
[2025-05-25 20:05:17] Firmware Revison: 0x07
[2025-05-25 20:05:17] Current Vout=5.19V, Iout=0.58A
[2025-05-25 20:05:17] System starts up because power supply is newly connected.
[2025-05-25 20:05:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-25 20:05:22] Pending for incoming shutdown command...
[2025-05-25 20:05:22] Schedule next shutdown at: 2025-05-25 20:20:00
[2025-05-25 20:05:23] Schedule next startup at: 2025-05-25 20:25:00
[2025-05-25 20:19:28] Copying "AttalosTrapSchedule.wpi" to "schedule.wpi"...
[2025-05-25 20:19:28] Running the script...
[2025-05-25 20:19:29] Schedule next shutdown at: 2025-05-25 21:15:00
[2025-05-25 20:19:29] Schedule next startup at: 2025-05-25 23:00:00
[2025-05-25 20:19:29] Done :-)
[2025-05-25 21:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-25 21:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-25 23:00:17] Done :-)
[2025-05-25 23:00:17] Firmware ID: 0x37
[2025-05-25 23:00:17] Firmware Revison: 0x07
[2025-05-25 23:00:17] Current Vout=5.19V, Iout=0.47A
[2025-05-25 23:00:17] System starts up because power supply is newly connected.
[2025-05-25 23:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-25 23:00:22] Pending for incoming shutdown command...
[2025-05-25 23:00:22] Schedule next shutdown at: 2025-05-25 23:15:00
[2025-05-25 23:00:23] Schedule next startup at: 2025-05-26 01:00:00
[2025-05-25 23:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-25 23:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 01:00:17] Done :-)
[2025-05-26 01:00:17] Firmware ID: 0x37
[2025-05-26 01:00:17] Firmware Revison: 0x07
[2025-05-26 01:00:17] Current Vout=5.2V, Iout=0.6A
[2025-05-26 01:00:17] System starts up because power supply is newly connected.
[2025-05-26 01:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 01:00:22] Pending for incoming shutdown command...
[2025-05-26 01:00:23] Schedule next shutdown at: 2025-05-26 01:15:00
[2025-05-26 01:00:23] Schedule next startup at: 2025-05-26 03:00:00
[2025-05-26 01:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 01:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 03:00:17] Done :-)
[2025-05-26 03:00:17] Firmware ID: 0x37
[2025-05-26 03:00:17] Firmware Revison: 0x07
[2025-05-26 03:00:17] Current Vout=5.2V, Iout=0.6A
[2025-05-26 03:00:17] System starts up because power supply is newly connected.
[2025-05-26 03:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 03:00:22] Pending for incoming shutdown command...
[2025-05-26 03:00:23] Schedule next shutdown at: 2025-05-26 03:15:00
[2025-05-26 03:00:23] Schedule next startup at: 2025-05-26 05:00:00
[2025-05-26 03:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 03:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 05:00:17] Done :-)
[2025-05-26 05:00:17] Firmware ID: 0x37
[2025-05-26 05:00:17] Firmware Revison: 0x07
[2025-05-26 05:00:17] Current Vout=5.19V, Iout=0.58A
[2025-05-26 05:00:17] System starts up because power supply is newly connected.
[2025-05-26 05:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 05:00:22] Pending for incoming shutdown command...
[2025-05-26 05:00:22] Schedule next shutdown at: 2025-05-26 05:15:00
[2025-05-26 05:00:23] Schedule next startup at: 2025-05-26 07:00:00
[2025-05-26 05:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-26 05:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 07:00:17] Done :-)
[2025-05-26 07:00:17] Firmware ID: 0x37
[2025-05-26 07:00:17] Firmware Revison: 0x07
[2025-05-26 07:00:17] Current Vout=5.2V, Iout=0.49A
[2025-05-26 07:00:17] System starts up because power supply is newly connected.
[2025-05-26 07:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 07:00:22] Pending for incoming shutdown command...
[2025-05-26 07:00:22] Schedule next shutdown at: 2025-05-26 07:15:00
[2025-05-26 07:00:23] Schedule next startup at: 2025-05-26 09:00:00
[2025-05-26 07:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 07:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 09:00:18] Done :-)
[2025-05-26 09:00:18] Firmware ID: 0x37
[2025-05-26 09:00:18] Firmware Revison: 0x07
[2025-05-26 09:00:18] Current Vout=5.2V, Iout=0.43A
[2025-05-26 09:00:18] System starts up because power supply is newly connected.
[2025-05-26 09:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 09:00:23] Pending for incoming shutdown command...
[2025-05-26 09:00:24] Schedule next shutdown at: 2025-05-26 09:15:00
[2025-05-26 09:00:24] Schedule next startup at: 2025-05-26 11:00:00
[2025-05-26 09:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-26 09:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 11:00:17] Done :-)
[2025-05-26 11:00:17] Firmware ID: 0x37
[2025-05-26 11:00:17] Firmware Revison: 0x07
[2025-05-26 11:00:17] Current Vout=5.19V, Iout=0.12A
[2025-05-26 11:00:17] System starts up because power supply is newly connected.
[2025-05-26 11:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 11:00:22] Pending for incoming shutdown command...
[2025-05-26 11:00:22] Schedule next shutdown at: 2025-05-26 11:15:00
[2025-05-26 11:00:23] Schedule next startup at: 2025-05-26 13:00:00
[2025-05-26 11:14:57] Shutting down system because scheduled shutdown is due.
[2025-05-26 11:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 13:00:17] Done :-)
[2025-05-26 13:00:17] Firmware ID: 0x37
[2025-05-26 13:00:17] Firmware Revison: 0x07
[2025-05-26 13:00:17] Current Vout=5.2V, Iout=0.4A
[2025-05-26 13:00:17] System starts up because power supply is newly connected.
[2025-05-26 13:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 13:00:22] Pending for incoming shutdown command...
[2025-05-26 13:00:22] Schedule next shutdown at: 2025-05-26 13:15:00
[2025-05-26 13:00:23] Schedule next startup at: 2025-05-26 15:00:00
[2025-05-26 15:00:17] Done :-)
[2025-05-26 15:00:17] Firmware ID: 0x37
[2025-05-26 15:00:17] Firmware Revison: 0x07
[2025-05-26 15:00:17] Current Vout=5.21V, Iout=0.49A
[2025-05-26 15:00:17] System starts up because power supply is newly connected.
[2025-05-26 15:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 15:00:22] Pending for incoming shutdown command...
[2025-05-26 15:00:22] Schedule next shutdown at: 2025-05-26 15:15:00
[2025-05-26 15:00:23] Schedule next startup at: 2025-05-26 17:00:00
[2025-05-26 15:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 15:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 17:00:18] Done :-)
[2025-05-26 17:00:18] Firmware ID: 0x37
[2025-05-26 17:00:18] Firmware Revison: 0x07
[2025-05-26 17:00:18] Current Vout=5.26V, Iout=0.53A
[2025-05-26 17:00:18] System starts up because power supply is newly connected.
[2025-05-26 17:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 17:00:23] Pending for incoming shutdown command...
[2025-05-26 17:00:23] Schedule next shutdown at: 2025-05-26 17:15:00
[2025-05-26 17:00:24] Schedule next startup at: 2025-05-26 19:00:00
[2025-05-26 17:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-26 17:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 19:00:17] Done :-)
[2025-05-26 19:00:17] Firmware ID: 0x37
[2025-05-26 19:00:17] Firmware Revison: 0x07
[2025-05-26 19:00:17] Current Vout=5.13V, Iout=0.38A
[2025-05-26 19:00:17] System starts up because power supply is newly connected.
[2025-05-26 19:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 19:00:22] Pending for incoming shutdown command...
[2025-05-26 19:00:22] Schedule next shutdown at: 2025-05-26 19:15:00
[2025-05-26 19:00:23] Schedule next startup at: 2025-05-26 21:00:00
[2025-05-26 19:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 19:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 21:00:17] Done :-)
[2025-05-26 21:00:17] Firmware ID: 0x37
[2025-05-26 21:00:17] Firmware Revison: 0x07
[2025-05-26 21:00:17] Current Vout=5.32V, Iout=0.45A
[2025-05-26 21:00:17] System starts up because power supply is newly connected.
[2025-05-26 21:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 21:00:22] Pending for incoming shutdown command...
[2025-05-26 21:00:23] Schedule next shutdown at: 2025-05-26 21:15:00
[2025-05-26 21:00:23] Schedule next startup at: 2025-05-26 23:00:00
[2025-05-26 21:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 21:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-26 23:00:17] Done :-)
[2025-05-26 23:00:17] Firmware ID: 0x37
[2025-05-26 23:00:17] Firmware Revison: 0x07
[2025-05-26 23:00:17] Current Vout=5.19V, Iout=0.55A
[2025-05-26 23:00:17] System starts up because power supply is newly connected.
[2025-05-26 23:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-26 23:00:22] Pending for incoming shutdown command...
[2025-05-26 23:00:23] Schedule next shutdown at: 2025-05-26 23:15:00
[2025-05-26 23:00:23] Schedule next startup at: 2025-05-27 01:00:00
[2025-05-26 23:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-26 23:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 01:00:17] Done :-)
[2025-05-27 01:00:17] Firmware ID: 0x37
[2025-05-27 01:00:17] Firmware Revison: 0x07
[2025-05-27 01:00:17] Current Vout=5.2V, Iout=0.58A
[2025-05-27 01:00:17] System starts up because power supply is newly connected.
[2025-05-27 01:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 01:00:22] Pending for incoming shutdown command...
[2025-05-27 01:00:22] Schedule next shutdown at: 2025-05-27 01:15:00
[2025-05-27 01:00:23] Schedule next startup at: 2025-05-27 03:00:00
[2025-05-27 01:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 01:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 03:00:17] Done :-)
[2025-05-27 03:00:17] Firmware ID: 0x37
[2025-05-27 03:00:17] Firmware Revison: 0x07
[2025-05-27 03:00:17] Current Vout=5.2V, Iout=0.58A
[2025-05-27 03:00:17] System starts up because power supply is newly connected.
[2025-05-27 03:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 03:00:22] Pending for incoming shutdown command...
[2025-05-27 03:00:22] Schedule next shutdown at: 2025-05-27 03:15:00
[2025-05-27 03:00:23] Schedule next startup at: 2025-05-27 05:00:00
[2025-05-27 03:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 03:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 05:00:17] Done :-)
[2025-05-27 05:00:17] Firmware ID: 0x37
[2025-05-27 05:00:17] Firmware Revison: 0x07
[2025-05-27 05:00:17] Current Vout=5.26V, Iout=0.21A
[2025-05-27 05:00:17] System starts up because power supply is newly connected.
[2025-05-27 05:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 05:00:22] Pending for incoming shutdown command...
[2025-05-27 05:00:22] Schedule next shutdown at: 2025-05-27 05:15:00
[2025-05-27 05:00:23] Schedule next startup at: 2025-05-27 07:00:00
[2025-05-27 05:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 05:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 07:00:17] Done :-)
[2025-05-27 07:00:17] Firmware ID: 0x37
[2025-05-27 07:00:17] Firmware Revison: 0x07
[2025-05-27 07:00:17] Current Vout=5.26V, Iout=0.38A
[2025-05-27 07:00:17] System starts up because power supply is newly connected.
[2025-05-27 07:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 07:00:22] Pending for incoming shutdown command...
[2025-05-27 07:00:22] Schedule next shutdown at: 2025-05-27 07:15:00
[2025-05-27 07:00:23] Schedule next startup at: 2025-05-27 09:00:00
[2025-05-27 07:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 07:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 09:00:17] Done :-)
[2025-05-27 09:00:17] Firmware ID: 0x37
[2025-05-27 09:00:17] Firmware Revison: 0x07
[2025-05-27 09:00:17] Current Vout=5.19V, Iout=0.43A
[2025-05-27 09:00:17] System starts up because power supply is newly connected.
[2025-05-27 09:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 09:00:22] Pending for incoming shutdown command...
[2025-05-27 09:00:22] Schedule next shutdown at: 2025-05-27 09:15:00
[2025-05-27 09:00:23] Schedule next startup at: 2025-05-27 11:00:00
[2025-05-27 09:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 09:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 11:00:17] Done :-)
[2025-05-27 11:00:17] Firmware ID: 0x37
[2025-05-27 11:00:17] Firmware Revison: 0x07
[2025-05-27 11:00:17] Current Vout=5.19V, Iout=0.58A
[2025-05-27 11:00:17] System starts up because power supply is newly connected.
[2025-05-27 11:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 11:00:22] Pending for incoming shutdown command...
[2025-05-27 11:00:23] Schedule next shutdown at: 2025-05-27 11:15:00
[2025-05-27 11:00:23] Schedule next startup at: 2025-05-27 13:00:00
[2025-05-27 11:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 11:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 13:00:17] Done :-)
[2025-05-27 13:00:17] Firmware ID: 0x37
[2025-05-27 13:00:17] Firmware Revison: 0x07
[2025-05-27 13:00:17] Current Vout=5.2V, Iout=0.62A
[2025-05-27 13:00:17] System starts up because power supply is newly connected.
[2025-05-27 13:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 13:00:22] Pending for incoming shutdown command...
[2025-05-27 13:00:23] Schedule next shutdown at: 2025-05-27 13:15:00
[2025-05-27 13:00:23] Schedule next startup at: 2025-05-27 15:00:00
[2025-05-27 15:00:18] Done :-)
[2025-05-27 15:00:18] Firmware ID: 0x37
[2025-05-27 15:00:18] Firmware Revison: 0x07
[2025-05-27 15:00:18] Current Vout=5.19V, Iout=0.55A
[2025-05-27 15:00:18] System starts up because power supply is newly connected.
[2025-05-27 15:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 15:00:23] Pending for incoming shutdown command...
[2025-05-27 15:00:24] Schedule next shutdown at: 2025-05-27 15:15:00
[2025-05-27 15:00:24] Schedule next startup at: 2025-05-27 17:00:00
[2025-05-27 15:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-27 15:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 17:00:18] Done :-)
[2025-05-27 17:00:18] Firmware ID: 0x37
[2025-05-27 17:00:18] Firmware Revison: 0x07
[2025-05-27 17:00:18] Current Vout=5.14V, Iout=0.36A
[2025-05-27 17:00:18] System starts up because power supply is newly connected.
[2025-05-27 17:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 17:00:23] Pending for incoming shutdown command...
[2025-05-27 17:00:23] Schedule next shutdown at: 2025-05-27 17:15:00
[2025-05-27 17:00:24] Schedule next startup at: 2025-05-27 19:00:00
[2025-05-27 17:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-27 17:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 19:00:17] Done :-)
[2025-05-27 19:00:17] Firmware ID: 0x37
[2025-05-27 19:00:17] Firmware Revison: 0x07
[2025-05-27 19:00:17] Current Vout=5.27V, Iout=0.43A
[2025-05-27 19:00:17] System starts up because power supply is newly connected.
[2025-05-27 19:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 19:00:22] Pending for incoming shutdown command...
[2025-05-27 19:00:22] Schedule next shutdown at: 2025-05-27 19:15:00
[2025-05-27 19:00:23] Schedule next startup at: 2025-05-27 21:00:00
[2025-05-27 19:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-27 19:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 21:00:17] Done :-)
[2025-05-27 21:00:17] Firmware ID: 0x37
[2025-05-27 21:00:17] Firmware Revison: 0x07
[2025-05-27 21:00:17] Current Vout=5.2V, Iout=0.55A
[2025-05-27 21:00:17] System starts up because power supply is newly connected.
[2025-05-27 21:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 21:00:22] Pending for incoming shutdown command...
[2025-05-27 21:00:23] Schedule next shutdown at: 2025-05-27 21:15:00
[2025-05-27 21:00:23] Schedule next startup at: 2025-05-27 23:00:00
[2025-05-27 21:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-27 21:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 21:30:55] Done :-)
[2025-05-27 21:30:55] Firmware ID: 0x37
[2025-05-27 21:30:55] Firmware Revison: 0x07
[2025-05-27 21:30:55] Current Vout=5.26V, Iout=0.4A
[2025-05-27 21:30:55] System starts up because power supply is newly connected.
[2025-05-27 21:31:00] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 21:31:00] Pending for incoming shutdown command...
[2025-05-27 21:31:00] Schedule script is interrupted, revising the schedule...
[2025-05-27 21:31:01] Schedule next shutdown at: 2025-05-27 22:59:00
[2025-05-27 21:31:01] Schedule next startup at: 2025-05-27 23:00:00
[2025-05-27 22:58:59] Shutting down system because scheduled shutdown is due.
[2025-05-27 22:58:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-27 23:00:17] Done :-)
[2025-05-27 23:00:17] Firmware ID: 0x37
[2025-05-27 23:00:17] Firmware Revison: 0x07
[2025-05-27 23:00:17] Current Vout=5.19V, Iout=0.55A
[2025-05-27 23:00:17] System starts up because power supply is newly connected.
[2025-05-27 23:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-27 23:00:22] Pending for incoming shutdown command...
[2025-05-27 23:00:23] Schedule next shutdown at: 2025-05-27 23:15:00
[2025-05-27 23:00:23] Schedule next startup at: 2025-05-28 01:00:00
[2025-05-27 23:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-27 23:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 01:00:18] Done :-)
[2025-05-28 01:00:18] Firmware ID: 0x37
[2025-05-28 01:00:18] Firmware Revison: 0x07
[2025-05-28 01:00:18] Current Vout=5.13V, Iout=0.49A
[2025-05-28 01:00:18] System starts up because power supply is newly connected.
[2025-05-28 01:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 01:00:23] Pending for incoming shutdown command...
[2025-05-28 01:00:23] Schedule next shutdown at: 2025-05-28 01:15:00
[2025-05-28 01:00:24] Schedule next startup at: 2025-05-28 03:00:00
[2025-05-28 01:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-28 01:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 03:00:17] Done :-)
[2025-05-28 03:00:17] Firmware ID: 0x37
[2025-05-28 03:00:17] Firmware Revison: 0x07
[2025-05-28 03:00:17] Current Vout=5.25V, Iout=0.38A
[2025-05-28 03:00:17] System starts up because power supply is newly connected.
[2025-05-28 03:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 03:00:22] Pending for incoming shutdown command...
[2025-05-28 03:00:22] Schedule next shutdown at: 2025-05-28 03:15:00
[2025-05-28 03:00:23] Schedule next startup at: 2025-05-28 05:00:00
[2025-05-28 03:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-28 03:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 05:00:17] Done :-)
[2025-05-28 05:00:17] Firmware ID: 0x37
[2025-05-28 05:00:17] Firmware Revison: 0x07
[2025-05-28 05:00:17] Current Vout=5.21V, Iout=0.51A
[2025-05-28 05:00:17] System starts up because power supply is newly connected.
[2025-05-28 05:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 05:00:22] Pending for incoming shutdown command...
[2025-05-28 05:00:23] Schedule next shutdown at: 2025-05-28 05:15:00
[2025-05-28 05:00:23] Schedule next startup at: 2025-05-28 07:00:00
[2025-05-28 05:14:59] Shutting down system because scheduled shutdown is due.
[2025-05-28 05:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 07:00:17] Done :-)
[2025-05-28 07:00:17] Firmware ID: 0x37
[2025-05-28 07:00:17] Firmware Revison: 0x07
[2025-05-28 07:00:17] Current Vout=5.19V, Iout=0.43A
[2025-05-28 07:00:17] System starts up because power supply is newly connected.
[2025-05-28 07:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 07:00:22] Pending for incoming shutdown command...
[2025-05-28 07:00:23] Schedule next shutdown at: 2025-05-28 07:15:00
[2025-05-28 07:00:23] Schedule next startup at: 2025-05-28 09:00:00
[2025-05-28 07:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-28 07:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 09:00:17] Done :-)
[2025-05-28 09:00:17] Firmware ID: 0x37
[2025-05-28 09:00:17] Firmware Revison: 0x07
[2025-05-28 09:00:17] Current Vout=5.2V, Iout=0.55A
[2025-05-28 09:00:17] System starts up because power supply is newly connected.
[2025-05-28 09:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 09:00:22] Pending for incoming shutdown command...
[2025-05-28 09:00:23] Schedule next shutdown at: 2025-05-28 09:15:00
[2025-05-28 09:00:23] Schedule next startup at: 2025-05-28 11:00:00
[2025-05-28 09:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-28 09:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 11:00:17] Done :-)
[2025-05-28 11:00:17] Firmware ID: 0x37
[2025-05-28 11:00:17] Firmware Revison: 0x07
[2025-05-28 11:00:17] Current Vout=5.14V, Iout=0.47A
[2025-05-28 11:00:17] System starts up because power supply is newly connected.
[2025-05-28 11:00:22] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 11:00:22] Pending for incoming shutdown command...
[2025-05-28 11:00:22] Schedule next shutdown at: 2025-05-28 11:15:00
[2025-05-28 11:00:23] Schedule next startup at: 2025-05-28 13:00:00
[2025-05-28 11:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-28 11:14:58] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 12:52:26] Done :-)
[2025-05-28 12:52:26] Firmware ID: 0x37
[2025-05-28 12:52:26] Firmware Revison: 0x07
[2025-05-28 12:52:26] Current Vout=5.26V, Iout=0.36A
[2025-05-28 12:52:26] System starts up because power supply is newly connected.
[2025-05-28 12:52:31] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 12:52:31] Pending for incoming shutdown command...
[2025-05-28 12:52:31] Schedule script is interrupted, revising the schedule...
[2025-05-28 12:52:31] Schedule next shutdown at: 2025-05-28 12:59:00
[2025-05-28 12:52:32] Schedule next startup at: 2025-05-28 13:00:00
[2025-05-28 13:00:18] Done :-)
[2025-05-28 13:00:18] Firmware ID: 0x37
[2025-05-28 13:00:18] Firmware Revison: 0x07
[2025-05-28 13:00:18] Current Vout=5.2V, Iout=0.49A
[2025-05-28 13:00:18] System starts up because power supply is newly connected.
[2025-05-28 13:00:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:00:23] Pending for incoming shutdown command...
[2025-05-28 13:00:24] Schedule next shutdown at: 2025-05-28 13:15:00
[2025-05-28 13:00:24] Schedule next startup at: 2025-05-28 15:00:00
[2025-05-28 13:11:57] Done :-)
[2025-05-28 13:11:57] Firmware ID: 0x37
[2025-05-28 13:11:57] Firmware Revison: 0x07
[2025-05-28 13:11:57] Current Vout=5.19V, Iout=0.4A
[2025-05-28 13:11:57] System starts up because power supply is newly connected.
[2025-05-28 13:12:02] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:12:02] Pending for incoming shutdown command...
[2025-05-28 13:12:03] Schedule next shutdown at: 2025-05-28 13:15:00
[2025-05-28 13:12:03] Schedule next startup at: 2025-05-28 15:00:00
[2025-05-28 13:14:58] Shutting down system because scheduled shutdown is due.
[2025-05-28 13:14:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-28 13:15:46] Done :-)
[2025-05-28 13:15:46] Firmware ID: 0x37
[2025-05-28 13:15:46] Firmware Revison: 0x07
[2025-05-28 13:15:46] Current Vout=5.19V, Iout=0.47A
[2025-05-28 13:15:46] System starts up because power supply is newly connected.
[2025-05-28 13:15:51] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:15:51] Pending for incoming shutdown command...
[2025-05-28 13:15:51] Schedule script is interrupted, revising the schedule...
[2025-05-28 13:15:52] Schedule next shutdown at: 2025-05-28 14:59:00
[2025-05-28 13:15:52] Schedule next startup at: 2025-05-28 15:00:00
[2025-05-28 13:23:36] Done :-)
[2025-05-28 13:23:36] Firmware ID: 0x37
[2025-05-28 13:23:36] Firmware Revison: 0x07
[2025-05-28 13:23:36] Current Vout=5.25V, Iout=0.43A
[2025-05-28 13:23:36] System starts up because power supply is newly connected.
[2025-05-28 13:23:41] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:23:41] Pending for incoming shutdown command...
[2025-05-28 13:23:41] Schedule next shutdown at: 2025-05-28 15:15:00
[2025-05-28 13:23:42] Schedule next startup at: 2025-05-28 17:00:00
[2025-05-28 13:28:50] Clearing auto startup time...
[2025-05-28 13:28:50] done :-)
[2025-05-28 13:28:56] Clearing auto shutdown time...
[2025-05-28 13:28:56] done :-)
[2025-05-28 13:29:09] Deleting "schedule.wpi" file...
[2025-05-28 13:29:09] done :-)
[2025-05-28 13:37:42] Done :-)
[2025-05-28 13:37:42] Firmware ID: 0x37
[2025-05-28 13:37:42] Firmware Revison: 0x07
[2025-05-28 13:37:42] Current Vout=5.2V, Iout=0.12A
[2025-05-28 13:37:42] System starts up because power supply is newly connected.
[2025-05-28 13:37:47] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:37:47] File "schedule.wpi" not found, skip running schedule script.
[2025-05-28 13:37:47] Pending for incoming shutdown command...
[2025-05-28 13:50:30] Done :-)
[2025-05-28 13:50:30] Firmware ID: 0x37
[2025-05-28 13:50:30] Firmware Revison: 0x07
[2025-05-28 13:50:30] Current Vout=5.21V, Iout=0A
[2025-05-28 13:50:30] System starts up because power supply is newly connected.
[2025-05-28 13:50:35] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 13:50:35] File "schedule.wpi" not found, skip running schedule script.
[2025-05-28 13:50:35] Pending for incoming shutdown command...
[2025-05-28 13:51:58] [Warning] System and RTC time seems not synchronized, difference is 61s. System time is "2025-05-28 13:51:58 EEST", while RTC time is "2025-05-28 13:52:59 EEST". Please synchronize the time first.
[2025-05-28 13:52:06] Copying "test_schedule.wpi" to "schedule.wpi"...
[2025-05-28 13:52:06] Running the script...
[2025-05-28 13:52:06] Schedule next shutdown at: 2025-05-28 14:00:00
[2025-05-28 13:52:07] Schedule next startup at: 2025-05-28 14:05:00
[2025-05-28 13:52:07] Done :-)
[2025-05-28 13:55:53] Copying "test_schedule.wpi" to "schedule.wpi"...
[2025-05-28 13:55:53] Running the script...
[2025-05-28 13:55:53] I need at least one OFF state in the script.
[2025-05-28 13:55:53] Done :-)
[2025-05-28 13:57:24] Copying "test_schedule.wpi" to "schedule.wpi"...
[2025-05-28 13:57:24] Running the script...
[2025-05-28 13:57:25] I need at least one OFF state in the script.
[2025-05-28 13:57:25] Done :-)
[2025-05-28 13:57:33] Deleting "schedule.wpi" file...
[2025-05-28 13:57:33] done :-)
[2025-05-28 13:57:41] Clearing auto startup time...
[2025-05-28 13:57:41] done :-)
[2025-05-28 13:57:46] Clearing auto shutdown time...
[2025-05-28 13:57:46] done :-)
[2025-05-28 13:57:54] Copying "test_schedule.wpi" to "schedule.wpi"...
[2025-05-28 13:57:54] Running the script...
[2025-05-28 13:57:55] I need at least one OFF state in the script.
[2025-05-28 13:57:55] Done :-)
[2025-05-28 13:59:17] Deleting "schedule.wpi" file...
[2025-05-28 13:59:17] done :-)
[2025-05-28 13:59:24] Copying "test_schedule.wpi" to "schedule.wpi"...
[2025-05-28 13:59:24] Running the script...
[2025-05-28 13:59:25] Done :-)
[2025-05-28 14:17:24] Applying network time to system...
[2025-05-28 14:17:35] Done :-)
[2025-05-28 14:17:35] Writing system time to RTC...
<2025-05-28 14:17:35> Done :-)
[2025-05-28 14:33:13] Done :-)
[2025-05-28 14:33:13] Firmware ID: 0x37
[2025-05-28 14:33:13] Firmware Revison: 0x07
[2025-05-28 14:33:13] Current Vout=5.21V, Iout=0.21A
[2025-05-28 14:33:13] System starts up because power supply is newly connected.
/home/asmeskla/wittypi/beforeScript.sh: line 13: /home/asmeskla/wittypi/syncTime.sh: Permission denied
[2025-05-28 14:33:18] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 14:33:18] Pending for incoming shutdown command...
[2025-05-28 14:35:30] Done :-)
[2025-05-28 14:35:30] Firmware ID: 0x37
[2025-05-28 14:35:30] Firmware Revison: 0x07
[2025-05-28 14:35:30] Current Vout=5.2V, Iout=0.23A
[2025-05-28 14:35:30] System starts up because power supply is newly connected.
[2025-05-28 14:37:36] Applying network time to system...
  Done :-)
[2025-05-28 14:37:36] Done :-)
[2025-05-28 14:37:36] Writing system time to RTC...
  Done :-)
<2025-05-28 14:37:36> Done :-)
[2025-05-28 14:37:36] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 14:37:36] Pending for incoming shutdown command...
[2025-05-28 14:37:39] Done :-)
[2025-05-28 14:37:39] Firmware ID: 0x37
[2025-05-28 14:37:39] Firmware Revison: 0x07
[2025-05-28 14:37:39] Current Vout=5.22V, Iout=0.27A
[2025-05-28 14:37:39] System starts up because power supply is newly connected.
[2025-05-28 14:39:44] Applying network time to system...
  Done :-)
[2025-05-28 14:39:46] Done :-)
[2025-05-28 14:39:46] Writing system time to RTC...
  Done :-)
<2025-05-28 14:39:46> Done :-)
[2025-05-28 14:39:46] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-28 14:39:46] Pending for incoming shutdown command...
[2025-05-28 14:40:45] Applying network time to system...
[2025-05-28 14:40:45] Done :-)
[2025-05-28 14:40:45] Writing system time to RTC...
<2025-05-28 14:40:45> Done :-)
[2025-05-28 14:51:26] Deleting "schedule.wpi" file...
[2025-05-28 14:51:26] done :-)
[2025-05-28 14:51:40] Copying "AttalosTrapSchedule.wpi" to "schedule.wpi"...
[2025-05-28 14:51:40] Running the script...
[2025-05-28 14:51:40] Schedule next shutdown at: 2025-05-28 15:15:00
[2025-05-28 14:51:41] Schedule next startup at: 2025-05-28 17:00:00
[2025-05-28 14:51:41] Done :-)
[2025-05-28 18:56:55] Internet detected, apply network time to system and Witty Pi...
[2025-05-28 18:56:55] Applying network time to system...
[2025-05-28 21:58:08] Done :-)
[2025-05-28 21:58:08] Writing system time to RTC...
<2025-05-28 21:58:08> Done :-)
<2025-05-28 21:58:16> Writing system time to RTC...
<2025-05-28 21:58:16> Done :-)
[2025-05-28 22:42:05] Deleting "schedule.wpi" file...
[2025-05-28 22:42:05] done :-)
[2025-05-28 22:42:17] Clearing auto startup time...
[2025-05-28 22:42:17] done :-)
[2025-05-28 22:42:25] Clearing auto shutdown time...
[2025-05-28 22:42:25] done :-)
[2025-05-28 22:42:33] Copying "AttalosTrapSchedule.wpi" to "schedule.wpi"...
[2025-05-28 22:42:33] Running the script...
[2025-05-28 22:42:34] Schedule next shutdown at: 2025-05-28 23:15:00
[2025-05-28 22:42:34] Schedule next startup at: 2025-05-29 01:00:00
[2025-05-28 22:42:34] Done :-)
[2025-05-28 22:23:19] Internet detected, apply network time to system and Witty Pi...
[2025-05-28 22:23:19] Applying network time to system...
[2025-05-29 00:27:31] Done :-)
[2025-05-29 00:27:31] Writing system time to RTC...
<2025-05-29 00:27:31> Done :-)
[2025-05-29 17:29:12] Done :-)
[2025-05-29 17:29:12] Firmware ID: 0x37
[2025-05-29 17:29:12] Firmware Revison: 0x07
[2025-05-29 17:29:12] Current Vout=5.21V, Iout=0.3A
[2025-05-29 17:29:12] System starts up because the button is clicked.
[2025-05-29 17:30:59] Copying "AttalosTrapSchedule.wpi" to "schedule.wpi"...
[2025-05-29 17:30:59] Running the script...
[2025-05-29 17:31:00] Schedule next shutdown at: 2025-05-29 19:15:00
[2025-05-29 17:31:00] Schedule next startup at: 2025-05-29 21:00:00
[2025-05-29 17:31:00] Done :-)
[2025-05-29 17:31:18] Applying network time to system...
  Done :-)
[2025-05-29 17:31:21] Done :-)
[2025-05-29 17:31:21] Writing system time to RTC...
  Done :-)
<2025-05-29 17:31:21> Done :-)
[2025-05-29 17:31:21] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 17:31:21] Pending for incoming shutdown command...
[2025-05-29 17:31:21] Schedule next shutdown at: 2025-05-29 19:15:00
[2025-05-29 17:31:21] Schedule next startup at: 2025-05-29 21:00:00
[2025-05-29 17:31:24] Copying "AttalosTrapSchedule.wpi" to "schedule.wpi"...
[2025-05-29 17:31:24] Running the script...
[2025-05-29 17:31:25] Schedule next shutdown at: 2025-05-29 19:15:00
[2025-05-29 17:31:25] Schedule next startup at: 2025-05-29 21:00:00
[2025-05-29 17:31:25] Done :-)
[2025-05-29 17:39:15] Copying "on_10m_every_20m.wpi" to "schedule.wpi"...
[2025-05-29 17:39:15] Running the script...
[2025-05-29 17:39:16] Schedule next shutdown at: 2025-05-29 17:50:00
[2025-05-29 17:39:16] Schedule next startup at: 2025-05-29 18:00:00
[2025-05-29 17:39:16] Done :-)
[2025-05-29 17:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 17:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 18:00:18] Done :-)
[2025-05-29 18:00:18] Firmware ID: 0x37
[2025-05-29 18:00:18] Firmware Revison: 0x07
[2025-05-29 18:00:18] Current Vout=5.26V, Iout=0.64A
[2025-05-29 18:00:18] System starts up because power supply is newly connected.
[2025-05-29 18:02:23] Applying network time to system...
  Done :-)
[2025-05-29 18:02:25] Done :-)
[2025-05-29 18:02:25] Writing system time to RTC...
  Done :-)
<2025-05-29 18:02:25> Done :-)
[2025-05-29 18:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 18:02:25] Pending for incoming shutdown command...
[2025-05-29 18:02:25] Schedule next shutdown at: 2025-05-29 18:10:00
[2025-05-29 18:02:25] Schedule next startup at: 2025-05-29 18:20:00
[2025-05-29 18:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 18:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 18:20:18] Done :-)
[2025-05-29 18:20:18] Firmware ID: 0x37
[2025-05-29 18:20:18] Firmware Revison: 0x07
[2025-05-29 18:20:18] Current Vout=5.2V, Iout=0.49A
[2025-05-29 18:20:18] System starts up because power supply is newly connected.
[2025-05-29 18:22:23] Applying network time to system...
  Done :-)
[2025-05-29 18:22:25] Done :-)
[2025-05-29 18:22:25] Writing system time to RTC...
  Done :-)
<2025-05-29 18:22:25> Done :-)
[2025-05-29 18:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 18:22:25] Pending for incoming shutdown command...
[2025-05-29 18:22:25] Schedule next shutdown at: 2025-05-29 18:30:00
[2025-05-29 18:22:25] Schedule next startup at: 2025-05-29 18:40:00
[2025-05-29 18:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 18:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 18:40:18] Done :-)
[2025-05-29 18:40:18] Firmware ID: 0x37
[2025-05-29 18:40:18] Firmware Revison: 0x07
[2025-05-29 18:40:18] Current Vout=5.2V, Iout=0.47A
[2025-05-29 18:40:18] System starts up because power supply is newly connected.
[2025-05-29 18:42:23] Applying network time to system...
  Done :-)
[2025-05-29 18:42:25] Done :-)
[2025-05-29 18:42:25] Writing system time to RTC...
  Done :-)
<2025-05-29 18:42:25> Done :-)
[2025-05-29 18:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 18:42:25] Pending for incoming shutdown command...
[2025-05-29 18:42:25] Schedule next shutdown at: 2025-05-29 18:50:00
[2025-05-29 18:42:25] Schedule next startup at: 2025-05-29 19:00:00
[2025-05-29 18:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 18:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 19:00:17] Done :-)
[2025-05-29 19:00:17] Firmware ID: 0x37
[2025-05-29 19:00:17] Firmware Revison: 0x07
[2025-05-29 19:00:17] Current Vout=5.19V, Iout=0.21A
[2025-05-29 19:00:17] System starts up because power supply is newly connected.
[2025-05-29 19:02:22] Applying network time to system...
  Done :-)
[2025-05-29 19:02:25] Done :-)
[2025-05-29 19:02:25] Writing system time to RTC...
  Done :-)
<2025-05-29 19:02:25> Done :-)
[2025-05-29 19:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 19:02:25] Pending for incoming shutdown command...
[2025-05-29 19:02:25] Schedule next shutdown at: 2025-05-29 19:10:00
[2025-05-29 19:02:25] Schedule next startup at: 2025-05-29 19:20:00
[2025-05-29 19:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 19:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 19:20:17] Done :-)
[2025-05-29 19:20:17] Firmware ID: 0x37
[2025-05-29 19:20:17] Firmware Revison: 0x07
[2025-05-29 19:20:17] Current Vout=5.19V, Iout=0.43A
[2025-05-29 19:20:17] System starts up because power supply is newly connected.
[2025-05-29 19:22:22] Applying network time to system...
  Done :-)
[2025-05-29 19:22:25] Done :-)
[2025-05-29 19:22:25] Writing system time to RTC...
  Done :-)
<2025-05-29 19:22:25> Done :-)
[2025-05-29 19:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 19:22:25] Pending for incoming shutdown command...
[2025-05-29 19:22:25] Schedule next shutdown at: 2025-05-29 19:30:00
[2025-05-29 19:22:25] Schedule next startup at: 2025-05-29 19:40:00
[2025-05-29 19:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 19:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 19:40:17] Done :-)
[2025-05-29 19:40:17] Firmware ID: 0x37
[2025-05-29 19:40:17] Firmware Revison: 0x07
[2025-05-29 19:40:17] Current Vout=5.2V, Iout=0.64A
[2025-05-29 19:40:17] System starts up because power supply is newly connected.
[2025-05-29 19:42:22] Applying network time to system...
  Done :-)
[2025-05-29 19:42:24] Done :-)
[2025-05-29 19:42:24] Writing system time to RTC...
  Done :-)
<2025-05-29 19:42:24> Done :-)
[2025-05-29 19:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 19:42:24] Pending for incoming shutdown command...
[2025-05-29 19:42:24] Schedule next shutdown at: 2025-05-29 19:50:00
[2025-05-29 19:42:24] Schedule next startup at: 2025-05-29 20:00:00
[2025-05-29 19:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 19:50:01] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 20:00:17] Done :-)
[2025-05-29 20:00:17] Firmware ID: 0x37
[2025-05-29 20:00:17] Firmware Revison: 0x07
[2025-05-29 20:00:17] Current Vout=5.27V, Iout=0.25A
[2025-05-29 20:00:17] System starts up because power supply is newly connected.
[2025-05-29 20:02:22] Applying network time to system...
  Done :-)
[2025-05-29 20:02:25] Done :-)
[2025-05-29 20:02:25] Writing system time to RTC...
  Done :-)
<2025-05-29 20:02:25> Done :-)
[2025-05-29 20:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 20:02:25] Pending for incoming shutdown command...
[2025-05-29 20:02:25] Schedule next shutdown at: 2025-05-29 20:10:00
[2025-05-29 20:02:25] Schedule next startup at: 2025-05-29 20:20:00
[2025-05-29 20:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 20:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 20:20:17] Done :-)
[2025-05-29 20:20:17] Firmware ID: 0x37
[2025-05-29 20:20:17] Firmware Revison: 0x07
[2025-05-29 20:20:17] Current Vout=5.2V, Iout=0.4A
[2025-05-29 20:20:17] System starts up because power supply is newly connected.
[2025-05-29 20:22:22] Applying network time to system...
  Done :-)
[2025-05-29 20:22:24] Done :-)
[2025-05-29 20:22:24] Writing system time to RTC...
  Done :-)
<2025-05-29 20:22:24> Done :-)
[2025-05-29 20:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 20:22:24] Pending for incoming shutdown command...
[2025-05-29 20:22:24] Schedule next shutdown at: 2025-05-29 20:30:00
[2025-05-29 20:22:24] Schedule next startup at: 2025-05-29 20:40:00
[2025-05-29 20:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 20:29:59] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] RTC has bad time, write system time into RTC
[xxxx-xx-xx xx:xx:xx] Writing system time to RTC...
<2025-05-29 20:30:04> Done :-)
<2025-05-29 20:30:04> Firmware ID: 0x37
<2025-05-29 20:30:04> Firmware Revison: 0x07
<2025-05-29 20:30:04> Current Vout=5.2V, Iout=0.47A
<2025-05-29 20:30:04> System starts up because power supply is newly connected.
[2025-05-29 20:32:10] Applying network time to system...
  Done :-)
[2025-05-29 20:46:13] Done :-)
[2025-05-29 20:46:13] Writing system time to RTC...
  Done :-)
<2025-05-29 20:46:13> Done :-)
<2025-05-29 20:46:13> Send out the SYS_UP signal via GPIO-17 pin.
<2025-05-29 20:46:13> Pending for incoming shutdown command...
[2025-05-29 20:46:13] Schedule next shutdown at: 2025-05-29 20:50:00
[2025-05-29 20:46:13] Schedule next startup at: 2025-05-29 21:00:00
<2025-05-29 20:50:00> Shutting down system because scheduled shutdown is due.
<2025-05-29 20:50:00> Halting all processes and then shutdown Raspberry Pi...
<2025-05-29 20:50:05> Done :-)
<2025-05-29 20:50:05> Firmware ID: 0x37
<2025-05-29 20:50:05> Firmware Revison: 0x07
<2025-05-29 20:50:06> Current Vout=5.21V, Iout=0.34A
<2025-05-29 20:50:06> System starts up because power supply is newly connected.
[2025-05-29 20:52:12] Applying network time to system...
  Done :-)
[2025-05-29 21:03:46] Done :-)
[2025-05-29 21:03:46] Writing system time to RTC...
  Done :-)
<2025-05-29 21:03:46> Done :-)
<2025-05-29 21:03:46> Send out the SYS_UP signal via GPIO-17 pin.
<2025-05-29 21:03:46> Pending for incoming shutdown command...
[2025-05-29 21:03:46] Schedule next shutdown at: 2025-05-29 21:10:00
[2025-05-29 21:03:46] Schedule next startup at: 2025-05-29 21:20:00
<2025-05-29 21:10:00> Shutting down system because scheduled shutdown is due.
<2025-05-29 21:10:00> Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 21:20:17] Done :-)
[2025-05-29 21:20:17] Firmware ID: 0x37
[2025-05-29 21:20:17] Firmware Revison: 0x07
[2025-05-29 21:20:17] Current Vout=5.19V, Iout=0.55A
[2025-05-29 21:20:17] System starts up because power supply is newly connected.
[2025-05-29 21:22:23] Applying network time to system...
  Done :-)
[2025-05-29 21:22:25] Done :-)
[2025-05-29 21:22:25] Writing system time to RTC...
  Done :-)
<2025-05-29 21:22:25> Done :-)
[2025-05-29 21:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 21:22:25] Pending for incoming shutdown command...
[2025-05-29 21:22:25] Schedule next shutdown at: 2025-05-29 21:30:00
[2025-05-29 21:22:25] Schedule next startup at: 2025-05-29 21:40:00
[2025-05-29 21:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 21:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 21:40:18] Done :-)
[2025-05-29 21:40:18] Firmware ID: 0x37
[2025-05-29 21:40:18] Firmware Revison: 0x07
[2025-05-29 21:40:18] Current Vout=5.26V, Iout=0.23A
[2025-05-29 21:40:18] System starts up because power supply is newly connected.
[2025-05-29 21:42:24] Applying network time to system...
  Done :-)
[2025-05-29 21:42:26] Done :-)
[2025-05-29 21:42:26] Writing system time to RTC...
  Done :-)
<2025-05-29 21:42:26> Done :-)
[2025-05-29 21:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 21:42:26] Pending for incoming shutdown command...
[2025-05-29 21:42:26] Schedule next shutdown at: 2025-05-29 21:50:00
[2025-05-29 21:42:26] Schedule next startup at: 2025-05-29 22:00:00
[2025-05-29 21:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 21:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 22:00:17] Done :-)
[2025-05-29 22:00:17] Firmware ID: 0x37
[2025-05-29 22:00:17] Firmware Revison: 0x07
[2025-05-29 22:00:17] Current Vout=5.27V, Iout=0.34A
[2025-05-29 22:00:17] System starts up because power supply is newly connected.
[2025-05-29 22:02:23] Applying network time to system...
  Done :-)
[2025-05-29 22:02:24] Done :-)
[2025-05-29 22:02:24] Writing system time to RTC...
  Done :-)
<2025-05-29 22:02:24> Done :-)
[2025-05-29 22:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 22:02:24] Pending for incoming shutdown command...
[2025-05-29 22:02:24] Schedule next shutdown at: 2025-05-29 22:10:00
[2025-05-29 22:02:24] Schedule next startup at: 2025-05-29 22:20:00
[2025-05-29 22:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 22:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 22:20:17] Done :-)
[2025-05-29 22:20:17] Firmware ID: 0x37
[2025-05-29 22:20:17] Firmware Revison: 0x07
[2025-05-29 22:20:17] Current Vout=5.19V, Iout=0.51A
[2025-05-29 22:20:17] System starts up because power supply is newly connected.
[2025-05-29 22:22:23] Applying network time to system...
  Done :-)
[2025-05-29 22:22:25] Done :-)
[2025-05-29 22:22:25] Writing system time to RTC...
  Done :-)
<2025-05-29 22:22:25> Done :-)
[2025-05-29 22:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 22:22:25] Pending for incoming shutdown command...
[2025-05-29 22:22:25] Schedule next shutdown at: 2025-05-29 22:30:00
[2025-05-29 22:22:25] Schedule next startup at: 2025-05-29 22:40:00
[2025-05-29 22:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 22:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 22:40:17] Done :-)
[2025-05-29 22:40:17] Firmware ID: 0x37
[2025-05-29 22:40:17] Firmware Revison: 0x07
[2025-05-29 22:40:17] Current Vout=5.19V, Iout=0.12A
[2025-05-29 22:40:17] System starts up because power supply is newly connected.
[2025-05-29 22:42:23] Applying network time to system...
  Done :-)
[2025-05-29 22:42:25] Done :-)
[2025-05-29 22:42:25] Writing system time to RTC...
  Done :-)
<2025-05-29 22:42:25> Done :-)
[2025-05-29 22:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 22:42:25] Pending for incoming shutdown command...
[2025-05-29 22:42:25] Schedule next shutdown at: 2025-05-29 22:50:00
[2025-05-29 22:42:25] Schedule next startup at: 2025-05-29 23:00:00
[2025-05-29 22:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 22:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 23:00:17] Done :-)
[2025-05-29 23:00:17] Firmware ID: 0x37
[2025-05-29 23:00:17] Firmware Revison: 0x07
[2025-05-29 23:00:17] Current Vout=5.26V, Iout=0.62A
[2025-05-29 23:00:17] System starts up because power supply is newly connected.
[2025-05-29 23:02:23] Applying network time to system...
  Done :-)
[2025-05-29 23:02:25] Done :-)
[2025-05-29 23:02:25] Writing system time to RTC...
  Done :-)
<2025-05-29 23:02:25> Done :-)
[2025-05-29 23:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 23:02:25] Pending for incoming shutdown command...
[2025-05-29 23:02:25] Schedule next shutdown at: 2025-05-29 23:10:00
[2025-05-29 23:02:25] Schedule next startup at: 2025-05-29 23:20:00
[2025-05-29 23:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 23:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 23:20:17] Done :-)
[2025-05-29 23:20:17] Firmware ID: 0x37
[2025-05-29 23:20:17] Firmware Revison: 0x07
[2025-05-29 23:20:17] Current Vout=5.2V, Iout=0.6A
[2025-05-29 23:20:17] System starts up because power supply is newly connected.
[2025-05-29 23:22:22] Applying network time to system...
  Done :-)
[2025-05-29 23:22:25] Done :-)
[2025-05-29 23:22:25] Writing system time to RTC...
  Done :-)
<2025-05-29 23:22:25> Done :-)
[2025-05-29 23:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 23:22:25] Pending for incoming shutdown command...
[2025-05-29 23:22:25] Schedule next shutdown at: 2025-05-29 23:30:00
[2025-05-29 23:22:25] Schedule next startup at: 2025-05-29 23:40:00
[2025-05-29 23:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-29 23:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-29 23:40:17] Done :-)
[2025-05-29 23:40:17] Firmware ID: 0x37
[2025-05-29 23:40:17] Firmware Revison: 0x07
[2025-05-29 23:40:17] Current Vout=5.2V, Iout=0.45A
[2025-05-29 23:40:17] System starts up because power supply is newly connected.
[2025-05-29 23:42:23] Applying network time to system...
  Done :-)
[2025-05-29 23:42:25] Done :-)
[2025-05-29 23:42:25] Writing system time to RTC...
  Done :-)
<2025-05-29 23:42:25> Done :-)
[2025-05-29 23:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-29 23:42:25] Pending for incoming shutdown command...
[2025-05-29 23:42:25] Schedule next shutdown at: 2025-05-29 23:50:00
[2025-05-29 23:42:25] Schedule next startup at: 2025-05-30 00:00:00
[2025-05-29 23:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-29 23:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 00:00:17] Done :-)
[2025-05-30 00:00:17] Firmware ID: 0x37
[2025-05-30 00:00:17] Firmware Revison: 0x07
[2025-05-30 00:00:17] Current Vout=5.27V, Iout=0.6A
[2025-05-30 00:00:17] System starts up because power supply is newly connected.
[2025-05-30 00:02:23] Applying network time to system...
  Done :-)
[2025-05-30 00:02:24] Done :-)
[2025-05-30 00:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 00:02:24> Done :-)
[2025-05-30 00:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 00:02:24] Pending for incoming shutdown command...
[2025-05-30 00:02:24] Schedule next shutdown at: 2025-05-30 00:10:00
[2025-05-30 00:02:24] Schedule next startup at: 2025-05-30 00:20:00
[2025-05-30 00:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 00:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 00:20:18] Done :-)
[2025-05-30 00:20:18] Firmware ID: 0x37
[2025-05-30 00:20:18] Firmware Revison: 0x07
[2025-05-30 00:20:18] Current Vout=5.2V, Iout=0.27A
[2025-05-30 00:20:18] System starts up because power supply is newly connected.
[2025-05-30 00:22:23] Applying network time to system...
  Done :-)
[2025-05-30 00:22:25] Done :-)
[2025-05-30 00:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 00:22:25> Done :-)
[2025-05-30 00:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 00:22:25] Pending for incoming shutdown command...
[2025-05-30 00:22:25] Schedule next shutdown at: 2025-05-30 00:30:00
[2025-05-30 00:22:25] Schedule next startup at: 2025-05-30 00:40:00
[2025-05-30 00:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 00:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 00:40:17] Done :-)
[2025-05-30 00:40:17] Firmware ID: 0x37
[2025-05-30 00:40:17] Firmware Revison: 0x07
[2025-05-30 00:40:17] Current Vout=5.27V, Iout=0.55A
[2025-05-30 00:40:17] System starts up because power supply is newly connected.
[2025-05-30 00:42:23] Applying network time to system...
  Done :-)
[2025-05-30 00:42:25] Done :-)
[2025-05-30 00:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 00:42:25> Done :-)
[2025-05-30 00:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 00:42:25] Pending for incoming shutdown command...
[2025-05-30 00:42:25] Schedule next shutdown at: 2025-05-30 00:50:00
[2025-05-30 00:42:25] Schedule next startup at: 2025-05-30 01:00:00
[2025-05-30 00:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 00:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 01:00:17] Done :-)
[2025-05-30 01:00:17] Firmware ID: 0x37
[2025-05-30 01:00:17] Firmware Revison: 0x07
[2025-05-30 01:00:17] Current Vout=5.26V, Iout=0.58A
[2025-05-30 01:00:17] System starts up because power supply is newly connected.
[2025-05-30 01:02:22] Applying network time to system...
  Done :-)
[2025-05-30 01:02:24] Done :-)
[2025-05-30 01:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 01:02:24> Done :-)
[2025-05-30 01:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 01:02:24] Pending for incoming shutdown command...
[2025-05-30 01:02:24] Schedule next shutdown at: 2025-05-30 01:10:00
[2025-05-30 01:02:24] Schedule next startup at: 2025-05-30 01:20:00
[2025-05-30 01:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 01:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 01:20:17] Done :-)
[2025-05-30 01:20:17] Firmware ID: 0x37
[2025-05-30 01:20:17] Firmware Revison: 0x07
[2025-05-30 01:20:17] Current Vout=5.2V, Iout=0.6A
[2025-05-30 01:20:17] System starts up because power supply is newly connected.
[2025-05-30 01:22:22] Applying network time to system...
  Done :-)
[2025-05-30 01:22:25] Done :-)
[2025-05-30 01:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 01:22:25> Done :-)
[2025-05-30 01:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 01:22:25] Pending for incoming shutdown command...
[2025-05-30 01:22:25] Schedule next shutdown at: 2025-05-30 01:30:00
[2025-05-30 01:22:25] Schedule next startup at: 2025-05-30 01:40:00
[2025-05-30 01:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 01:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 01:40:18] Done :-)
[2025-05-30 01:40:18] Firmware ID: 0x37
[2025-05-30 01:40:18] Firmware Revison: 0x07
[2025-05-30 01:40:18] Current Vout=5.2V, Iout=0.45A
[2025-05-30 01:40:18] System starts up because power supply is newly connected.
[2025-05-30 01:42:23] Applying network time to system...
  Done :-)
[2025-05-30 01:42:26] Done :-)
[2025-05-30 01:42:26] Writing system time to RTC...
  Done :-)
<2025-05-30 01:42:26> Done :-)
[2025-05-30 01:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 01:42:26] Pending for incoming shutdown command...
[2025-05-30 01:42:26] Schedule next shutdown at: 2025-05-30 01:50:00
[2025-05-30 01:42:26] Schedule next startup at: 2025-05-30 02:00:00
[2025-05-30 01:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 01:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 02:00:18] Done :-)
[2025-05-30 02:00:18] Firmware ID: 0x37
[2025-05-30 02:00:18] Firmware Revison: 0x07
[2025-05-30 02:00:18] Current Vout=5.21V, Iout=0.19A
[2025-05-30 02:00:18] System starts up because power supply is newly connected.
[2025-05-30 02:02:24] Applying network time to system...
  Done :-)
[2025-05-30 02:02:24] Done :-)
[2025-05-30 02:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 02:02:24> Done :-)
[2025-05-30 02:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 02:02:24] Pending for incoming shutdown command...
[2025-05-30 02:02:24] Schedule next shutdown at: 2025-05-30 02:10:00
[2025-05-30 02:02:24] Schedule next startup at: 2025-05-30 02:20:00
[2025-05-30 02:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 02:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 02:20:17] Done :-)
[2025-05-30 02:20:17] Firmware ID: 0x37
[2025-05-30 02:20:17] Firmware Revison: 0x07
[2025-05-30 02:20:17] Current Vout=5.27V, Iout=0.21A
[2025-05-30 02:20:17] System starts up because power supply is newly connected.
[2025-05-30 02:22:22] Applying network time to system...
  Done :-)
[2025-05-30 02:22:25] Done :-)
[2025-05-30 02:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 02:22:25> Done :-)
[2025-05-30 02:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 02:22:25] Pending for incoming shutdown command...
[2025-05-30 02:22:25] Schedule next shutdown at: 2025-05-30 02:30:00
[2025-05-30 02:22:25] Schedule next startup at: 2025-05-30 02:40:00
[2025-05-30 02:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 02:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 02:40:17] Done :-)
[2025-05-30 02:40:17] Firmware ID: 0x37
[2025-05-30 02:40:17] Firmware Revison: 0x07
[2025-05-30 02:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-30 02:40:17] System starts up because power supply is newly connected.
[2025-05-30 02:42:27] Applying network time to system...
  Done :-)
[2025-05-30 02:42:29] Done :-)
[2025-05-30 02:42:29] Writing system time to RTC...
  Done :-)
<2025-05-30 02:42:29> Done :-)
[2025-05-30 02:42:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 02:42:29] Pending for incoming shutdown command...
[2025-05-30 02:42:29] Schedule next shutdown at: 2025-05-30 02:50:00
[2025-05-30 02:42:29] Schedule next startup at: 2025-05-30 03:00:00
[2025-05-30 02:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 02:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 03:00:17] Done :-)
[2025-05-30 03:00:17] Firmware ID: 0x37
[2025-05-30 03:00:17] Firmware Revison: 0x07
[2025-05-30 03:00:17] Current Vout=5.13V, Iout=0.55A
[2025-05-30 03:00:17] System starts up because power supply is newly connected.
[2025-05-30 03:02:23] Applying network time to system...
  Done :-)
[2025-05-30 03:02:25] Done :-)
[2025-05-30 03:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 03:02:25> Done :-)
[2025-05-30 03:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 03:02:25] Pending for incoming shutdown command...
[2025-05-30 03:02:25] Schedule next shutdown at: 2025-05-30 03:10:00
[2025-05-30 03:02:26] Schedule next startup at: 2025-05-30 03:20:00
[2025-05-30 03:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 03:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 03:20:17] Done :-)
[2025-05-30 03:20:17] Firmware ID: 0x37
[2025-05-30 03:20:17] Firmware Revison: 0x07
[2025-05-30 03:20:17] Current Vout=5.2V, Iout=0.47A
[2025-05-30 03:20:17] System starts up because power supply is newly connected.
[2025-05-30 03:22:22] Applying network time to system...
  Done :-)
[2025-05-30 03:22:25] Done :-)
[2025-05-30 03:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 03:22:25> Done :-)
[2025-05-30 03:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 03:22:25] Pending for incoming shutdown command...
[2025-05-30 03:22:25] Schedule next shutdown at: 2025-05-30 03:30:00
[2025-05-30 03:22:25] Schedule next startup at: 2025-05-30 03:40:00
[2025-05-30 03:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 03:30:00] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-05-30 03:40:17] Done :-)
[2025-05-30 03:40:17] Firmware ID: 0x37
[2025-05-30 03:40:17] Firmware Revison: 0x07
[2025-05-30 03:40:17] Current Vout=5.13V, Iout=0.36A
[2025-05-30 03:40:17] System starts up because power supply is newly connected.
[2025-05-30 03:42:22] Applying network time to system...
  Done :-)
[2025-05-30 03:42:25] Done :-)
[2025-05-30 03:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 03:42:25> Done :-)
[2025-05-30 03:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 03:42:25] Pending for incoming shutdown command...
[2025-05-30 03:42:25] Schedule next shutdown at: 2025-05-30 03:50:00
[2025-05-30 03:42:25] Schedule next startup at: 2025-05-30 04:00:00
[2025-05-30 03:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 03:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 04:00:17] Done :-)
[2025-05-30 04:00:17] Firmware ID: 0x37
[2025-05-30 04:00:17] Firmware Revison: 0x07
[2025-05-30 04:00:17] Current Vout=5.2V, Iout=0.62A
[2025-05-30 04:00:17] System starts up because power supply is newly connected.
[2025-05-30 04:02:22] Applying network time to system...
  Done :-)
[2025-05-30 04:02:25] Done :-)
[2025-05-30 04:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 04:02:25> Done :-)
[2025-05-30 04:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 04:02:25] Pending for incoming shutdown command...
[2025-05-30 04:02:25] Schedule next shutdown at: 2025-05-30 04:10:00
[2025-05-30 04:02:25] Schedule next startup at: 2025-05-30 04:20:00
[2025-05-30 04:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 04:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 04:20:17] Done :-)
[2025-05-30 04:20:17] Firmware ID: 0x37
[2025-05-30 04:20:17] Firmware Revison: 0x07
[2025-05-30 04:20:17] Current Vout=5.2V, Iout=0.55A
[2025-05-30 04:20:17] System starts up because power supply is newly connected.
[2025-05-30 04:22:23] Applying network time to system...
  Done :-)
[2025-05-30 04:22:25] Done :-)
[2025-05-30 04:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 04:22:25> Done :-)
[2025-05-30 04:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 04:22:25] Pending for incoming shutdown command...
[2025-05-30 04:22:25] Schedule next shutdown at: 2025-05-30 04:30:00
[2025-05-30 04:22:25] Schedule next startup at: 2025-05-30 04:40:00
[2025-05-30 04:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 04:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 04:40:17] Done :-)
[2025-05-30 04:40:17] Firmware ID: 0x37
[2025-05-30 04:40:17] Firmware Revison: 0x07
[2025-05-30 04:40:17] Current Vout=5.27V, Iout=0.23A
[2025-05-30 04:40:17] System starts up because power supply is newly connected.
[2025-05-30 04:42:22] Applying network time to system...
  Done :-)
[2025-05-30 04:42:24] Done :-)
[2025-05-30 04:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 04:42:24> Done :-)
[2025-05-30 04:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 04:42:24] Pending for incoming shutdown command...
[2025-05-30 04:42:24] Schedule next shutdown at: 2025-05-30 04:50:00
[2025-05-30 04:42:24] Schedule next startup at: 2025-05-30 05:00:00
[2025-05-30 04:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 04:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 05:00:17] Done :-)
[2025-05-30 05:00:17] Firmware ID: 0x37
[2025-05-30 05:00:17] Firmware Revison: 0x07
[2025-05-30 05:00:17] Current Vout=5.27V, Iout=0.36A
[2025-05-30 05:00:17] System starts up because power supply is newly connected.
[2025-05-30 05:02:22] Applying network time to system...
  Done :-)
[2025-05-30 05:02:25] Done :-)
[2025-05-30 05:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 05:02:25> Done :-)
[2025-05-30 05:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 05:02:25] Pending for incoming shutdown command...
[2025-05-30 05:02:25] Schedule next shutdown at: 2025-05-30 05:10:00
[2025-05-30 05:02:25] Schedule next startup at: 2025-05-30 05:20:00
[2025-05-30 05:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 05:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 05:20:17] Done :-)
[2025-05-30 05:20:17] Firmware ID: 0x37
[2025-05-30 05:20:17] Firmware Revison: 0x07
[2025-05-30 05:20:17] Current Vout=5.19V, Iout=0.4A
[2025-05-30 05:20:17] System starts up because power supply is newly connected.
[2025-05-30 05:22:22] Applying network time to system...
  Done :-)
[2025-05-30 05:22:25] Done :-)
[2025-05-30 05:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 05:22:25> Done :-)
[2025-05-30 05:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 05:22:25] Pending for incoming shutdown command...
[2025-05-30 05:22:25] Schedule next shutdown at: 2025-05-30 05:30:00
[2025-05-30 05:22:25] Schedule next startup at: 2025-05-30 05:40:00
[2025-05-30 05:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 05:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 05:40:17] Done :-)
[2025-05-30 05:40:17] Firmware ID: 0x37
[2025-05-30 05:40:17] Firmware Revison: 0x07
[2025-05-30 05:40:17] Current Vout=5.19V, Iout=0.58A
[2025-05-30 05:40:17] System starts up because power supply is newly connected.
[2025-05-30 05:42:22] Applying network time to system...
  Done :-)
[2025-05-30 05:42:23] Done :-)
[2025-05-30 05:42:23] Writing system time to RTC...
  Done :-)
<2025-05-30 05:42:23> Done :-)
[2025-05-30 05:42:23] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 05:42:23] Pending for incoming shutdown command...
[2025-05-30 05:42:23] Schedule next shutdown at: 2025-05-30 05:50:00
[2025-05-30 05:42:23] Schedule next startup at: 2025-05-30 06:00:00
[2025-05-30 05:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 05:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 06:00:17] Done :-)
[2025-05-30 06:00:17] Firmware ID: 0x37
[2025-05-30 06:00:17] Firmware Revison: 0x07
[2025-05-30 06:00:17] Current Vout=5.2V, Iout=0.51A
[2025-05-30 06:00:17] System starts up because power supply is newly connected.
[2025-05-30 06:02:22] Applying network time to system...
  Done :-)
[2025-05-30 06:02:24] Done :-)
[2025-05-30 06:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 06:02:24> Done :-)
[2025-05-30 06:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 06:02:24] Pending for incoming shutdown command...
[2025-05-30 06:02:24] Schedule next shutdown at: 2025-05-30 06:10:00
[2025-05-30 06:02:24] Schedule next startup at: 2025-05-30 06:20:00
[2025-05-30 06:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 06:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 06:20:18] Done :-)
[2025-05-30 06:20:18] Firmware ID: 0x37
[2025-05-30 06:20:18] Firmware Revison: 0x07
[2025-05-30 06:20:18] Current Vout=5.2V, Iout=0.53A
[2025-05-30 06:20:18] System starts up because power supply is newly connected.
[2025-05-30 06:22:24] Applying network time to system...
  Done :-)
[2025-05-30 06:22:25] Done :-)
[2025-05-30 06:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 06:22:25> Done :-)
[2025-05-30 06:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 06:22:25] Pending for incoming shutdown command...
[2025-05-30 06:22:25] Schedule next shutdown at: 2025-05-30 06:30:00
[2025-05-30 06:22:25] Schedule next startup at: 2025-05-30 06:40:00
[2025-05-30 06:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 06:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 06:40:18] Done :-)
[2025-05-30 06:40:18] Firmware ID: 0x37
[2025-05-30 06:40:18] Firmware Revison: 0x07
[2025-05-30 06:40:18] Current Vout=5.19V, Iout=0.36A
[2025-05-30 06:40:18] System starts up because power supply is newly connected.
[2025-05-30 06:42:23] Applying network time to system...
  Done :-)
[2025-05-30 06:42:25] Done :-)
[2025-05-30 06:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 06:42:25> Done :-)
[2025-05-30 06:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 06:42:25] Pending for incoming shutdown command...
[2025-05-30 06:42:25] Schedule next shutdown at: 2025-05-30 06:50:00
[2025-05-30 06:42:25] Schedule next startup at: 2025-05-30 07:00:00
[2025-05-30 06:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 06:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 07:00:17] Done :-)
[2025-05-30 07:00:17] Firmware ID: 0x37
[2025-05-30 07:00:17] Firmware Revison: 0x07
[2025-05-30 07:00:17] Current Vout=5.2V, Iout=0.36A
[2025-05-30 07:00:17] System starts up because power supply is newly connected.
[2025-05-30 07:02:22] Applying network time to system...
  Done :-)
[2025-05-30 07:02:25] Done :-)
[2025-05-30 07:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 07:02:25> Done :-)
[2025-05-30 07:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 07:02:25] Pending for incoming shutdown command...
[2025-05-30 07:02:25] Schedule next shutdown at: 2025-05-30 07:10:00
[2025-05-30 07:02:25] Schedule next startup at: 2025-05-30 07:20:00
[2025-05-30 07:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 07:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 07:20:17] Done :-)
[2025-05-30 07:20:17] Firmware ID: 0x37
[2025-05-30 07:20:17] Firmware Revison: 0x07
[2025-05-30 07:20:17] Current Vout=5.19V, Iout=0.47A
[2025-05-30 07:20:17] System starts up because power supply is newly connected.
[2025-05-30 07:22:22] Applying network time to system...
  Done :-)
[2025-05-30 07:22:25] Done :-)
[2025-05-30 07:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 07:22:25> Done :-)
[2025-05-30 07:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 07:22:25] Pending for incoming shutdown command...
[2025-05-30 07:22:25] Schedule next shutdown at: 2025-05-30 07:30:00
[2025-05-30 07:22:25] Schedule next startup at: 2025-05-30 07:40:00
[2025-05-30 07:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 07:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 07:40:17] Done :-)
[2025-05-30 07:40:17] Firmware ID: 0x37
[2025-05-30 07:40:17] Firmware Revison: 0x07
[2025-05-30 07:40:17] Current Vout=5.19V, Iout=0.58A
[2025-05-30 07:40:17] System starts up because power supply is newly connected.
[2025-05-30 07:42:23] Applying network time to system...
  Done :-)
[2025-05-30 07:42:25] Done :-)
[2025-05-30 07:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 07:42:25> Done :-)
[2025-05-30 07:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 07:42:25] Pending for incoming shutdown command...
[2025-05-30 07:42:25] Schedule next shutdown at: 2025-05-30 07:50:00
[2025-05-30 07:42:25] Schedule next startup at: 2025-05-30 08:00:00
[2025-05-30 07:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 07:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 08:00:18] Done :-)
[2025-05-30 08:00:18] Firmware ID: 0x37
[2025-05-30 08:00:18] Firmware Revison: 0x07
[2025-05-30 08:00:18] Current Vout=5.19V, Iout=0.27A
[2025-05-30 08:00:18] System starts up because power supply is newly connected.
[2025-05-30 08:02:23] Applying network time to system...
  Done :-)
[2025-05-30 08:02:24] Done :-)
[2025-05-30 08:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 08:02:24> Done :-)
[2025-05-30 08:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 08:02:24] Pending for incoming shutdown command...
[2025-05-30 08:02:24] Schedule next shutdown at: 2025-05-30 08:10:00
[2025-05-30 08:02:24] Schedule next startup at: 2025-05-30 08:20:00
[2025-05-30 08:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 08:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 08:20:17] Done :-)
[2025-05-30 08:20:17] Firmware ID: 0x37
[2025-05-30 08:20:17] Firmware Revison: 0x07
[2025-05-30 08:20:17] Current Vout=5.2V, Iout=0.32A
[2025-05-30 08:20:17] System starts up because power supply is newly connected.
[2025-05-30 08:22:22] Applying network time to system...
  Done :-)
[2025-05-30 08:22:25] Done :-)
[2025-05-30 08:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 08:22:25> Done :-)
[2025-05-30 08:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 08:22:25] Pending for incoming shutdown command...
[2025-05-30 08:22:25] Schedule next shutdown at: 2025-05-30 08:30:00
[2025-05-30 08:22:25] Schedule next startup at: 2025-05-30 08:40:00
[2025-05-30 08:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 08:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 08:40:17] Done :-)
[2025-05-30 08:40:17] Firmware ID: 0x37
[2025-05-30 08:40:17] Firmware Revison: 0x07
[2025-05-30 08:40:17] Current Vout=5.19V, Iout=0.55A
[2025-05-30 08:40:17] System starts up because power supply is newly connected.
[2025-05-30 08:42:23] Applying network time to system...
  Done :-)
[2025-05-30 08:42:25] Done :-)
[2025-05-30 08:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 08:42:25> Done :-)
[2025-05-30 08:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 08:42:25] Pending for incoming shutdown command...
[2025-05-30 08:42:25] Schedule next shutdown at: 2025-05-30 08:50:00
[2025-05-30 08:42:26] Schedule next startup at: 2025-05-30 09:00:00
[2025-05-30 08:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 08:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 09:00:18] Done :-)
[2025-05-30 09:00:18] Firmware ID: 0x37
[2025-05-30 09:00:18] Firmware Revison: 0x07
[2025-05-30 09:00:18] Current Vout=5.2V, Iout=0.38A
[2025-05-30 09:00:18] System starts up because power supply is newly connected.
[2025-05-30 09:02:24] Applying network time to system...
  Done :-)
[2025-05-30 09:02:24] Done :-)
[2025-05-30 09:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 09:02:24> Done :-)
[2025-05-30 09:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 09:02:24] Pending for incoming shutdown command...
[2025-05-30 09:02:24] Schedule next shutdown at: 2025-05-30 09:10:00
[2025-05-30 09:02:24] Schedule next startup at: 2025-05-30 09:20:00
[2025-05-30 09:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 09:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 09:20:17] Done :-)
[2025-05-30 09:20:17] Firmware ID: 0x37
[2025-05-30 09:20:17] Firmware Revison: 0x07
[2025-05-30 09:20:17] Current Vout=5.2V, Iout=0.53A
[2025-05-30 09:20:17] System starts up because power supply is newly connected.
[2025-05-30 09:22:23] Applying network time to system...
  Done :-)
[2025-05-30 09:22:25] Done :-)
[2025-05-30 09:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 09:22:25> Done :-)
[2025-05-30 09:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 09:22:25] Pending for incoming shutdown command...
[2025-05-30 09:22:25] Schedule next shutdown at: 2025-05-30 09:30:00
[2025-05-30 09:22:25] Schedule next startup at: 2025-05-30 09:40:00
[2025-05-30 09:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 09:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 09:40:19] Done :-)
[2025-05-30 09:40:19] Firmware ID: 0x37
[2025-05-30 09:40:19] Firmware Revison: 0x07
[2025-05-30 09:40:19] Current Vout=5.14V, Iout=0.27A
[2025-05-30 09:40:19] System starts up because power supply is newly connected.
[2025-05-30 09:42:24] Applying network time to system...
  Done :-)
[2025-05-30 09:42:26] Done :-)
[2025-05-30 09:42:26] Writing system time to RTC...
  Done :-)
<2025-05-30 09:42:26> Done :-)
[2025-05-30 09:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 09:42:26] Pending for incoming shutdown command...
[2025-05-30 09:42:26] Schedule next shutdown at: 2025-05-30 09:50:00
[2025-05-30 09:42:26] Schedule next startup at: 2025-05-30 10:00:00
[2025-05-30 09:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 09:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 10:00:17] Done :-)
[2025-05-30 10:00:17] Firmware ID: 0x37
[2025-05-30 10:00:17] Firmware Revison: 0x07
[2025-05-30 10:00:17] Current Vout=5.2V, Iout=0.53A
[2025-05-30 10:00:17] System starts up because power supply is newly connected.
[2025-05-30 10:02:22] Applying network time to system...
  Done :-)
[2025-05-30 10:02:25] Done :-)
[2025-05-30 10:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 10:02:25> Done :-)
[2025-05-30 10:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 10:02:25] Pending for incoming shutdown command...
[2025-05-30 10:02:25] Schedule next shutdown at: 2025-05-30 10:10:00
[2025-05-30 10:02:25] Schedule next startup at: 2025-05-30 10:20:00
[2025-05-30 10:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 10:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 10:20:17] Done :-)
[2025-05-30 10:20:17] Firmware ID: 0x37
[2025-05-30 10:20:17] Firmware Revison: 0x07
[2025-05-30 10:20:17] Current Vout=5.27V, Iout=0.58A
[2025-05-30 10:20:17] System starts up because power supply is newly connected.
[2025-05-30 10:22:23] Applying network time to system...
  Done :-)
[2025-05-30 10:22:25] Done :-)
[2025-05-30 10:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 10:22:25> Done :-)
[2025-05-30 10:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 10:22:25] Pending for incoming shutdown command...
[2025-05-30 10:22:25] Schedule next shutdown at: 2025-05-30 10:30:00
[2025-05-30 10:22:25] Schedule next startup at: 2025-05-30 10:40:00
[2025-05-30 10:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 10:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 10:40:18] Done :-)
[2025-05-30 10:40:18] Firmware ID: 0x37
[2025-05-30 10:40:18] Firmware Revison: 0x07
[2025-05-30 10:40:18] Current Vout=5.19V, Iout=0.51A
[2025-05-30 10:40:18] System starts up because power supply is newly connected.
[2025-05-30 10:42:24] Applying network time to system...
  Done :-)
[2025-05-30 10:42:26] Done :-)
[2025-05-30 10:42:26] Writing system time to RTC...
  Done :-)
<2025-05-30 10:42:26> Done :-)
[2025-05-30 10:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 10:42:26] Pending for incoming shutdown command...
[2025-05-30 10:42:26] Schedule next shutdown at: 2025-05-30 10:50:00
[2025-05-30 10:42:26] Schedule next startup at: 2025-05-30 11:00:00
[2025-05-30 10:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 10:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 11:00:17] Done :-)
[2025-05-30 11:00:17] Firmware ID: 0x37
[2025-05-30 11:00:17] Firmware Revison: 0x07
[2025-05-30 11:00:17] Current Vout=5.27V, Iout=0.34A
[2025-05-30 11:00:17] System starts up because power supply is newly connected.
[2025-05-30 11:02:22] Applying network time to system...
  Done :-)
[2025-05-30 11:02:24] Done :-)
[2025-05-30 11:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 11:02:24> Done :-)
[2025-05-30 11:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 11:02:24] Pending for incoming shutdown command...
[2025-05-30 11:02:24] Schedule next shutdown at: 2025-05-30 11:10:00
[2025-05-30 11:02:24] Schedule next startup at: 2025-05-30 11:20:00
[2025-05-30 11:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 11:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 11:20:17] Done :-)
[2025-05-30 11:20:17] Firmware ID: 0x37
[2025-05-30 11:20:17] Firmware Revison: 0x07
[2025-05-30 11:20:17] Current Vout=5.2V, Iout=0.51A
[2025-05-30 11:20:17] System starts up because power supply is newly connected.
[2025-05-30 11:22:22] Applying network time to system...
  Done :-)
[2025-05-30 11:22:24] Done :-)
[2025-05-30 11:22:24] Writing system time to RTC...
  Done :-)
<2025-05-30 11:22:24> Done :-)
[2025-05-30 11:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 11:22:24] Pending for incoming shutdown command...
[2025-05-30 11:22:24] Schedule next shutdown at: 2025-05-30 11:30:00
[2025-05-30 11:22:24] Schedule next startup at: 2025-05-30 11:40:00
[2025-05-30 11:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 11:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 11:40:17] Done :-)
[2025-05-30 11:40:17] Firmware ID: 0x37
[2025-05-30 11:40:17] Firmware Revison: 0x07
[2025-05-30 11:40:17] Current Vout=5.26V, Iout=0.43A
[2025-05-30 11:40:17] System starts up because power supply is newly connected.
[2025-05-30 11:42:22] Applying network time to system...
  Done :-)
[2025-05-30 11:42:25] Done :-)
[2025-05-30 11:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 11:42:25> Done :-)
[2025-05-30 11:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 11:42:25] Pending for incoming shutdown command...
[2025-05-30 11:42:25] Schedule next shutdown at: 2025-05-30 11:50:00
[2025-05-30 11:42:25] Schedule next startup at: 2025-05-30 12:00:00
[2025-05-30 11:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 11:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 12:00:17] Done :-)
[2025-05-30 12:00:17] Firmware ID: 0x37
[2025-05-30 12:00:17] Firmware Revison: 0x07
[2025-05-30 12:00:17] Current Vout=5.2V, Iout=0.34A
[2025-05-30 12:00:17] System starts up because power supply is newly connected.
[2025-05-30 12:02:27] Applying network time to system...
  Done :-)
[2025-05-30 12:02:30] Done :-)
[2025-05-30 12:02:30] Writing system time to RTC...
  Done :-)
<2025-05-30 12:02:30> Done :-)
[2025-05-30 12:02:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 12:02:30] Pending for incoming shutdown command...
[2025-05-30 12:02:30] Schedule next shutdown at: 2025-05-30 12:10:00
[2025-05-30 12:02:30] Schedule next startup at: 2025-05-30 12:20:00
[2025-05-30 12:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 12:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 12:20:17] Done :-)
[2025-05-30 12:20:17] Firmware ID: 0x37
[2025-05-30 12:20:17] Firmware Revison: 0x07
[2025-05-30 12:20:17] Current Vout=5.2V, Iout=0.45A
[2025-05-30 12:20:17] System starts up because power supply is newly connected.
[2025-05-30 12:22:22] Applying network time to system...
  Done :-)
[2025-05-30 12:22:25] Done :-)
[2025-05-30 12:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 12:22:25> Done :-)
[2025-05-30 12:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 12:22:25] Pending for incoming shutdown command...
[2025-05-30 12:22:25] Schedule next shutdown at: 2025-05-30 12:30:00
[2025-05-30 12:22:25] Schedule next startup at: 2025-05-30 12:40:00
[2025-05-30 12:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 12:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 12:40:17] Done :-)
[2025-05-30 12:40:17] Firmware ID: 0x37
[2025-05-30 12:40:17] Firmware Revison: 0x07
[2025-05-30 12:40:17] Current Vout=5.34V, Iout=0.38A
[2025-05-30 12:40:17] System starts up because power supply is newly connected.
[2025-05-30 12:42:23] Applying network time to system...
  Done :-)
[2025-05-30 12:42:26] Done :-)
[2025-05-30 12:42:26] Writing system time to RTC...
  Done :-)
<2025-05-30 12:42:26> Done :-)
[2025-05-30 12:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 12:42:26] Pending for incoming shutdown command...
[2025-05-30 12:42:26] Schedule next shutdown at: 2025-05-30 12:50:00
[2025-05-30 12:42:26] Schedule next startup at: 2025-05-30 13:00:00
[2025-05-30 12:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 12:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 13:00:17] Done :-)
[2025-05-30 13:00:17] Firmware ID: 0x37
[2025-05-30 13:00:17] Firmware Revison: 0x07
[2025-05-30 13:00:17] Current Vout=5.2V, Iout=0.58A
[2025-05-30 13:00:17] System starts up because power supply is newly connected.
[2025-05-30 13:02:28] Applying network time to system...
  Done :-)
[2025-05-30 13:02:29] Done :-)
[2025-05-30 13:02:29] Writing system time to RTC...
  Done :-)
<2025-05-30 13:02:29> Done :-)
[2025-05-30 13:02:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 13:02:29] Pending for incoming shutdown command...
[2025-05-30 13:02:29] Schedule next shutdown at: 2025-05-30 13:10:00
[2025-05-30 13:02:29] Schedule next startup at: 2025-05-30 13:20:00
[2025-05-30 13:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 13:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 13:20:17] Done :-)
[2025-05-30 13:20:17] Firmware ID: 0x37
[2025-05-30 13:20:17] Firmware Revison: 0x07
[2025-05-30 13:20:17] Current Vout=5.28V, Iout=0.4A
[2025-05-30 13:20:17] System starts up because power supply is newly connected.
[2025-05-30 13:22:22] Applying network time to system...
  Done :-)
[2025-05-30 13:22:25] Done :-)
[2025-05-30 13:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 13:22:25> Done :-)
[2025-05-30 13:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 13:22:25] Pending for incoming shutdown command...
[2025-05-30 13:22:25] Schedule next shutdown at: 2025-05-30 13:30:00
[2025-05-30 13:22:25] Schedule next startup at: 2025-05-30 13:40:00
[2025-05-30 13:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 13:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 13:40:17] Done :-)
[2025-05-30 13:40:17] Firmware ID: 0x37
[2025-05-30 13:40:17] Firmware Revison: 0x07
[2025-05-30 13:40:17] Current Vout=5.2V, Iout=0.38A
[2025-05-30 13:40:17] System starts up because power supply is newly connected.
[2025-05-30 13:42:23] Applying network time to system...
  Done :-)
[2025-05-30 13:42:24] Done :-)
[2025-05-30 13:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 13:42:24> Done :-)
[2025-05-30 13:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 13:42:24] Pending for incoming shutdown command...
[2025-05-30 13:42:24] Schedule next shutdown at: 2025-05-30 13:50:00
[2025-05-30 13:42:24] Schedule next startup at: 2025-05-30 14:00:00
[2025-05-30 13:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 13:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 14:00:18] Done :-)
[2025-05-30 14:00:18] Firmware ID: 0x37
[2025-05-30 14:00:18] Firmware Revison: 0x07
[2025-05-30 14:00:18] Current Vout=5.19V, Iout=0.55A
[2025-05-30 14:00:18] System starts up because power supply is newly connected.
[2025-05-30 14:02:24] Applying network time to system...
  Done :-)
[2025-05-30 14:02:25] Done :-)
[2025-05-30 14:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 14:02:25> Done :-)
[2025-05-30 14:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 14:02:25] Pending for incoming shutdown command...
[2025-05-30 14:02:25] Schedule next shutdown at: 2025-05-30 14:10:00
[2025-05-30 14:02:25] Schedule next startup at: 2025-05-30 14:20:00
[2025-05-30 14:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 14:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 14:20:17] Done :-)
[2025-05-30 14:20:17] Firmware ID: 0x37
[2025-05-30 14:20:17] Firmware Revison: 0x07
[2025-05-30 14:20:17] Current Vout=5.2V, Iout=0.32A
[2025-05-30 14:20:17] System starts up because power supply is newly connected.
[2025-05-30 14:22:27] Applying network time to system...
  Done :-)
[2025-05-30 14:22:29] Done :-)
[2025-05-30 14:22:29] Writing system time to RTC...
  Done :-)
<2025-05-30 14:22:29> Done :-)
[2025-05-30 14:22:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 14:22:29] Pending for incoming shutdown command...
[2025-05-30 14:22:29] Schedule next shutdown at: 2025-05-30 14:30:00
[2025-05-30 14:22:29] Schedule next startup at: 2025-05-30 14:40:00
[2025-05-30 14:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 14:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 14:40:17] Done :-)
[2025-05-30 14:40:17] Firmware ID: 0x37
[2025-05-30 14:40:17] Firmware Revison: 0x07
[2025-05-30 14:40:17] Current Vout=5.2V, Iout=0.45A
[2025-05-30 14:40:17] System starts up because power supply is newly connected.
[2025-05-30 14:42:22] Applying network time to system...
  Done :-)
[2025-05-30 14:42:24] Done :-)
[2025-05-30 14:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 14:42:24> Done :-)
[2025-05-30 14:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 14:42:24] Pending for incoming shutdown command...
[2025-05-30 14:42:24] Schedule next shutdown at: 2025-05-30 14:50:00
[2025-05-30 14:42:24] Schedule next startup at: 2025-05-30 15:00:00
[2025-05-30 14:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 14:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 15:00:17] Done :-)
[2025-05-30 15:00:17] Firmware ID: 0x37
[2025-05-30 15:00:17] Firmware Revison: 0x07
[2025-05-30 15:00:17] Current Vout=5.26V, Iout=0.45A
[2025-05-30 15:00:17] System starts up because power supply is newly connected.
[2025-05-30 15:02:22] Applying network time to system...
  Done :-)
[2025-05-30 15:02:24] Done :-)
[2025-05-30 15:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 15:02:24> Done :-)
[2025-05-30 15:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 15:02:24] Pending for incoming shutdown command...
[2025-05-30 15:02:24] Schedule next shutdown at: 2025-05-30 15:10:00
[2025-05-30 15:02:24] Schedule next startup at: 2025-05-30 15:20:00
[2025-05-30 15:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 15:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 15:20:17] Done :-)
[2025-05-30 15:20:17] Firmware ID: 0x37
[2025-05-30 15:20:17] Firmware Revison: 0x07
[2025-05-30 15:20:17] Current Vout=5.19V, Iout=0.45A
[2025-05-30 15:20:17] System starts up because power supply is newly connected.
[2025-05-30 15:22:22] Applying network time to system...
  Done :-)
[2025-05-30 15:22:25] Done :-)
[2025-05-30 15:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 15:22:25> Done :-)
[2025-05-30 15:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 15:22:25] Pending for incoming shutdown command...
[2025-05-30 15:22:25] Schedule next shutdown at: 2025-05-30 15:30:00
[2025-05-30 15:22:25] Schedule next startup at: 2025-05-30 15:40:00
[2025-05-30 15:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 15:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 15:40:18] Done :-)
[2025-05-30 15:40:18] Firmware ID: 0x37
[2025-05-30 15:40:18] Firmware Revison: 0x07
[2025-05-30 15:40:18] Current Vout=5.2V, Iout=0.3A
[2025-05-30 15:40:18] System starts up because power supply is newly connected.
[2025-05-30 15:42:23] Applying network time to system...
  Done :-)
[2025-05-30 15:42:25] Done :-)
[2025-05-30 15:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 15:42:25> Done :-)
[2025-05-30 15:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 15:42:25] Pending for incoming shutdown command...
[2025-05-30 15:42:25] Schedule next shutdown at: 2025-05-30 15:50:00
[2025-05-30 15:42:25] Schedule next startup at: 2025-05-30 16:00:00
[2025-05-30 15:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 15:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 16:00:17] Done :-)
[2025-05-30 16:00:17] Firmware ID: 0x37
[2025-05-30 16:00:17] Firmware Revison: 0x07
[2025-05-30 16:00:17] Current Vout=5.19V, Iout=0.4A
[2025-05-30 16:00:17] System starts up because power supply is newly connected.
[2025-05-30 16:02:22] Applying network time to system...
  Done :-)
[2025-05-30 16:02:25] Done :-)
[2025-05-30 16:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 16:02:25> Done :-)
[2025-05-30 16:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 16:02:25] Pending for incoming shutdown command...
[2025-05-30 16:02:25] Schedule next shutdown at: 2025-05-30 16:10:00
[2025-05-30 16:02:25] Schedule next startup at: 2025-05-30 16:20:00
[2025-05-30 16:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 16:10:01] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 16:20:17] Done :-)
[2025-05-30 16:20:17] Firmware ID: 0x37
[2025-05-30 16:20:17] Firmware Revison: 0x07
[2025-05-30 16:20:17] Current Vout=5.19V, Iout=0.6A
[2025-05-30 16:20:17] System starts up because power supply is newly connected.
[2025-05-30 16:22:23] Applying network time to system...
  Done :-)
[2025-05-30 16:22:24] Done :-)
[2025-05-30 16:22:24] Writing system time to RTC...
  Done :-)
<2025-05-30 16:22:24> Done :-)
[2025-05-30 16:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 16:22:24] Pending for incoming shutdown command...
[2025-05-30 16:22:24] Schedule next shutdown at: 2025-05-30 16:30:00
[2025-05-30 16:22:24] Schedule next startup at: 2025-05-30 16:40:00
[2025-05-30 16:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 16:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 16:40:17] Done :-)
[2025-05-30 16:40:17] Firmware ID: 0x37
[2025-05-30 16:40:17] Firmware Revison: 0x07
[2025-05-30 16:40:17] Current Vout=5.21V, Iout=0.3A
[2025-05-30 16:40:17] System starts up because power supply is newly connected.
[2025-05-30 16:42:22] Applying network time to system...
  Done :-)
[2025-05-30 16:42:24] Done :-)
[2025-05-30 16:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 16:42:24> Done :-)
[2025-05-30 16:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 16:42:24] Pending for incoming shutdown command...
[2025-05-30 16:42:24] Schedule next shutdown at: 2025-05-30 16:50:00
[2025-05-30 16:42:24] Schedule next startup at: 2025-05-30 17:00:00
[2025-05-30 16:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 16:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 17:00:17] Done :-)
[2025-05-30 17:00:17] Firmware ID: 0x37
[2025-05-30 17:00:17] Firmware Revison: 0x07
[2025-05-30 17:00:17] Current Vout=5.2V, Iout=0.38A
[2025-05-30 17:00:17] System starts up because power supply is newly connected.
[2025-05-30 17:02:23] Applying network time to system...
  Done :-)
[2025-05-30 17:02:25] Done :-)
[2025-05-30 17:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 17:02:25> Done :-)
[2025-05-30 17:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 17:02:25] Pending for incoming shutdown command...
[2025-05-30 17:02:25] Schedule next shutdown at: 2025-05-30 17:10:00
[2025-05-30 17:02:25] Schedule next startup at: 2025-05-30 17:20:00
[2025-05-30 17:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 17:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 17:20:17] Done :-)
[2025-05-30 17:20:17] Firmware ID: 0x37
[2025-05-30 17:20:17] Firmware Revison: 0x07
[2025-05-30 17:20:17] Current Vout=5.19V, Iout=0.58A
[2025-05-30 17:20:17] System starts up because power supply is newly connected.
[2025-05-30 17:22:22] Applying network time to system...
  Done :-)
[2025-05-30 17:22:24] Done :-)
[2025-05-30 17:22:24] Writing system time to RTC...
  Done :-)
<2025-05-30 17:22:24> Done :-)
[2025-05-30 17:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 17:22:24] Pending for incoming shutdown command...
[2025-05-30 17:22:24] Schedule next shutdown at: 2025-05-30 17:30:00
[2025-05-30 17:22:24] Schedule next startup at: 2025-05-30 17:40:00
[2025-05-30 17:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 17:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 17:40:17] Done :-)
[2025-05-30 17:40:17] Firmware ID: 0x37
[2025-05-30 17:40:17] Firmware Revison: 0x07
[2025-05-30 17:40:17] Current Vout=5.34V, Iout=0.34A
[2025-05-30 17:40:17] System starts up because power supply is newly connected.
[2025-05-30 17:42:22] Applying network time to system...
  Done :-)
[2025-05-30 17:42:25] Done :-)
[2025-05-30 17:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 17:42:25> Done :-)
[2025-05-30 17:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 17:42:25] Pending for incoming shutdown command...
[2025-05-30 17:42:25] Schedule next shutdown at: 2025-05-30 17:50:00
[2025-05-30 17:42:25] Schedule next startup at: 2025-05-30 18:00:00
[2025-05-30 17:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 17:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 18:00:18] Done :-)
[2025-05-30 18:00:18] Firmware ID: 0x37
[2025-05-30 18:00:18] Firmware Revison: 0x07
[2025-05-30 18:00:18] Current Vout=5.19V, Iout=0.62A
[2025-05-30 18:00:18] System starts up because power supply is newly connected.
[2025-05-30 18:02:24] Applying network time to system...
  Done :-)
[2025-05-30 18:02:24] Done :-)
[2025-05-30 18:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 18:02:24> Done :-)
[2025-05-30 18:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 18:02:24] Pending for incoming shutdown command...
[2025-05-30 18:02:24] Schedule next shutdown at: 2025-05-30 18:10:00
[2025-05-30 18:02:24] Schedule next startup at: 2025-05-30 18:20:00
[2025-05-30 18:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 18:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 18:20:17] Done :-)
[2025-05-30 18:20:17] Firmware ID: 0x37
[2025-05-30 18:20:17] Firmware Revison: 0x07
[2025-05-30 18:20:17] Current Vout=5.2V, Iout=0.36A
[2025-05-30 18:20:17] System starts up because power supply is newly connected.
[2025-05-30 18:22:22] Applying network time to system...
  Done :-)
[2025-05-30 18:22:24] Done :-)
[2025-05-30 18:22:24] Writing system time to RTC...
  Done :-)
<2025-05-30 18:22:24> Done :-)
[2025-05-30 18:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 18:22:24] Pending for incoming shutdown command...
[2025-05-30 18:22:24] Schedule next shutdown at: 2025-05-30 18:30:00
[2025-05-30 18:22:24] Schedule next startup at: 2025-05-30 18:40:00
[2025-05-30 18:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 18:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 18:40:17] Done :-)
[2025-05-30 18:40:17] Firmware ID: 0x37
[2025-05-30 18:40:17] Firmware Revison: 0x07
[2025-05-30 18:40:17] Current Vout=5.2V, Iout=0.51A
[2025-05-30 18:40:17] System starts up because power supply is newly connected.
[2025-05-30 18:42:22] Applying network time to system...
  Done :-)
[2025-05-30 18:42:25] Done :-)
[2025-05-30 18:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 18:42:25> Done :-)
[2025-05-30 18:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 18:42:25] Pending for incoming shutdown command...
[2025-05-30 18:42:25] Schedule next shutdown at: 2025-05-30 18:50:00
[2025-05-30 18:42:25] Schedule next startup at: 2025-05-30 19:00:00
[2025-05-30 18:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 18:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 19:00:17] Done :-)
[2025-05-30 19:00:17] Firmware ID: 0x37
[2025-05-30 19:00:17] Firmware Revison: 0x07
[2025-05-30 19:00:17] Current Vout=5.2V, Iout=0.32A
[2025-05-30 19:00:17] System starts up because power supply is newly connected.
[2025-05-30 19:02:22] Applying network time to system...
  Done :-)
[2025-05-30 19:02:24] Done :-)
[2025-05-30 19:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 19:02:24> Done :-)
[2025-05-30 19:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 19:02:24] Pending for incoming shutdown command...
[2025-05-30 19:02:24] Schedule next shutdown at: 2025-05-30 19:10:00
[2025-05-30 19:02:25] Schedule next startup at: 2025-05-30 19:20:00
[2025-05-30 19:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 19:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 19:20:17] Done :-)
[2025-05-30 19:20:17] Firmware ID: 0x37
[2025-05-30 19:20:17] Firmware Revison: 0x07
[2025-05-30 19:20:17] Current Vout=5.19V, Iout=0.15A
[2025-05-30 19:20:17] System starts up because power supply is newly connected.
[2025-05-30 19:22:22] Applying network time to system...
  Done :-)
[2025-05-30 19:22:25] Done :-)
[2025-05-30 19:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 19:22:25> Done :-)
[2025-05-30 19:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 19:22:25] Pending for incoming shutdown command...
[2025-05-30 19:22:25] Schedule next shutdown at: 2025-05-30 19:30:00
[2025-05-30 19:22:25] Schedule next startup at: 2025-05-30 19:40:00
[2025-05-30 19:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 19:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 19:40:17] Done :-)
[2025-05-30 19:40:17] Firmware ID: 0x37
[2025-05-30 19:40:17] Firmware Revison: 0x07
[2025-05-30 19:40:17] Current Vout=5.19V, Iout=0.62A
[2025-05-30 19:40:17] System starts up because power supply is newly connected.
[2025-05-30 19:42:22] Applying network time to system...
  Done :-)
[2025-05-30 19:42:24] Done :-)
[2025-05-30 19:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 19:42:24> Done :-)
[2025-05-30 19:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 19:42:24] Pending for incoming shutdown command...
[2025-05-30 19:42:24] Schedule next shutdown at: 2025-05-30 19:50:00
[2025-05-30 19:42:24] Schedule next startup at: 2025-05-30 20:00:00
[2025-05-30 19:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 19:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 20:00:17] Done :-)
[2025-05-30 20:00:17] Firmware ID: 0x37
[2025-05-30 20:00:17] Firmware Revison: 0x07
[2025-05-30 20:00:17] Current Vout=5.12V, Iout=0.55A
[2025-05-30 20:00:17] System starts up because power supply is newly connected.
[2025-05-30 20:02:22] Applying network time to system...
  Done :-)
[2025-05-30 20:02:25] Done :-)
[2025-05-30 20:02:25] Writing system time to RTC...
  Done :-)
<2025-05-30 20:02:25> Done :-)
[2025-05-30 20:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 20:02:25] Pending for incoming shutdown command...
[2025-05-30 20:02:25] Schedule next shutdown at: 2025-05-30 20:10:00
[2025-05-30 20:02:25] Schedule next startup at: 2025-05-30 20:20:00
[2025-05-30 20:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 20:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 20:20:17] Done :-)
[2025-05-30 20:20:17] Firmware ID: 0x37
[2025-05-30 20:20:17] Firmware Revison: 0x07
[2025-05-30 20:20:17] Current Vout=5.19V, Iout=0.32A
[2025-05-30 20:20:17] System starts up because power supply is newly connected.
[2025-05-30 20:22:22] Applying network time to system...
  Done :-)
[2025-05-30 20:22:24] Done :-)
[2025-05-30 20:22:24] Writing system time to RTC...
  Done :-)
<2025-05-30 20:22:24> Done :-)
[2025-05-30 20:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 20:22:24] Pending for incoming shutdown command...
[2025-05-30 20:22:24] Schedule next shutdown at: 2025-05-30 20:30:00
[2025-05-30 20:22:24] Schedule next startup at: 2025-05-30 20:40:00
[2025-05-30 20:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 20:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 20:40:17] Done :-)
[2025-05-30 20:40:17] Firmware ID: 0x37
[2025-05-30 20:40:17] Firmware Revison: 0x07
[2025-05-30 20:40:17] Current Vout=5.25V, Iout=0.1A
[2025-05-30 20:40:17] System starts up because power supply is newly connected.
[2025-05-30 20:42:22] Applying network time to system...
  Done :-)
[2025-05-30 20:42:24] Done :-)
[2025-05-30 20:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 20:42:24> Done :-)
[2025-05-30 20:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 20:42:24] Pending for incoming shutdown command...
[2025-05-30 20:42:24] Schedule next shutdown at: 2025-05-30 20:50:00
[2025-05-30 20:42:24] Schedule next startup at: 2025-05-30 21:00:00
[2025-05-30 20:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 20:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 21:00:17] Done :-)
[2025-05-30 21:00:17] Firmware ID: 0x37
[2025-05-30 21:00:17] Firmware Revison: 0x07
[2025-05-30 21:00:17] Current Vout=5.2V, Iout=0.49A
[2025-05-30 21:00:17] System starts up because power supply is newly connected.
[2025-05-30 21:02:23] Applying network time to system...
  Done :-)
[2025-05-30 21:02:24] Done :-)
[2025-05-30 21:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 21:02:24> Done :-)
[2025-05-30 21:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 21:02:24] Pending for incoming shutdown command...
[2025-05-30 21:02:24] Schedule next shutdown at: 2025-05-30 21:10:00
[2025-05-30 21:02:25] Schedule next startup at: 2025-05-30 21:20:00
[2025-05-30 21:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 21:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 21:20:17] Done :-)
[2025-05-30 21:20:17] Firmware ID: 0x37
[2025-05-30 21:20:17] Firmware Revison: 0x07
[2025-05-30 21:20:17] Current Vout=5.28V, Iout=0.45A
[2025-05-30 21:20:17] System starts up because power supply is newly connected.
[2025-05-30 21:22:22] Applying network time to system...
  Done :-)
[2025-05-30 21:22:25] Done :-)
[2025-05-30 21:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 21:22:25> Done :-)
[2025-05-30 21:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 21:22:25] Pending for incoming shutdown command...
[2025-05-30 21:22:25] Schedule next shutdown at: 2025-05-30 21:30:00
[2025-05-30 21:22:25] Schedule next startup at: 2025-05-30 21:40:00
[2025-05-30 21:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 21:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 21:40:17] Done :-)
[2025-05-30 21:40:17] Firmware ID: 0x37
[2025-05-30 21:40:17] Firmware Revison: 0x07
[2025-05-30 21:40:17] Current Vout=5.19V, Iout=0.45A
[2025-05-30 21:40:17] System starts up because power supply is newly connected.
[2025-05-30 21:42:22] Applying network time to system...
  Done :-)
[2025-05-30 21:42:25] Done :-)
[2025-05-30 21:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 21:42:25> Done :-)
[2025-05-30 21:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 21:42:25] Pending for incoming shutdown command...
[2025-05-30 21:42:25] Schedule next shutdown at: 2025-05-30 21:50:00
[2025-05-30 21:42:25] Schedule next startup at: 2025-05-30 22:00:00
[2025-05-30 21:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 21:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 22:00:17] Done :-)
[2025-05-30 22:00:17] Firmware ID: 0x37
[2025-05-30 22:00:17] Firmware Revison: 0x07
[2025-05-30 22:00:17] Current Vout=5.19V, Iout=0.49A
[2025-05-30 22:00:17] System starts up because power supply is newly connected.
[2025-05-30 22:02:23] Applying network time to system...
  Done :-)
[2025-05-30 22:02:24] Done :-)
[2025-05-30 22:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 22:02:24> Done :-)
[2025-05-30 22:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 22:02:24] Pending for incoming shutdown command...
[2025-05-30 22:02:24] Schedule next shutdown at: 2025-05-30 22:10:00
[2025-05-30 22:02:24] Schedule next startup at: 2025-05-30 22:20:00
[2025-05-30 22:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 22:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 22:20:17] Done :-)
[2025-05-30 22:20:17] Firmware ID: 0x37
[2025-05-30 22:20:17] Firmware Revison: 0x07
[2025-05-30 22:20:17] Current Vout=5.19V, Iout=0.38A
[2025-05-30 22:20:17] System starts up because power supply is newly connected.
[2025-05-30 22:22:23] Applying network time to system...
  Done :-)
[2025-05-30 22:22:25] Done :-)
[2025-05-30 22:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 22:22:25> Done :-)
[2025-05-30 22:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 22:22:25] Pending for incoming shutdown command...
[2025-05-30 22:22:25] Schedule next shutdown at: 2025-05-30 22:30:00
[2025-05-30 22:22:25] Schedule next startup at: 2025-05-30 22:40:00
[2025-05-30 22:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-30 22:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 22:40:18] Done :-)
[2025-05-30 22:40:18] Firmware ID: 0x37
[2025-05-30 22:40:18] Firmware Revison: 0x07
[2025-05-30 22:40:18] Current Vout=5.14V, Iout=0.34A
[2025-05-30 22:40:18] System starts up because power supply is newly connected.
[2025-05-30 22:42:23] Applying network time to system...
  Done :-)
[2025-05-30 22:42:25] Done :-)
[2025-05-30 22:42:25] Writing system time to RTC...
  Done :-)
<2025-05-30 22:42:25> Done :-)
[2025-05-30 22:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 22:42:25] Pending for incoming shutdown command...
[2025-05-30 22:42:25] Schedule next shutdown at: 2025-05-30 22:50:00
[2025-05-30 22:42:25] Schedule next startup at: 2025-05-30 23:00:00
[2025-05-30 22:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 22:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 23:00:17] Done :-)
[2025-05-30 23:00:17] Firmware ID: 0x37
[2025-05-30 23:00:17] Firmware Revison: 0x07
[2025-05-30 23:00:17] Current Vout=5.27V, Iout=0.4A
[2025-05-30 23:00:17] System starts up because power supply is newly connected.
[2025-05-30 23:02:22] Applying network time to system...
  Done :-)
[2025-05-30 23:02:24] Done :-)
[2025-05-30 23:02:24] Writing system time to RTC...
  Done :-)
<2025-05-30 23:02:24> Done :-)
[2025-05-30 23:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 23:02:24] Pending for incoming shutdown command...
[2025-05-30 23:02:24] Schedule next shutdown at: 2025-05-30 23:10:00
[2025-05-30 23:02:24] Schedule next startup at: 2025-05-30 23:20:00
[2025-05-30 23:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 23:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 23:20:18] Done :-)
[2025-05-30 23:20:18] Firmware ID: 0x37
[2025-05-30 23:20:18] Firmware Revison: 0x07
[2025-05-30 23:20:18] Current Vout=5.19V, Iout=0.47A
[2025-05-30 23:20:18] System starts up because power supply is newly connected.
[2025-05-30 23:22:24] Applying network time to system...
  Done :-)
[2025-05-30 23:22:25] Done :-)
[2025-05-30 23:22:25] Writing system time to RTC...
  Done :-)
<2025-05-30 23:22:25> Done :-)
[2025-05-30 23:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 23:22:25] Pending for incoming shutdown command...
[2025-05-30 23:22:25] Schedule next shutdown at: 2025-05-30 23:30:00
[2025-05-30 23:22:25] Schedule next startup at: 2025-05-30 23:40:00
[2025-05-30 23:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 23:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-30 23:40:17] Done :-)
[2025-05-30 23:40:17] Firmware ID: 0x37
[2025-05-30 23:40:17] Firmware Revison: 0x07
[2025-05-30 23:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-30 23:40:17] System starts up because power supply is newly connected.
[2025-05-30 23:42:23] Applying network time to system...
  Done :-)
[2025-05-30 23:42:24] Done :-)
[2025-05-30 23:42:24] Writing system time to RTC...
  Done :-)
<2025-05-30 23:42:24> Done :-)
[2025-05-30 23:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-30 23:42:24] Pending for incoming shutdown command...
[2025-05-30 23:42:24] Schedule next shutdown at: 2025-05-30 23:50:00
[2025-05-30 23:42:24] Schedule next startup at: 2025-05-31 00:00:00
[2025-05-30 23:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-30 23:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 00:00:18] Done :-)
[2025-05-31 00:00:18] Firmware ID: 0x37
[2025-05-31 00:00:18] Firmware Revison: 0x07
[2025-05-31 00:00:18] Current Vout=5.19V, Iout=0.6A
[2025-05-31 00:00:18] System starts up because power supply is newly connected.
[2025-05-31 00:02:24] Applying network time to system...
  Done :-)
[2025-05-31 00:02:25] Done :-)
[2025-05-31 00:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 00:02:25> Done :-)
[2025-05-31 00:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 00:02:25] Pending for incoming shutdown command...
[2025-05-31 00:02:25] Schedule next shutdown at: 2025-05-31 00:10:00
[2025-05-31 00:02:25] Schedule next startup at: 2025-05-31 00:20:00
[2025-05-31 00:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 00:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 00:20:17] Done :-)
[2025-05-31 00:20:17] Firmware ID: 0x37
[2025-05-31 00:20:17] Firmware Revison: 0x07
[2025-05-31 00:20:17] Current Vout=5.2V, Iout=0.55A
[2025-05-31 00:20:17] System starts up because power supply is newly connected.
[2025-05-31 00:22:23] Applying network time to system...
  Done :-)
[2025-05-31 00:22:24] Done :-)
[2025-05-31 00:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 00:22:24> Done :-)
[2025-05-31 00:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 00:22:24] Pending for incoming shutdown command...
[2025-05-31 00:22:24] Schedule next shutdown at: 2025-05-31 00:30:00
[2025-05-31 00:22:24] Schedule next startup at: 2025-05-31 00:40:00
[2025-05-31 00:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 00:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 00:40:17] Done :-)
[2025-05-31 00:40:17] Firmware ID: 0x37
[2025-05-31 00:40:17] Firmware Revison: 0x07
[2025-05-31 00:40:17] Current Vout=5.19V, Iout=0.4A
[2025-05-31 00:40:17] System starts up because power supply is newly connected.
[2025-05-31 00:42:23] Applying network time to system...
  Done :-)
[2025-05-31 00:42:24] Done :-)
[2025-05-31 00:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 00:42:24> Done :-)
[2025-05-31 00:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 00:42:24] Pending for incoming shutdown command...
[2025-05-31 00:42:24] Schedule next shutdown at: 2025-05-31 00:50:00
[2025-05-31 00:42:24] Schedule next startup at: 2025-05-31 01:00:00
[2025-05-31 00:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 00:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 01:00:17] Done :-)
[2025-05-31 01:00:17] Firmware ID: 0x37
[2025-05-31 01:00:17] Firmware Revison: 0x07
[2025-05-31 01:00:17] Current Vout=5.19V, Iout=0.55A
[2025-05-31 01:00:17] System starts up because power supply is newly connected.
[2025-05-31 01:02:22] Applying network time to system...
  Done :-)
[2025-05-31 01:02:26] Done :-)
[2025-05-31 01:02:26] Writing system time to RTC...
  Done :-)
<2025-05-31 01:02:26> Done :-)
[2025-05-31 01:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 01:02:26] Pending for incoming shutdown command...
[2025-05-31 01:02:26] Schedule next shutdown at: 2025-05-31 01:10:00
[2025-05-31 01:02:26] Schedule next startup at: 2025-05-31 01:20:00
[2025-05-31 01:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 01:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 01:20:17] Done :-)
[2025-05-31 01:20:17] Firmware ID: 0x37
[2025-05-31 01:20:17] Firmware Revison: 0x07
[2025-05-31 01:20:17] Current Vout=5.26V, Iout=0.62A
[2025-05-31 01:20:17] System starts up because power supply is newly connected.
[2025-05-31 01:22:22] Applying network time to system...
  Done :-)
[2025-05-31 01:22:24] Done :-)
[2025-05-31 01:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 01:22:24> Done :-)
[2025-05-31 01:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 01:22:24] Pending for incoming shutdown command...
[2025-05-31 01:22:24] Schedule next shutdown at: 2025-05-31 01:30:00
[2025-05-31 01:22:24] Schedule next startup at: 2025-05-31 01:40:00
[2025-05-31 01:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 01:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 01:40:17] Done :-)
[2025-05-31 01:40:17] Firmware ID: 0x37
[2025-05-31 01:40:17] Firmware Revison: 0x07
[2025-05-31 01:40:17] Current Vout=5.19V, Iout=0.38A
[2025-05-31 01:40:17] System starts up because power supply is newly connected.
[2025-05-31 01:42:22] Applying network time to system...
  Done :-)
[2025-05-31 01:42:24] Done :-)
[2025-05-31 01:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 01:42:24> Done :-)
[2025-05-31 01:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 01:42:24] Pending for incoming shutdown command...
[2025-05-31 01:42:24] Schedule next shutdown at: 2025-05-31 01:50:00
[2025-05-31 01:42:24] Schedule next startup at: 2025-05-31 02:00:00
[2025-05-31 01:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 01:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 02:00:17] Done :-)
[2025-05-31 02:00:17] Firmware ID: 0x37
[2025-05-31 02:00:17] Firmware Revison: 0x07
[2025-05-31 02:00:17] Current Vout=5.19V, Iout=0.45A
[2025-05-31 02:00:17] System starts up because power supply is newly connected.
[2025-05-31 02:02:23] Applying network time to system...
  Done :-)
[2025-05-31 02:02:25] Done :-)
[2025-05-31 02:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 02:02:25> Done :-)
[2025-05-31 02:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 02:02:25] Pending for incoming shutdown command...
[2025-05-31 02:02:25] Schedule next shutdown at: 2025-05-31 02:10:00
[2025-05-31 02:02:25] Schedule next startup at: 2025-05-31 02:20:00
[2025-05-31 02:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 02:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 02:20:17] Done :-)
[2025-05-31 02:20:17] Firmware ID: 0x37
[2025-05-31 02:20:17] Firmware Revison: 0x07
[2025-05-31 02:20:17] Current Vout=5.2V, Iout=0.43A
[2025-05-31 02:20:17] System starts up because power supply is newly connected.
[2025-05-31 02:22:22] Applying network time to system...
  Done :-)
[2025-05-31 02:22:25] Done :-)
[2025-05-31 02:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 02:22:25> Done :-)
[2025-05-31 02:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 02:22:25] Pending for incoming shutdown command...
[2025-05-31 02:22:25] Schedule next shutdown at: 2025-05-31 02:30:00
[2025-05-31 02:22:25] Schedule next startup at: 2025-05-31 02:40:00
[2025-05-31 02:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 02:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 02:40:18] Done :-)
[2025-05-31 02:40:18] Firmware ID: 0x37
[2025-05-31 02:40:18] Firmware Revison: 0x07
[2025-05-31 02:40:18] Current Vout=5.19V, Iout=0.53A
[2025-05-31 02:40:18] System starts up because power supply is newly connected.
[2025-05-31 02:42:23] Applying network time to system...
  Done :-)
[2025-05-31 02:42:25] Done :-)
[2025-05-31 02:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 02:42:25> Done :-)
[2025-05-31 02:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 02:42:25] Pending for incoming shutdown command...
[2025-05-31 02:42:25] Schedule next shutdown at: 2025-05-31 02:50:00
[2025-05-31 02:42:25] Schedule next startup at: 2025-05-31 03:00:00
[2025-05-31 02:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 02:50:00] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-05-31 03:00:18] Done :-)
[2025-05-31 03:00:18] Firmware ID: 0x37
[2025-05-31 03:00:18] Firmware Revison: 0x07
[2025-05-31 03:00:18] Current Vout=5.26V, Iout=0.36A
[2025-05-31 03:00:18] System starts up because power supply is newly connected.
[2025-05-31 03:02:23] Applying network time to system...
  Done :-)
[2025-05-31 03:02:25] Done :-)
[2025-05-31 03:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 03:02:25> Done :-)
[2025-05-31 03:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 03:02:25] Pending for incoming shutdown command...
[2025-05-31 03:02:25] Schedule next shutdown at: 2025-05-31 03:10:00
[2025-05-31 03:02:25] Schedule next startup at: 2025-05-31 03:20:00
[2025-05-31 03:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 03:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 03:20:17] Done :-)
[2025-05-31 03:20:17] Firmware ID: 0x37
[2025-05-31 03:20:17] Firmware Revison: 0x07
[2025-05-31 03:20:17] Current Vout=5.19V, Iout=0.58A
[2025-05-31 03:20:17] System starts up because power supply is newly connected.
[2025-05-31 03:22:22] Applying network time to system...
  Done :-)
[2025-05-31 03:22:25] Done :-)
[2025-05-31 03:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 03:22:25> Done :-)
[2025-05-31 03:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 03:22:25] Pending for incoming shutdown command...
[2025-05-31 03:22:25] Schedule next shutdown at: 2025-05-31 03:30:00
[2025-05-31 03:22:25] Schedule next startup at: 2025-05-31 03:40:00
[2025-05-31 03:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 03:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 03:40:18] Done :-)
[2025-05-31 03:40:18] Firmware ID: 0x37
[2025-05-31 03:40:18] Firmware Revison: 0x07
[2025-05-31 03:40:18] Current Vout=5.2V, Iout=0.25A
[2025-05-31 03:40:18] System starts up because power supply is newly connected.
[2025-05-31 03:42:23] Applying network time to system...
  Done :-)
[2025-05-31 03:42:25] Done :-)
[2025-05-31 03:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 03:42:25> Done :-)
[2025-05-31 03:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 03:42:25] Pending for incoming shutdown command...
[2025-05-31 03:42:25] Schedule next shutdown at: 2025-05-31 03:50:00
[2025-05-31 03:42:25] Schedule next startup at: 2025-05-31 04:00:00
[2025-05-31 03:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 03:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 04:00:18] Done :-)
[2025-05-31 04:00:18] Firmware ID: 0x37
[2025-05-31 04:00:18] Firmware Revison: 0x07
[2025-05-31 04:00:18] Current Vout=5.19V, Iout=0.45A
[2025-05-31 04:00:18] System starts up because power supply is newly connected.
[2025-05-31 04:02:23] Applying network time to system...
  Done :-)
[2025-05-31 04:02:25] Done :-)
[2025-05-31 04:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 04:02:25> Done :-)
[2025-05-31 04:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 04:02:25] Pending for incoming shutdown command...
[2025-05-31 04:02:25] Schedule next shutdown at: 2025-05-31 04:10:00
[2025-05-31 04:02:25] Schedule next startup at: 2025-05-31 04:20:00
[2025-05-31 04:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 04:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 04:20:18] Done :-)
[2025-05-31 04:20:18] Firmware ID: 0x37
[2025-05-31 04:20:18] Firmware Revison: 0x07
[2025-05-31 04:20:18] Current Vout=5.19V, Iout=0.51A
[2025-05-31 04:20:18] System starts up because power supply is newly connected.
[2025-05-31 04:22:24] Applying network time to system...
  Done :-)
[2025-05-31 04:22:25] Done :-)
[2025-05-31 04:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 04:22:25> Done :-)
[2025-05-31 04:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 04:22:25] Pending for incoming shutdown command...
[2025-05-31 04:22:25] Schedule next shutdown at: 2025-05-31 04:30:00
[2025-05-31 04:22:25] Schedule next startup at: 2025-05-31 04:40:00
[2025-05-31 04:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 04:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 04:40:17] Done :-)
[2025-05-31 04:40:17] Firmware ID: 0x37
[2025-05-31 04:40:17] Firmware Revison: 0x07
[2025-05-31 04:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-31 04:40:17] System starts up because power supply is newly connected.
[2025-05-31 04:42:22] Applying network time to system...
  Done :-)
[2025-05-31 04:42:25] Done :-)
[2025-05-31 04:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 04:42:25> Done :-)
[2025-05-31 04:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 04:42:25] Pending for incoming shutdown command...
[2025-05-31 04:42:25] Schedule next shutdown at: 2025-05-31 04:50:00
[2025-05-31 04:42:25] Schedule next startup at: 2025-05-31 05:00:00
[2025-05-31 04:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 04:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 05:00:17] Done :-)
[2025-05-31 05:00:17] Firmware ID: 0x37
[2025-05-31 05:00:17] Firmware Revison: 0x07
[2025-05-31 05:00:17] Current Vout=5.2V, Iout=0.32A
[2025-05-31 05:00:17] System starts up because power supply is newly connected.
[2025-05-31 05:02:22] Applying network time to system...
  Done :-)
[2025-05-31 05:02:25] Done :-)
[2025-05-31 05:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 05:02:25> Done :-)
[2025-05-31 05:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 05:02:25] Pending for incoming shutdown command...
[2025-05-31 05:02:25] Schedule next shutdown at: 2025-05-31 05:10:00
[2025-05-31 05:02:25] Schedule next startup at: 2025-05-31 05:20:00
[2025-05-31 05:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 05:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 05:20:17] Done :-)
[2025-05-31 05:20:17] Firmware ID: 0x37
[2025-05-31 05:20:17] Firmware Revison: 0x07
[2025-05-31 05:20:17] Current Vout=5.19V, Iout=0.58A
[2025-05-31 05:20:17] System starts up because power supply is newly connected.
[2025-05-31 05:22:23] Applying network time to system...
  Done :-)
[2025-05-31 05:22:25] Done :-)
[2025-05-31 05:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 05:22:25> Done :-)
[2025-05-31 05:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 05:22:25] Pending for incoming shutdown command...
[2025-05-31 05:22:25] Schedule next shutdown at: 2025-05-31 05:30:00
[2025-05-31 05:22:25] Schedule next startup at: 2025-05-31 05:40:00
[2025-05-31 05:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 05:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 05:40:17] Done :-)
[2025-05-31 05:40:17] Firmware ID: 0x37
[2025-05-31 05:40:17] Firmware Revison: 0x07
[2025-05-31 05:40:17] Current Vout=5.2V, Iout=0.55A
[2025-05-31 05:40:17] System starts up because power supply is newly connected.
[2025-05-31 05:42:22] Applying network time to system...
  Done :-)
[2025-05-31 05:42:25] Done :-)
[2025-05-31 05:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 05:42:25> Done :-)
[2025-05-31 05:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 05:42:25] Pending for incoming shutdown command...
[2025-05-31 05:42:25] Schedule next shutdown at: 2025-05-31 05:50:00
[2025-05-31 05:42:25] Schedule next startup at: 2025-05-31 06:00:00
[2025-05-31 05:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 05:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 06:00:17] Done :-)
[2025-05-31 06:00:17] Firmware ID: 0x37
[2025-05-31 06:00:17] Firmware Revison: 0x07
[2025-05-31 06:00:17] Current Vout=5.19V, Iout=0.62A
[2025-05-31 06:00:17] System starts up because power supply is newly connected.
[2025-05-31 06:02:23] Applying network time to system...
  Done :-)
[2025-05-31 06:02:24] Done :-)
[2025-05-31 06:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 06:02:24> Done :-)
[2025-05-31 06:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 06:02:24] Pending for incoming shutdown command...
[2025-05-31 06:02:24] Schedule next shutdown at: 2025-05-31 06:10:00
[2025-05-31 06:02:24] Schedule next startup at: 2025-05-31 06:20:00
[2025-05-31 06:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 06:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 06:20:17] Done :-)
[2025-05-31 06:20:17] Firmware ID: 0x37
[2025-05-31 06:20:17] Firmware Revison: 0x07
[2025-05-31 06:20:17] Current Vout=5.19V, Iout=0.53A
[2025-05-31 06:20:17] System starts up because power supply is newly connected.
[2025-05-31 06:22:22] Applying network time to system...
  Done :-)
[2025-05-31 06:22:24] Done :-)
[2025-05-31 06:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 06:22:24> Done :-)
[2025-05-31 06:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 06:22:24] Pending for incoming shutdown command...
[2025-05-31 06:22:24] Schedule next shutdown at: 2025-05-31 06:30:00
[2025-05-31 06:22:24] Schedule next startup at: 2025-05-31 06:40:00
[2025-05-31 06:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 06:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 06:40:17] Done :-)
[2025-05-31 06:40:17] Firmware ID: 0x37
[2025-05-31 06:40:17] Firmware Revison: 0x07
[2025-05-31 06:40:17] Current Vout=5.19V, Iout=0.51A
[2025-05-31 06:40:17] System starts up because power supply is newly connected.
[2025-05-31 06:42:23] Applying network time to system...
  Done :-)
[2025-05-31 06:42:24] Done :-)
[2025-05-31 06:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 06:42:24> Done :-)
[2025-05-31 06:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 06:42:24] Pending for incoming shutdown command...
[2025-05-31 06:42:24] Schedule next shutdown at: 2025-05-31 06:50:00
[2025-05-31 06:42:24] Schedule next startup at: 2025-05-31 07:00:00
[2025-05-31 06:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 06:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 07:00:18] Done :-)
[2025-05-31 07:00:18] Firmware ID: 0x37
[2025-05-31 07:00:18] Firmware Revison: 0x07
[2025-05-31 07:00:18] Current Vout=5.19V, Iout=0.6A
[2025-05-31 07:00:18] System starts up because power supply is newly connected.
[2025-05-31 07:02:23] Applying network time to system...
  Done :-)
[2025-05-31 07:02:24] Done :-)
[2025-05-31 07:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 07:02:24> Done :-)
[2025-05-31 07:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 07:02:24] Pending for incoming shutdown command...
[2025-05-31 07:02:24] Schedule next shutdown at: 2025-05-31 07:10:00
[2025-05-31 07:02:24] Schedule next startup at: 2025-05-31 07:20:00
[2025-05-31 07:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 07:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 07:20:17] Done :-)
[2025-05-31 07:20:17] Firmware ID: 0x37
[2025-05-31 07:20:17] Firmware Revison: 0x07
[2025-05-31 07:20:17] Current Vout=5.2V, Iout=0.38A
[2025-05-31 07:20:17] System starts up because power supply is newly connected.
[2025-05-31 07:22:22] Applying network time to system...
  Done :-)
[2025-05-31 07:22:25] Done :-)
[2025-05-31 07:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 07:22:25> Done :-)
[2025-05-31 07:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 07:22:25] Pending for incoming shutdown command...
[2025-05-31 07:22:25] Schedule next shutdown at: 2025-05-31 07:30:00
[2025-05-31 07:22:25] Schedule next startup at: 2025-05-31 07:40:00
[2025-05-31 07:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 07:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 07:40:17] Done :-)
[2025-05-31 07:40:17] Firmware ID: 0x37
[2025-05-31 07:40:17] Firmware Revison: 0x07
[2025-05-31 07:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-31 07:40:17] System starts up because power supply is newly connected.
[2025-05-31 07:42:22] Applying network time to system...
  Done :-)
[2025-05-31 07:42:25] Done :-)
[2025-05-31 07:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 07:42:25> Done :-)
[2025-05-31 07:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 07:42:25] Pending for incoming shutdown command...
[2025-05-31 07:42:25] Schedule next shutdown at: 2025-05-31 07:50:00
[2025-05-31 07:42:25] Schedule next startup at: 2025-05-31 08:00:00
[2025-05-31 07:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 07:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 08:00:17] Done :-)
[2025-05-31 08:00:17] Firmware ID: 0x37
[2025-05-31 08:00:17] Firmware Revison: 0x07
[2025-05-31 08:00:17] Current Vout=5.21V, Iout=0.19A
[2025-05-31 08:00:17] System starts up because power supply is newly connected.
[2025-05-31 08:02:22] Applying network time to system...
  Done :-)
[2025-05-31 08:02:24] Done :-)
[2025-05-31 08:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 08:02:24> Done :-)
[2025-05-31 08:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 08:02:24] Pending for incoming shutdown command...
[2025-05-31 08:02:24] Schedule next shutdown at: 2025-05-31 08:10:00
[2025-05-31 08:02:24] Schedule next startup at: 2025-05-31 08:20:00
[2025-05-31 08:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 08:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 08:20:17] Done :-)
[2025-05-31 08:20:17] Firmware ID: 0x37
[2025-05-31 08:20:17] Firmware Revison: 0x07
[2025-05-31 08:20:17] Current Vout=5.33V, Iout=0.53A
[2025-05-31 08:20:17] System starts up because power supply is newly connected.
[2025-05-31 08:22:22] Applying network time to system...
  Done :-)
[2025-05-31 08:22:25] Done :-)
[2025-05-31 08:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 08:22:25> Done :-)
[2025-05-31 08:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 08:22:25] Pending for incoming shutdown command...
[2025-05-31 08:22:25] Schedule next shutdown at: 2025-05-31 08:30:00
[2025-05-31 08:22:25] Schedule next startup at: 2025-05-31 08:40:00
[2025-05-31 08:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 08:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 08:40:17] Done :-)
[2025-05-31 08:40:17] Firmware ID: 0x37
[2025-05-31 08:40:17] Firmware Revison: 0x07
[2025-05-31 08:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-31 08:40:17] System starts up because power supply is newly connected.
[2025-05-31 08:42:22] Applying network time to system...
  Done :-)
[2025-05-31 08:42:24] Done :-)
[2025-05-31 08:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 08:42:24> Done :-)
[2025-05-31 08:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 08:42:24] Pending for incoming shutdown command...
[2025-05-31 08:42:24] Schedule next shutdown at: 2025-05-31 08:50:00
[2025-05-31 08:42:24] Schedule next startup at: 2025-05-31 09:00:00
[2025-05-31 08:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 08:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 09:00:17] Done :-)
[2025-05-31 09:00:17] Firmware ID: 0x37
[2025-05-31 09:00:17] Firmware Revison: 0x07
[2025-05-31 09:00:17] Current Vout=5.18V, Iout=0.64A
[2025-05-31 09:00:17] System starts up because power supply is newly connected.
[2025-05-31 09:02:23] Applying network time to system...
  Done :-)
[2025-05-31 09:02:25] Done :-)
[2025-05-31 09:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 09:02:25> Done :-)
[2025-05-31 09:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 09:02:25] Pending for incoming shutdown command...
[2025-05-31 09:02:25] Schedule next shutdown at: 2025-05-31 09:10:00
[2025-05-31 09:02:25] Schedule next startup at: 2025-05-31 09:20:00
[2025-05-31 09:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 09:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 09:20:18] Done :-)
[2025-05-31 09:20:18] Firmware ID: 0x37
[2025-05-31 09:20:18] Firmware Revison: 0x07
[2025-05-31 09:20:18] Current Vout=5.2V, Iout=0.45A
[2025-05-31 09:20:18] System starts up because power supply is newly connected.
[2025-05-31 09:22:23] Applying network time to system...
  Done :-)
[2025-05-31 09:22:25] Done :-)
[2025-05-31 09:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 09:22:25> Done :-)
[2025-05-31 09:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 09:22:25] Pending for incoming shutdown command...
[2025-05-31 09:22:25] Schedule next shutdown at: 2025-05-31 09:30:00
[2025-05-31 09:22:25] Schedule next startup at: 2025-05-31 09:40:00
[2025-05-31 09:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 09:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 09:40:17] Done :-)
[2025-05-31 09:40:17] Firmware ID: 0x37
[2025-05-31 09:40:17] Firmware Revison: 0x07
[2025-05-31 09:40:17] Current Vout=5.13V, Iout=0.34A
[2025-05-31 09:40:17] System starts up because power supply is newly connected.
[2025-05-31 09:42:22] Applying network time to system...
  Done :-)
[2025-05-31 09:42:24] Done :-)
[2025-05-31 09:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 09:42:24> Done :-)
[2025-05-31 09:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 09:42:24] Pending for incoming shutdown command...
[2025-05-31 09:42:24] Schedule next shutdown at: 2025-05-31 09:50:00
[2025-05-31 09:42:24] Schedule next startup at: 2025-05-31 10:00:00
[2025-05-31 09:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 09:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 10:00:17] Done :-)
[2025-05-31 10:00:17] Firmware ID: 0x37
[2025-05-31 10:00:17] Firmware Revison: 0x07
[2025-05-31 10:00:17] Current Vout=5.2V, Iout=0.32A
[2025-05-31 10:00:17] System starts up because power supply is newly connected.
[2025-05-31 10:02:23] Applying network time to system...
  Done :-)
[2025-05-31 10:02:24] Done :-)
[2025-05-31 10:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 10:02:24> Done :-)
[2025-05-31 10:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 10:02:24] Pending for incoming shutdown command...
[2025-05-31 10:02:24] Schedule next shutdown at: 2025-05-31 10:10:00
[2025-05-31 10:02:25] Schedule next startup at: 2025-05-31 10:20:00
[2025-05-31 10:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 10:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 10:20:17] Done :-)
[2025-05-31 10:20:17] Firmware ID: 0x37
[2025-05-31 10:20:17] Firmware Revison: 0x07
[2025-05-31 10:20:17] Current Vout=5.2V, Iout=0.27A
[2025-05-31 10:20:17] System starts up because power supply is newly connected.
[2025-05-31 10:22:22] Applying network time to system...
  Done :-)
[2025-05-31 10:22:25] Done :-)
[2025-05-31 10:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 10:22:25> Done :-)
[2025-05-31 10:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 10:22:25] Pending for incoming shutdown command...
[2025-05-31 10:22:25] Schedule next shutdown at: 2025-05-31 10:30:00
[2025-05-31 10:22:25] Schedule next startup at: 2025-05-31 10:40:00
[2025-05-31 10:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 10:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 10:40:18] Done :-)
[2025-05-31 10:40:18] Firmware ID: 0x37
[2025-05-31 10:40:18] Firmware Revison: 0x07
[2025-05-31 10:40:18] Current Vout=5.19V, Iout=0.32A
[2025-05-31 10:40:18] System starts up because power supply is newly connected.
[2025-05-31 10:42:24] Applying network time to system...
  Done :-)
[2025-05-31 10:42:26] Done :-)
[2025-05-31 10:42:26] Writing system time to RTC...
  Done :-)
<2025-05-31 10:42:26> Done :-)
[2025-05-31 10:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 10:42:26] Pending for incoming shutdown command...
[2025-05-31 10:42:26] Schedule next shutdown at: 2025-05-31 10:50:00
[2025-05-31 10:42:26] Schedule next startup at: 2025-05-31 11:00:00
[2025-05-31 10:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 10:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 11:00:17] Done :-)
[2025-05-31 11:00:17] Firmware ID: 0x37
[2025-05-31 11:00:17] Firmware Revison: 0x07
[2025-05-31 11:00:17] Current Vout=5.2V, Iout=0.55A
[2025-05-31 11:00:17] System starts up because power supply is newly connected.
[2025-05-31 11:02:22] Applying network time to system...
  Done :-)
[2025-05-31 11:02:24] Done :-)
[2025-05-31 11:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 11:02:24> Done :-)
[2025-05-31 11:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 11:02:24] Pending for incoming shutdown command...
[2025-05-31 11:02:24] Schedule next shutdown at: 2025-05-31 11:10:00
[2025-05-31 11:02:24] Schedule next startup at: 2025-05-31 11:20:00
[2025-05-31 11:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 11:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 11:20:17] Done :-)
[2025-05-31 11:20:17] Firmware ID: 0x37
[2025-05-31 11:20:17] Firmware Revison: 0x07
[2025-05-31 11:20:17] Current Vout=5.13V, Iout=0.47A
[2025-05-31 11:20:17] System starts up because power supply is newly connected.
[2025-05-31 11:22:23] Applying network time to system...
  Done :-)
[2025-05-31 11:22:25] Done :-)
[2025-05-31 11:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 11:22:25> Done :-)
[2025-05-31 11:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 11:22:25] Pending for incoming shutdown command...
[2025-05-31 11:22:25] Schedule next shutdown at: 2025-05-31 11:30:00
[2025-05-31 11:22:25] Schedule next startup at: 2025-05-31 11:40:00
[2025-05-31 11:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 11:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 11:40:17] Done :-)
[2025-05-31 11:40:17] Firmware ID: 0x37
[2025-05-31 11:40:17] Firmware Revison: 0x07
[2025-05-31 11:40:17] Current Vout=5.19V, Iout=0.66A
[2025-05-31 11:40:17] System starts up because power supply is newly connected.
[2025-05-31 11:42:22] Applying network time to system...
  Done :-)
[2025-05-31 11:42:24] Done :-)
[2025-05-31 11:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 11:42:24> Done :-)
[2025-05-31 11:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 11:42:24] Pending for incoming shutdown command...
[2025-05-31 11:42:24] Schedule next shutdown at: 2025-05-31 11:50:00
[2025-05-31 11:42:24] Schedule next startup at: 2025-05-31 12:00:00
[2025-05-31 11:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 11:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 12:00:18] Done :-)
[2025-05-31 12:00:18] Firmware ID: 0x37
[2025-05-31 12:00:18] Firmware Revison: 0x07
[2025-05-31 12:00:18] Current Vout=5.19V, Iout=0.64A
[2025-05-31 12:00:18] System starts up because power supply is newly connected.
[2025-05-31 12:02:24] Applying network time to system...
  Done :-)
[2025-05-31 12:02:25] Done :-)
[2025-05-31 12:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 12:02:25> Done :-)
[2025-05-31 12:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 12:02:25] Pending for incoming shutdown command...
[2025-05-31 12:02:25] Schedule next shutdown at: 2025-05-31 12:10:00
[2025-05-31 12:02:25] Schedule next startup at: 2025-05-31 12:20:00
[2025-05-31 12:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 12:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 12:20:17] Done :-)
[2025-05-31 12:20:17] Firmware ID: 0x37
[2025-05-31 12:20:17] Firmware Revison: 0x07
[2025-05-31 12:20:17] Current Vout=5.2V, Iout=0.62A
[2025-05-31 12:20:17] System starts up because power supply is newly connected.
[2025-05-31 12:22:28] Applying network time to system...
  Done :-)
[2025-05-31 12:22:30] Done :-)
[2025-05-31 12:22:30] Writing system time to RTC...
  Done :-)
<2025-05-31 12:22:30> Done :-)
[2025-05-31 12:22:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 12:22:30] Pending for incoming shutdown command...
[2025-05-31 12:22:30] Schedule next shutdown at: 2025-05-31 12:30:00
[2025-05-31 12:22:31] Schedule next startup at: 2025-05-31 12:40:00
[2025-05-31 12:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 12:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 12:40:17] Done :-)
[2025-05-31 12:40:17] Firmware ID: 0x37
[2025-05-31 12:40:17] Firmware Revison: 0x07
[2025-05-31 12:40:17] Current Vout=5.19V, Iout=0.7A
[2025-05-31 12:40:17] System starts up because power supply is newly connected.
[2025-05-31 12:42:28] Applying network time to system...
  Done :-)
[2025-05-31 12:42:30] Done :-)
[2025-05-31 12:42:30] Writing system time to RTC...
  Done :-)
<2025-05-31 12:42:30> Done :-)
[2025-05-31 12:42:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 12:42:30] Pending for incoming shutdown command...
[2025-05-31 12:42:30] Schedule next shutdown at: 2025-05-31 12:50:00
[2025-05-31 12:42:31] Schedule next startup at: 2025-05-31 13:00:00
[2025-05-31 12:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 12:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 13:00:17] Done :-)
[2025-05-31 13:00:17] Firmware ID: 0x37
[2025-05-31 13:00:17] Firmware Revison: 0x07
[2025-05-31 13:00:17] Current Vout=5.19V, Iout=0.49A
[2025-05-31 13:00:17] System starts up because power supply is newly connected.
[2025-05-31 13:02:23] Applying network time to system...
  Done :-)
[2025-05-31 13:02:24] Done :-)
[2025-05-31 13:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 13:02:24> Done :-)
[2025-05-31 13:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 13:02:24] Pending for incoming shutdown command...
[2025-05-31 13:02:24] Schedule next shutdown at: 2025-05-31 13:10:00
[2025-05-31 13:02:24] Schedule next startup at: 2025-05-31 13:20:00
[2025-05-31 13:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 13:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 13:20:17] Done :-)
[2025-05-31 13:20:17] Firmware ID: 0x37
[2025-05-31 13:20:17] Firmware Revison: 0x07
[2025-05-31 13:20:17] Current Vout=5.28V, Iout=0.62A
[2025-05-31 13:20:17] System starts up because power supply is newly connected.
[2025-05-31 13:22:28] Applying network time to system...
  Done :-)
[2025-05-31 13:22:29] Done :-)
[2025-05-31 13:22:29] Writing system time to RTC...
  Done :-)
<2025-05-31 13:22:29> Done :-)
[2025-05-31 13:22:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 13:22:29] Pending for incoming shutdown command...
[2025-05-31 13:22:29] Schedule next shutdown at: 2025-05-31 13:30:00
[2025-05-31 13:22:29] Schedule next startup at: 2025-05-31 13:40:00
[2025-05-31 13:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 13:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 13:40:17] Done :-)
[2025-05-31 13:40:17] Firmware ID: 0x37
[2025-05-31 13:40:17] Firmware Revison: 0x07
[2025-05-31 13:40:17] Current Vout=5.19V, Iout=0.51A
[2025-05-31 13:40:17] System starts up because power supply is newly connected.
[2025-05-31 13:42:33] Applying network time to system...
  Done :-)
[2025-05-31 13:42:35] Done :-)
[2025-05-31 13:42:35] Writing system time to RTC...
[2025-05-31 13:42:36] I2C write 0x01 0x08 58 53 failed (result=0x36), retrying 1 ...
  Done :-)
<2025-05-31 13:42:36> Done :-)
[2025-05-31 13:42:36] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 13:42:36] Pending for incoming shutdown command...
[2025-05-31 13:42:36] Schedule next shutdown at: 2025-05-31 13:50:00
[2025-05-31 13:42:37] Schedule next startup at: 2025-05-31 14:00:00
[2025-05-31 13:50:01] Shutting down system because scheduled shutdown is due.
[2025-05-31 13:50:02] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 14:00:17] Done :-)
[2025-05-31 14:00:17] Firmware ID: 0x37
[2025-05-31 14:00:17] Firmware Revison: 0x07
[2025-05-31 14:00:17] Current Vout=5.27V, Iout=0.36A
[2025-05-31 14:00:17] System starts up because power supply is newly connected.
[2025-05-31 14:02:22] Applying network time to system...
  Done :-)
[2025-05-31 14:02:26] Done :-)
[2025-05-31 14:02:26] Writing system time to RTC...
  Done :-)
<2025-05-31 14:02:26> Done :-)
[2025-05-31 14:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 14:02:26] Pending for incoming shutdown command...
[2025-05-31 14:02:26] Schedule next shutdown at: 2025-05-31 14:10:00
[2025-05-31 14:02:26] Schedule next startup at: 2025-05-31 14:20:00
[2025-05-31 14:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 14:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 14:20:17] Done :-)
[2025-05-31 14:20:17] Firmware ID: 0x37
[2025-05-31 14:20:17] Firmware Revison: 0x07
[2025-05-31 14:20:17] Current Vout=5.2V, Iout=0.62A
[2025-05-31 14:20:17] System starts up because power supply is newly connected.
[2025-05-31 14:22:22] Applying network time to system...
  Done :-)
[2025-05-31 14:22:24] Done :-)
[2025-05-31 14:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 14:22:24> Done :-)
[2025-05-31 14:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 14:22:24] Pending for incoming shutdown command...
[2025-05-31 14:22:24] Schedule next shutdown at: 2025-05-31 14:30:00
[2025-05-31 14:22:24] Schedule next startup at: 2025-05-31 14:40:00
[2025-05-31 14:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 14:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 14:40:17] Done :-)
[2025-05-31 14:40:17] Firmware ID: 0x37
[2025-05-31 14:40:17] Firmware Revison: 0x07
[2025-05-31 14:40:17] Current Vout=5.31V, Iout=0.4A
[2025-05-31 14:40:17] System starts up because power supply is newly connected.
[2025-05-31 14:42:23] Applying network time to system...
  Done :-)
[2025-05-31 14:42:25] Done :-)
[2025-05-31 14:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 14:42:25> Done :-)
[2025-05-31 14:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 14:42:25] Pending for incoming shutdown command...
[2025-05-31 14:42:25] Schedule next shutdown at: 2025-05-31 14:50:00
[2025-05-31 14:42:25] Schedule next startup at: 2025-05-31 15:00:00
[2025-05-31 14:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 14:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 15:00:18] Done :-)
[2025-05-31 15:00:18] Firmware ID: 0x37
[2025-05-31 15:00:18] Firmware Revison: 0x07
[2025-05-31 15:00:18] Current Vout=5.26V, Iout=0.55A
[2025-05-31 15:00:18] System starts up because power supply is newly connected.
[2025-05-31 15:02:23] Applying network time to system...
  Done :-)
[2025-05-31 15:02:25] Done :-)
[2025-05-31 15:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 15:02:25> Done :-)
[2025-05-31 15:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 15:02:25] Pending for incoming shutdown command...
[2025-05-31 15:02:25] Schedule next shutdown at: 2025-05-31 15:10:00
[2025-05-31 15:02:25] Schedule next startup at: 2025-05-31 15:20:00
[2025-05-31 15:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 15:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 15:20:17] Done :-)
[2025-05-31 15:20:17] Firmware ID: 0x37
[2025-05-31 15:20:17] Firmware Revison: 0x07
[2025-05-31 15:20:17] Current Vout=5.19V, Iout=0.58A
[2025-05-31 15:20:17] System starts up because power supply is newly connected.
[2025-05-31 15:22:23] Applying network time to system...
  Done :-)
[2025-05-31 15:22:25] Done :-)
[2025-05-31 15:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 15:22:25> Done :-)
[2025-05-31 15:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 15:22:25] Pending for incoming shutdown command...
[2025-05-31 15:22:25] Schedule next shutdown at: 2025-05-31 15:30:00
[2025-05-31 15:22:25] Schedule next startup at: 2025-05-31 15:40:00
[2025-05-31 15:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 15:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 15:40:17] Done :-)
[2025-05-31 15:40:17] Firmware ID: 0x37
[2025-05-31 15:40:17] Firmware Revison: 0x07
[2025-05-31 15:40:17] Current Vout=5.19V, Iout=0.49A
[2025-05-31 15:40:17] System starts up because power supply is newly connected.
[2025-05-31 15:42:23] Applying network time to system...
  Done :-)
[2025-05-31 15:42:24] Done :-)
[2025-05-31 15:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 15:42:24> Done :-)
[2025-05-31 15:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 15:42:24] Pending for incoming shutdown command...
[2025-05-31 15:42:24] Schedule next shutdown at: 2025-05-31 15:50:00
[2025-05-31 15:42:25] Schedule next startup at: 2025-05-31 16:00:00
[2025-05-31 15:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 15:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 16:00:18] Done :-)
[2025-05-31 16:00:18] Firmware ID: 0x37
[2025-05-31 16:00:18] Firmware Revison: 0x07
[2025-05-31 16:00:18] Current Vout=5.19V, Iout=0.43A
[2025-05-31 16:00:18] System starts up because power supply is newly connected.
[2025-05-31 16:02:23] Applying network time to system...
  Done :-)
[2025-05-31 16:02:26] Done :-)
[2025-05-31 16:02:26] Writing system time to RTC...
  Done :-)
<2025-05-31 16:02:26> Done :-)
[2025-05-31 16:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 16:02:26] Pending for incoming shutdown command...
[2025-05-31 16:02:26] Schedule next shutdown at: 2025-05-31 16:10:00
[2025-05-31 16:02:26] Schedule next startup at: 2025-05-31 16:20:00
[2025-05-31 16:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 16:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 16:20:17] Done :-)
[2025-05-31 16:20:17] Firmware ID: 0x37
[2025-05-31 16:20:17] Firmware Revison: 0x07
[2025-05-31 16:20:17] Current Vout=5.19V, Iout=0.32A
[2025-05-31 16:20:17] System starts up because power supply is newly connected.
[2025-05-31 16:22:22] Applying network time to system...
  Done :-)
[2025-05-31 16:22:24] Done :-)
[2025-05-31 16:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 16:22:24> Done :-)
[2025-05-31 16:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 16:22:24] Pending for incoming shutdown command...
[2025-05-31 16:22:24] Schedule next shutdown at: 2025-05-31 16:30:00
[2025-05-31 16:22:24] Schedule next startup at: 2025-05-31 16:40:00
[2025-05-31 16:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 16:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 16:40:17] Done :-)
[2025-05-31 16:40:17] Firmware ID: 0x37
[2025-05-31 16:40:17] Firmware Revison: 0x07
[2025-05-31 16:40:17] Current Vout=5.19V, Iout=0.43A
[2025-05-31 16:40:17] System starts up because power supply is newly connected.
[2025-05-31 16:42:22] Applying network time to system...
  Done :-)
[2025-05-31 16:42:24] Done :-)
[2025-05-31 16:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 16:42:24> Done :-)
[2025-05-31 16:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 16:42:24] Pending for incoming shutdown command...
[2025-05-31 16:42:24] Schedule next shutdown at: 2025-05-31 16:50:00
[2025-05-31 16:42:24] Schedule next startup at: 2025-05-31 17:00:00
[2025-05-31 16:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 16:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 17:00:17] Done :-)
[2025-05-31 17:00:17] Firmware ID: 0x37
[2025-05-31 17:00:17] Firmware Revison: 0x07
[2025-05-31 17:00:17] Current Vout=5.2V, Iout=0.55A
[2025-05-31 17:00:17] System starts up because power supply is newly connected.
[2025-05-31 17:02:22] Applying network time to system...
  Done :-)
[2025-05-31 17:02:24] Done :-)
[2025-05-31 17:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 17:02:24> Done :-)
[2025-05-31 17:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 17:02:24] Pending for incoming shutdown command...
[2025-05-31 17:02:24] Schedule next shutdown at: 2025-05-31 17:10:00
[2025-05-31 17:02:24] Schedule next startup at: 2025-05-31 17:20:00
[2025-05-31 17:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 17:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 17:20:17] Done :-)
[2025-05-31 17:20:17] Firmware ID: 0x37
[2025-05-31 17:20:17] Firmware Revison: 0x07
[2025-05-31 17:20:17] Current Vout=5.19V, Iout=0.27A
[2025-05-31 17:20:17] System starts up because power supply is newly connected.
[2025-05-31 17:22:22] Applying network time to system...
  Done :-)
[2025-05-31 17:22:24] Done :-)
[2025-05-31 17:22:24] Writing system time to RTC...
  Done :-)
<2025-05-31 17:22:24> Done :-)
[2025-05-31 17:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 17:22:24] Pending for incoming shutdown command...
[2025-05-31 17:22:24] Schedule next shutdown at: 2025-05-31 17:30:00
[2025-05-31 17:22:24] Schedule next startup at: 2025-05-31 17:40:00
[2025-05-31 17:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 17:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 17:40:18] Done :-)
[2025-05-31 17:40:18] Firmware ID: 0x37
[2025-05-31 17:40:18] Firmware Revison: 0x07
[2025-05-31 17:40:18] Current Vout=5.27V, Iout=0.45A
[2025-05-31 17:40:18] System starts up because power supply is newly connected.
[2025-05-31 17:42:23] Applying network time to system...
  Done :-)
[2025-05-31 17:42:24] Done :-)
[2025-05-31 17:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 17:42:24> Done :-)
[2025-05-31 17:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 17:42:24] Pending for incoming shutdown command...
[2025-05-31 17:42:24] Schedule next shutdown at: 2025-05-31 17:50:00
[2025-05-31 17:42:24] Schedule next startup at: 2025-05-31 18:00:00
[2025-05-31 17:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 17:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 18:00:18] Done :-)
[2025-05-31 18:00:18] Firmware ID: 0x37
[2025-05-31 18:00:18] Firmware Revison: 0x07
[2025-05-31 18:00:18] Current Vout=5.19V, Iout=0.58A
[2025-05-31 18:00:18] System starts up because power supply is newly connected.
[2025-05-31 18:02:23] Applying network time to system...
  Done :-)
[2025-05-31 18:02:25] Done :-)
[2025-05-31 18:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 18:02:25> Done :-)
[2025-05-31 18:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 18:02:25] Pending for incoming shutdown command...
[2025-05-31 18:02:25] Schedule next shutdown at: 2025-05-31 18:10:00
[2025-05-31 18:02:25] Schedule next startup at: 2025-05-31 18:20:00
[2025-05-31 18:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 18:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 18:20:17] Done :-)
[2025-05-31 18:20:17] Firmware ID: 0x37
[2025-05-31 18:20:17] Firmware Revison: 0x07
[2025-05-31 18:20:17] Current Vout=5.19V, Iout=0.27A
[2025-05-31 18:20:17] System starts up because power supply is newly connected.
[2025-05-31 18:22:23] Applying network time to system...
  Done :-)
[2025-05-31 18:22:25] Done :-)
[2025-05-31 18:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 18:22:25> Done :-)
[2025-05-31 18:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 18:22:25] Pending for incoming shutdown command...
[2025-05-31 18:22:25] Schedule next shutdown at: 2025-05-31 18:30:00
[2025-05-31 18:22:25] Schedule next startup at: 2025-05-31 18:40:00
[2025-05-31 18:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 18:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 18:40:18] Done :-)
[2025-05-31 18:40:18] Firmware ID: 0x37
[2025-05-31 18:40:18] Firmware Revison: 0x07
[2025-05-31 18:40:18] Current Vout=5.19V, Iout=0.75A
[2025-05-31 18:40:18] System starts up because power supply is newly connected.
[2025-05-31 18:42:23] Applying network time to system...
  Done :-)
[2025-05-31 18:42:24] Done :-)
[2025-05-31 18:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 18:42:24> Done :-)
[2025-05-31 18:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 18:42:24] Pending for incoming shutdown command...
[2025-05-31 18:42:24] Schedule next shutdown at: 2025-05-31 18:50:00
[2025-05-31 18:42:24] Schedule next startup at: 2025-05-31 19:00:00
[2025-05-31 18:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 18:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 19:00:17] Done :-)
[2025-05-31 19:00:17] Firmware ID: 0x37
[2025-05-31 19:00:17] Firmware Revison: 0x07
[2025-05-31 19:00:17] Current Vout=5.18V, Iout=0.3A
[2025-05-31 19:00:17] System starts up because power supply is newly connected.
[2025-05-31 19:02:23] Applying network time to system...
  Done :-)
[2025-05-31 19:02:25] Done :-)
[2025-05-31 19:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 19:02:25> Done :-)
[2025-05-31 19:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 19:02:25] Pending for incoming shutdown command...
[2025-05-31 19:02:25] Schedule next shutdown at: 2025-05-31 19:10:00
[2025-05-31 19:02:25] Schedule next startup at: 2025-05-31 19:20:00
[2025-05-31 19:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 19:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 19:20:17] Done :-)
[2025-05-31 19:20:17] Firmware ID: 0x37
[2025-05-31 19:20:17] Firmware Revison: 0x07
[2025-05-31 19:20:17] Current Vout=5.2V, Iout=0.55A
[2025-05-31 19:20:17] System starts up because power supply is newly connected.
[2025-05-31 19:22:27] Applying network time to system...
  Done :-)
[2025-05-31 19:22:29] Done :-)
[2025-05-31 19:22:29] Writing system time to RTC...
  Done :-)
<2025-05-31 19:22:29> Done :-)
[2025-05-31 19:22:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 19:22:29] Pending for incoming shutdown command...
[2025-05-31 19:22:29] Schedule next shutdown at: 2025-05-31 19:30:00
[2025-05-31 19:22:29] Schedule next startup at: 2025-05-31 19:40:00
[2025-05-31 19:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 19:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 19:40:17] Done :-)
[2025-05-31 19:40:17] Firmware ID: 0x37
[2025-05-31 19:40:17] Firmware Revison: 0x07
[2025-05-31 19:40:17] Current Vout=5.25V, Iout=0.3A
[2025-05-31 19:40:17] System starts up because power supply is newly connected.
[2025-05-31 19:42:28] Applying network time to system...
  Done :-)
[2025-05-31 19:42:29] Done :-)
[2025-05-31 19:42:29] Writing system time to RTC...
  Done :-)
<2025-05-31 19:42:29> Done :-)
[2025-05-31 19:42:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 19:42:29] Pending for incoming shutdown command...
[2025-05-31 19:42:29] Schedule next shutdown at: 2025-05-31 19:50:00
[2025-05-31 19:42:30] Schedule next startup at: 2025-05-31 20:00:00
[2025-05-31 19:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 19:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 20:00:17] Done :-)
[2025-05-31 20:00:17] Firmware ID: 0x37
[2025-05-31 20:00:17] Firmware Revison: 0x07
[2025-05-31 20:00:17] Current Vout=5.26V, Iout=0.49A
[2025-05-31 20:00:17] System starts up because power supply is newly connected.
  Can not get legit network time.
[2025-05-31 20:02:40] Can not get legit network time.
[2025-05-31 20:02:40] Writing system time to RTC...
  Done :-)
<2025-05-31 20:02:40> Done :-)
[2025-05-31 20:02:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 20:02:41] Pending for incoming shutdown command...
[2025-05-31 20:02:41] Schedule next shutdown at: 2025-05-31 20:10:00
[2025-05-31 20:02:41] Schedule next startup at: 2025-05-31 20:20:00
[2025-05-31 20:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 20:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 20:20:17] Done :-)
[2025-05-31 20:20:17] Firmware ID: 0x37
[2025-05-31 20:20:17] Firmware Revison: 0x07
[2025-05-31 20:20:17] Current Vout=5.19V, Iout=0.36A
[2025-05-31 20:20:17] System starts up because power supply is newly connected.
[2025-05-31 20:22:22] Applying network time to system...
  Done :-)
[2025-05-31 20:22:27] Done :-)
[2025-05-31 20:22:27] Writing system time to RTC...
  Done :-)
<2025-05-31 20:22:27> Done :-)
[2025-05-31 20:22:27] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 20:22:27] Pending for incoming shutdown command...
[2025-05-31 20:22:27] Schedule next shutdown at: 2025-05-31 20:30:00
[2025-05-31 20:22:27] Schedule next startup at: 2025-05-31 20:40:00
[2025-05-31 20:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 20:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 20:40:18] Done :-)
[2025-05-31 20:40:18] Firmware ID: 0x37
[2025-05-31 20:40:18] Firmware Revison: 0x07
[2025-05-31 20:40:18] Current Vout=5.27V, Iout=0.34A
[2025-05-31 20:40:18] System starts up because power supply is newly connected.
[2025-05-31 20:42:53] Can not get legit network time.
[2025-05-31 20:42:53] Writing system time to RTC...
  Done :-)
<2025-05-31 20:42:54> Done :-)
[2025-05-31 20:42:54] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 20:42:54] Pending for incoming shutdown command...
[2025-05-31 20:42:54] Schedule next shutdown at: 2025-05-31 20:50:00
[2025-05-31 20:42:54] Schedule next startup at: 2025-05-31 21:00:00
[2025-05-31 20:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 20:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 21:00:17] Done :-)
[2025-05-31 21:00:17] Firmware ID: 0x37
[2025-05-31 21:00:17] Firmware Revison: 0x07
[2025-05-31 21:00:17] Current Vout=5.19V, Iout=0.6A
[2025-05-31 21:00:17] System starts up because power supply is newly connected.
[2025-05-31 21:02:28] Applying network time to system...
  Done :-)
[2025-05-31 21:02:32] Done :-)
[2025-05-31 21:02:32] Writing system time to RTC...
  Done :-)
<2025-05-31 21:02:32> Done :-)
[2025-05-31 21:02:32] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 21:02:32] Pending for incoming shutdown command...
[2025-05-31 21:02:32] Schedule next shutdown at: 2025-05-31 21:10:00
[2025-05-31 21:02:32] Schedule next startup at: 2025-05-31 21:20:00
[2025-05-31 21:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 21:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 21:20:17] Done :-)
[2025-05-31 21:20:17] Firmware ID: 0x37
[2025-05-31 21:20:17] Firmware Revison: 0x07
[2025-05-31 21:20:17] Current Vout=5.33V, Iout=0.21A
[2025-05-31 21:20:17] System starts up because power supply is newly connected.
[2025-05-31 21:22:27] Applying network time to system...
  Done :-)
[2025-05-31 21:22:30] Done :-)
[2025-05-31 21:22:30] Writing system time to RTC...
  Done :-)
<2025-05-31 21:22:30> Done :-)
[2025-05-31 21:22:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 21:22:30] Pending for incoming shutdown command...
[2025-05-31 21:22:30] Schedule next shutdown at: 2025-05-31 21:30:00
[2025-05-31 21:22:31] Schedule next startup at: 2025-05-31 21:40:00
[2025-05-31 21:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 21:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 21:40:18] Done :-)
[2025-05-31 21:40:18] Firmware ID: 0x37
[2025-05-31 21:40:18] Firmware Revison: 0x07
[2025-05-31 21:40:18] Current Vout=5.19V, Iout=0.49A
[2025-05-31 21:40:18] System starts up because power supply is newly connected.
[2025-05-31 21:42:23] Applying network time to system...
  Done :-)
[2025-05-31 21:42:25] Done :-)
[2025-05-31 21:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 21:42:25> Done :-)
[2025-05-31 21:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 21:42:25] Pending for incoming shutdown command...
[2025-05-31 21:42:25] Schedule next shutdown at: 2025-05-31 21:50:00
[2025-05-31 21:42:25] Schedule next startup at: 2025-05-31 22:00:00
[2025-05-31 21:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 21:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 22:00:17] Done :-)
[2025-05-31 22:00:17] Firmware ID: 0x37
[2025-05-31 22:00:17] Firmware Revison: 0x07
[2025-05-31 22:00:17] Current Vout=5.2V, Iout=0.23A
[2025-05-31 22:00:17] System starts up because power supply is newly connected.
[2025-05-31 22:02:22] Applying network time to system...
  Done :-)
[2025-05-31 22:02:24] Done :-)
[2025-05-31 22:02:24] Writing system time to RTC...
  Done :-)
<2025-05-31 22:02:24> Done :-)
[2025-05-31 22:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 22:02:24] Pending for incoming shutdown command...
[2025-05-31 22:02:24] Schedule next shutdown at: 2025-05-31 22:10:00
[2025-05-31 22:02:24] Schedule next startup at: 2025-05-31 22:20:00
[2025-05-31 22:09:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 22:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 22:20:18] Done :-)
[2025-05-31 22:20:18] Firmware ID: 0x37
[2025-05-31 22:20:18] Firmware Revison: 0x07
[2025-05-31 22:20:18] Current Vout=5.19V, Iout=0.53A
[2025-05-31 22:20:18] System starts up because power supply is newly connected.
[2025-05-31 22:22:24] Applying network time to system...
  Done :-)
[2025-05-31 22:22:25] Done :-)
[2025-05-31 22:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 22:22:25> Done :-)
[2025-05-31 22:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 22:22:25] Pending for incoming shutdown command...
[2025-05-31 22:22:25] Schedule next shutdown at: 2025-05-31 22:30:00
[2025-05-31 22:22:25] Schedule next startup at: 2025-05-31 22:40:00
[2025-05-31 22:29:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 22:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 22:40:17] Done :-)
[2025-05-31 22:40:17] Firmware ID: 0x37
[2025-05-31 22:40:17] Firmware Revison: 0x07
[2025-05-31 22:40:17] Current Vout=5.32V, Iout=0.36A
[2025-05-31 22:40:17] System starts up because power supply is newly connected.
[2025-05-31 22:42:22] Applying network time to system...
  Done :-)
[2025-05-31 22:42:24] Done :-)
[2025-05-31 22:42:24] Writing system time to RTC...
  Done :-)
<2025-05-31 22:42:24> Done :-)
[2025-05-31 22:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 22:42:24] Pending for incoming shutdown command...
[2025-05-31 22:42:24] Schedule next shutdown at: 2025-05-31 22:50:00
[2025-05-31 22:42:24] Schedule next startup at: 2025-05-31 23:00:00
[2025-05-31 22:49:59] Shutting down system because scheduled shutdown is due.
[2025-05-31 22:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 23:00:17] Done :-)
[2025-05-31 23:00:17] Firmware ID: 0x37
[2025-05-31 23:00:17] Firmware Revison: 0x07
[2025-05-31 23:00:17] Current Vout=5.19V, Iout=0.51A
[2025-05-31 23:00:17] System starts up because power supply is newly connected.
[2025-05-31 23:02:22] Applying network time to system...
  Done :-)
[2025-05-31 23:02:25] Done :-)
[2025-05-31 23:02:25] Writing system time to RTC...
  Done :-)
<2025-05-31 23:02:25> Done :-)
[2025-05-31 23:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 23:02:25] Pending for incoming shutdown command...
[2025-05-31 23:02:25] Schedule next shutdown at: 2025-05-31 23:10:00
[2025-05-31 23:02:26] Schedule next startup at: 2025-05-31 23:20:00
[2025-05-31 23:10:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 23:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 23:20:18] Done :-)
[2025-05-31 23:20:18] Firmware ID: 0x37
[2025-05-31 23:20:18] Firmware Revison: 0x07
[2025-05-31 23:20:18] Current Vout=5.19V, Iout=0.66A
[2025-05-31 23:20:18] System starts up because power supply is newly connected.
[2025-05-31 23:22:23] Applying network time to system...
  Done :-)
[2025-05-31 23:22:25] Done :-)
[2025-05-31 23:22:25] Writing system time to RTC...
  Done :-)
<2025-05-31 23:22:25> Done :-)
[2025-05-31 23:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 23:22:25] Pending for incoming shutdown command...
[2025-05-31 23:22:25] Schedule next shutdown at: 2025-05-31 23:30:00
[2025-05-31 23:22:25] Schedule next startup at: 2025-05-31 23:40:00
[2025-05-31 23:30:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 23:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-05-31 23:40:17] Done :-)
[2025-05-31 23:40:17] Firmware ID: 0x37
[2025-05-31 23:40:17] Firmware Revison: 0x07
[2025-05-31 23:40:17] Current Vout=5.26V, Iout=0.55A
[2025-05-31 23:40:17] System starts up because power supply is newly connected.
[2025-05-31 23:42:23] Applying network time to system...
  Done :-)
[2025-05-31 23:42:25] Done :-)
[2025-05-31 23:42:25] Writing system time to RTC...
  Done :-)
<2025-05-31 23:42:25> Done :-)
[2025-05-31 23:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-05-31 23:42:25] Pending for incoming shutdown command...
[2025-05-31 23:42:25] Schedule next shutdown at: 2025-05-31 23:50:00
[2025-05-31 23:42:25] Schedule next startup at: 2025-06-01 00:00:00
[2025-05-31 23:50:00] Shutting down system because scheduled shutdown is due.
[2025-05-31 23:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 00:00:17] Done :-)
[2025-06-01 00:00:17] Firmware ID: 0x37
[2025-06-01 00:00:17] Firmware Revison: 0x07
[2025-06-01 00:00:17] Current Vout=5.19V, Iout=0.62A
[2025-06-01 00:00:17] System starts up because power supply is newly connected.
[2025-06-01 00:02:23] Applying network time to system...
  Done :-)
[2025-06-01 00:02:25] Done :-)
[2025-06-01 00:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 00:02:25> Done :-)
[2025-06-01 00:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 00:02:25] Pending for incoming shutdown command...
[2025-06-01 00:02:25] Schedule next shutdown at: 2025-06-01 00:10:00
[2025-06-01 00:02:25] Schedule next startup at: 2025-06-01 00:20:00
[2025-06-01 00:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 00:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 00:20:17] Done :-)
[2025-06-01 00:20:17] Firmware ID: 0x37
[2025-06-01 00:20:17] Firmware Revison: 0x07
[2025-06-01 00:20:17] Current Vout=5.2V, Iout=0.27A
[2025-06-01 00:20:17] System starts up because power supply is newly connected.
[2025-06-01 00:22:22] Applying network time to system...
  Done :-)
[2025-06-01 00:22:25] Done :-)
[2025-06-01 00:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 00:22:25> Done :-)
[2025-06-01 00:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 00:22:25] Pending for incoming shutdown command...
[2025-06-01 00:22:25] Schedule next shutdown at: 2025-06-01 00:30:00
[2025-06-01 00:22:25] Schedule next startup at: 2025-06-01 00:40:00
[2025-06-01 00:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 00:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 00:40:18] Done :-)
[2025-06-01 00:40:18] Firmware ID: 0x37
[2025-06-01 00:40:18] Firmware Revison: 0x07
[2025-06-01 00:40:18] Current Vout=5.26V, Iout=0.47A
[2025-06-01 00:40:18] System starts up because power supply is newly connected.
[2025-06-01 00:42:23] Applying network time to system...
  Done :-)
[2025-06-01 00:42:24] Done :-)
[2025-06-01 00:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 00:42:24> Done :-)
[2025-06-01 00:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 00:42:24] Pending for incoming shutdown command...
[2025-06-01 00:42:24] Schedule next shutdown at: 2025-06-01 00:50:00
[2025-06-01 00:42:24] Schedule next startup at: 2025-06-01 01:00:00
[2025-06-01 00:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 00:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 01:00:17] Done :-)
[2025-06-01 01:00:17] Firmware ID: 0x37
[2025-06-01 01:00:17] Firmware Revison: 0x07
[2025-06-01 01:00:17] Current Vout=5.13V, Iout=0.36A
[2025-06-01 01:00:17] System starts up because power supply is newly connected.
[2025-06-01 01:02:23] Applying network time to system...
  Done :-)
[2025-06-01 01:02:24] Done :-)
[2025-06-01 01:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 01:02:24> Done :-)
[2025-06-01 01:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 01:02:24] Pending for incoming shutdown command...
[2025-06-01 01:02:24] Schedule next shutdown at: 2025-06-01 01:10:00
[2025-06-01 01:02:24] Schedule next startup at: 2025-06-01 01:20:00
[2025-06-01 01:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 01:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 01:20:17] Done :-)
[2025-06-01 01:20:17] Firmware ID: 0x37
[2025-06-01 01:20:17] Firmware Revison: 0x07
[2025-06-01 01:20:17] Current Vout=5.19V, Iout=0.32A
[2025-06-01 01:20:17] System starts up because power supply is newly connected.
[2025-06-01 01:22:22] Applying network time to system...
  Done :-)
[2025-06-01 01:22:25] Done :-)
[2025-06-01 01:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 01:22:25> Done :-)
[2025-06-01 01:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 01:22:25] Pending for incoming shutdown command...
[2025-06-01 01:22:25] Schedule next shutdown at: 2025-06-01 01:30:00
[2025-06-01 01:22:25] Schedule next startup at: 2025-06-01 01:40:00
[2025-06-01 01:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 01:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 01:40:17] Done :-)
[2025-06-01 01:40:17] Firmware ID: 0x37
[2025-06-01 01:40:17] Firmware Revison: 0x07
[2025-06-01 01:40:17] Current Vout=5.2V, Iout=0.62A
[2025-06-01 01:40:17] System starts up because power supply is newly connected.
[2025-06-01 01:42:23] Applying network time to system...
  Done :-)
[2025-06-01 01:42:24] Done :-)
[2025-06-01 01:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 01:42:24> Done :-)
[2025-06-01 01:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 01:42:24] Pending for incoming shutdown command...
[2025-06-01 01:42:24] Schedule next shutdown at: 2025-06-01 01:50:00
[2025-06-01 01:42:24] Schedule next startup at: 2025-06-01 02:00:00
[2025-06-01 01:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 01:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 02:00:17] Done :-)
[2025-06-01 02:00:17] Firmware ID: 0x37
[2025-06-01 02:00:17] Firmware Revison: 0x07
[2025-06-01 02:00:17] Current Vout=5.19V, Iout=0.49A
[2025-06-01 02:00:17] System starts up because power supply is newly connected.
[2025-06-01 02:02:28] Applying network time to system...
  Done :-)
[2025-06-01 02:02:30] Done :-)
[2025-06-01 02:02:30] Writing system time to RTC...
  Done :-)
<2025-06-01 02:02:30> Done :-)
[2025-06-01 02:02:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 02:02:30] Pending for incoming shutdown command...
[2025-06-01 02:02:30] Schedule next shutdown at: 2025-06-01 02:10:00
[2025-06-01 02:02:30] Schedule next startup at: 2025-06-01 02:20:00
[2025-06-01 02:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 02:09:59] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-06-01 02:20:17] Done :-)
[2025-06-01 02:20:17] Firmware ID: 0x37
[2025-06-01 02:20:17] Firmware Revison: 0x07
[2025-06-01 02:20:17] Current Vout=5.2V, Iout=0.45A
[2025-06-01 02:20:17] System starts up because power supply is newly connected.
[2025-06-01 02:22:22] Applying network time to system...
  Done :-)
[2025-06-01 02:22:24] Done :-)
[2025-06-01 02:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 02:22:24> Done :-)
[2025-06-01 02:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 02:22:24] Pending for incoming shutdown command...
[2025-06-01 02:22:24] Schedule next shutdown at: 2025-06-01 02:30:00
[2025-06-01 02:22:24] Schedule next startup at: 2025-06-01 02:40:00
[2025-06-01 02:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 02:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 02:40:17] Done :-)
[2025-06-01 02:40:17] Firmware ID: 0x37
[2025-06-01 02:40:17] Firmware Revison: 0x07
[2025-06-01 02:40:17] Current Vout=5.19V, Iout=0.64A
[2025-06-01 02:40:17] System starts up because power supply is newly connected.
[2025-06-01 02:42:23] Applying network time to system...
  Done :-)
[2025-06-01 02:42:24] Done :-)
[2025-06-01 02:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 02:42:24> Done :-)
[2025-06-01 02:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 02:42:24] Pending for incoming shutdown command...
[2025-06-01 02:42:24] Schedule next shutdown at: 2025-06-01 02:50:00
[2025-06-01 02:42:24] Schedule next startup at: 2025-06-01 03:00:00
[2025-06-01 02:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 02:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 03:00:17] Done :-)
[2025-06-01 03:00:17] Firmware ID: 0x37
[2025-06-01 03:00:17] Firmware Revison: 0x07
[2025-06-01 03:00:17] Current Vout=5.19V, Iout=0.53A
[2025-06-01 03:00:17] System starts up because power supply is newly connected.
[2025-06-01 03:02:23] Applying network time to system...
  Done :-)
[2025-06-01 03:02:25] Done :-)
[2025-06-01 03:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 03:02:25> Done :-)
[2025-06-01 03:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 03:02:25] Pending for incoming shutdown command...
[2025-06-01 03:02:25] Schedule next shutdown at: 2025-06-01 03:10:00
[2025-06-01 03:02:25] Schedule next startup at: 2025-06-01 03:20:00
[2025-06-01 03:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 03:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 03:20:17] Done :-)
[2025-06-01 03:20:17] Firmware ID: 0x37
[2025-06-01 03:20:17] Firmware Revison: 0x07
[2025-06-01 03:20:17] Current Vout=5.13V, Iout=0.4A
[2025-06-01 03:20:17] System starts up because power supply is newly connected.
[2025-06-01 03:22:26] Applying network time to system...
  Done :-)
[2025-06-01 03:22:27] Done :-)
[2025-06-01 03:22:27] Writing system time to RTC...
  Done :-)
<2025-06-01 03:22:27> Done :-)
[2025-06-01 03:22:27] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 03:22:27] Pending for incoming shutdown command...
[2025-06-01 03:22:27] Schedule next shutdown at: 2025-06-01 03:30:00
[2025-06-01 03:22:28] Schedule next startup at: 2025-06-01 03:40:00
[2025-06-01 03:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 03:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 03:40:17] Done :-)
[2025-06-01 03:40:17] Firmware ID: 0x37
[2025-06-01 03:40:17] Firmware Revison: 0x07
[2025-06-01 03:40:17] Current Vout=5.33V, Iout=0.43A
[2025-06-01 03:40:17] System starts up because power supply is newly connected.
[2025-06-01 03:42:36] Applying network time to system...
  Done :-)
[2025-06-01 03:42:39] Done :-)
[2025-06-01 03:42:39] Writing system time to RTC...
  Done :-)
<2025-06-01 03:42:39> Done :-)
[2025-06-01 03:42:39] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 03:42:39] Pending for incoming shutdown command...
[2025-06-01 03:42:39] Schedule next shutdown at: 2025-06-01 03:50:00
[2025-06-01 03:42:39] Schedule next startup at: 2025-06-01 04:00:00
[2025-06-01 03:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 03:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 04:00:17] Done :-)
[2025-06-01 04:00:17] Firmware ID: 0x37
[2025-06-01 04:00:17] Firmware Revison: 0x07
[2025-06-01 04:00:17] Current Vout=5.19V, Iout=0.58A
[2025-06-01 04:00:17] System starts up because power supply is newly connected.
[2025-06-01 04:02:22] Applying network time to system...
  Done :-)
[2025-06-01 04:02:24] Done :-)
[2025-06-01 04:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 04:02:24> Done :-)
[2025-06-01 04:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 04:02:24] Pending for incoming shutdown command...
[2025-06-01 04:02:24] Schedule next shutdown at: 2025-06-01 04:10:00
[2025-06-01 04:02:24] Schedule next startup at: 2025-06-01 04:20:00
[2025-06-01 04:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 04:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 04:20:17] Done :-)
[2025-06-01 04:20:17] Firmware ID: 0x37
[2025-06-01 04:20:17] Firmware Revison: 0x07
[2025-06-01 04:20:17] Current Vout=5.13V, Iout=0.47A
[2025-06-01 04:20:17] System starts up because power supply is newly connected.
[2025-06-01 04:22:22] Applying network time to system...
  Done :-)
[2025-06-01 04:22:24] Done :-)
[2025-06-01 04:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 04:22:24> Done :-)
[2025-06-01 04:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 04:22:24] Pending for incoming shutdown command...
[2025-06-01 04:22:24] Schedule next shutdown at: 2025-06-01 04:30:00
[2025-06-01 04:22:24] Schedule next startup at: 2025-06-01 04:40:00
[2025-06-01 04:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 04:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 04:40:17] Done :-)
[2025-06-01 04:40:17] Firmware ID: 0x37
[2025-06-01 04:40:17] Firmware Revison: 0x07
[2025-06-01 04:40:17] Current Vout=5.19V, Iout=0.38A
[2025-06-01 04:40:17] System starts up because power supply is newly connected.
[2025-06-01 04:42:22] Applying network time to system...
  Done :-)
[2025-06-01 04:42:24] Done :-)
[2025-06-01 04:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 04:42:24> Done :-)
[2025-06-01 04:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 04:42:24] Pending for incoming shutdown command...
[2025-06-01 04:42:24] Schedule next shutdown at: 2025-06-01 04:50:00
[2025-06-01 04:42:24] Schedule next startup at: 2025-06-01 05:00:00
[2025-06-01 04:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 04:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 05:00:17] Done :-)
[2025-06-01 05:00:17] Firmware ID: 0x37
[2025-06-01 05:00:17] Firmware Revison: 0x07
[2025-06-01 05:00:17] Current Vout=5.2V, Iout=0.68A
[2025-06-01 05:00:17] System starts up because power supply is newly connected.
[2025-06-01 05:02:22] Applying network time to system...
  Done :-)
[2025-06-01 05:02:24] Done :-)
[2025-06-01 05:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 05:02:24> Done :-)
[2025-06-01 05:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 05:02:24] Pending for incoming shutdown command...
[2025-06-01 05:02:24] Schedule next shutdown at: 2025-06-01 05:10:00
[2025-06-01 05:02:24] Schedule next startup at: 2025-06-01 05:20:00
[2025-06-01 05:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 05:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 05:20:17] Done :-)
[2025-06-01 05:20:17] Firmware ID: 0x37
[2025-06-01 05:20:17] Firmware Revison: 0x07
[2025-06-01 05:20:17] Current Vout=5.19V, Iout=0.43A
[2025-06-01 05:20:17] System starts up because power supply is newly connected.
[2025-06-01 05:22:22] Applying network time to system...
  Done :-)
[2025-06-01 05:22:24] Done :-)
[2025-06-01 05:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 05:22:24> Done :-)
[2025-06-01 05:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 05:22:24] Pending for incoming shutdown command...
[2025-06-01 05:22:24] Schedule next shutdown at: 2025-06-01 05:30:00
[2025-06-01 05:22:24] Schedule next startup at: 2025-06-01 05:40:00
[2025-06-01 05:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 05:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 05:40:17] Done :-)
[2025-06-01 05:40:17] Firmware ID: 0x37
[2025-06-01 05:40:17] Firmware Revison: 0x07
[2025-06-01 05:40:17] Current Vout=5.25V, Iout=0.43A
[2025-06-01 05:40:17] System starts up because power supply is newly connected.
[2025-06-01 05:42:22] Applying network time to system...
  Done :-)
[2025-06-01 05:42:24] Done :-)
[2025-06-01 05:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 05:42:24> Done :-)
[2025-06-01 05:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 05:42:24] Pending for incoming shutdown command...
[2025-06-01 05:42:24] Schedule next shutdown at: 2025-06-01 05:50:00
[2025-06-01 05:42:24] Schedule next startup at: 2025-06-01 06:00:00
[2025-06-01 05:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 05:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 06:00:18] Done :-)
[2025-06-01 06:00:18] Firmware ID: 0x37
[2025-06-01 06:00:18] Firmware Revison: 0x07
[2025-06-01 06:00:18] Current Vout=5.19V, Iout=0.49A
[2025-06-01 06:00:18] System starts up because power supply is newly connected.
[2025-06-01 06:02:23] Applying network time to system...
  Done :-)
[2025-06-01 06:02:25] Done :-)
[2025-06-01 06:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 06:02:25> Done :-)
[2025-06-01 06:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 06:02:25] Pending for incoming shutdown command...
[2025-06-01 06:02:25] Schedule next shutdown at: 2025-06-01 06:10:00
[2025-06-01 06:02:25] Schedule next startup at: 2025-06-01 06:20:00
[2025-06-01 06:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 06:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 06:20:18] Done :-)
[2025-06-01 06:20:18] Firmware ID: 0x37
[2025-06-01 06:20:18] Firmware Revison: 0x07
[2025-06-01 06:20:18] Current Vout=5.19V, Iout=0.12A
[2025-06-01 06:20:18] System starts up because power supply is newly connected.
[2025-06-01 06:22:42] Applying network time to system...
  Done :-)
[2025-06-01 06:22:43] Done :-)
[2025-06-01 06:22:43] Writing system time to RTC...
  Done :-)
<2025-06-01 06:22:43> Done :-)
[2025-06-01 06:22:43] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 06:22:43] Pending for incoming shutdown command...
[2025-06-01 06:22:43] Schedule next shutdown at: 2025-06-01 06:30:00
[2025-06-01 06:22:44] Schedule next startup at: 2025-06-01 06:40:00
[2025-06-01 06:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 06:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 06:40:17] Done :-)
[2025-06-01 06:40:17] Firmware ID: 0x37
[2025-06-01 06:40:17] Firmware Revison: 0x07
[2025-06-01 06:40:17] Current Vout=5.19V, Iout=0.6A
[2025-06-01 06:40:17] System starts up because power supply is newly connected.
[2025-06-01 06:42:23] Applying network time to system...
  Done :-)
[2025-06-01 06:42:25] Done :-)
[2025-06-01 06:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 06:42:25> Done :-)
[2025-06-01 06:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 06:42:25] Pending for incoming shutdown command...
[2025-06-01 06:42:25] Schedule next shutdown at: 2025-06-01 06:50:00
[2025-06-01 06:42:25] Schedule next startup at: 2025-06-01 07:00:00
[2025-06-01 06:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 06:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 07:00:17] Done :-)
[2025-06-01 07:00:17] Firmware ID: 0x37
[2025-06-01 07:00:17] Firmware Revison: 0x07
[2025-06-01 07:00:17] Current Vout=5.26V, Iout=0.6A
[2025-06-01 07:00:17] System starts up because power supply is newly connected.
[2025-06-01 07:02:22] Applying network time to system...
  Done :-)
[2025-06-01 07:02:25] Done :-)
[2025-06-01 07:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 07:02:25> Done :-)
[2025-06-01 07:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 07:02:25] Pending for incoming shutdown command...
[2025-06-01 07:02:25] Schedule next shutdown at: 2025-06-01 07:10:00
[2025-06-01 07:02:25] Schedule next startup at: 2025-06-01 07:20:00
[2025-06-01 07:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 07:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 07:20:17] Done :-)
[2025-06-01 07:20:17] Firmware ID: 0x37
[2025-06-01 07:20:17] Firmware Revison: 0x07
[2025-06-01 07:20:17] Current Vout=5.19V, Iout=0.25A
[2025-06-01 07:20:17] System starts up because power supply is newly connected.
[2025-06-01 07:22:22] Applying network time to system...
  Done :-)
[2025-06-01 07:22:24] Done :-)
[2025-06-01 07:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 07:22:24> Done :-)
[2025-06-01 07:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 07:22:24] Pending for incoming shutdown command...
[2025-06-01 07:22:24] Schedule next shutdown at: 2025-06-01 07:30:00
[2025-06-01 07:22:24] Schedule next startup at: 2025-06-01 07:40:00
[2025-06-01 07:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 07:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 07:40:17] Done :-)
[2025-06-01 07:40:17] Firmware ID: 0x37
[2025-06-01 07:40:17] Firmware Revison: 0x07
[2025-06-01 07:40:17] Current Vout=5.19V, Iout=0.21A
[2025-06-01 07:40:17] System starts up because power supply is newly connected.
[2025-06-01 07:42:51] Applying network time to system...
  Done :-)
[2025-06-01 07:42:53] Done :-)
[2025-06-01 07:42:53] Writing system time to RTC...
  Done :-)
<2025-06-01 07:42:53> Done :-)
[2025-06-01 07:42:53] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 07:42:53] Pending for incoming shutdown command...
[2025-06-01 07:42:53] Schedule next shutdown at: 2025-06-01 07:50:00
[2025-06-01 07:42:54] Schedule next startup at: 2025-06-01 08:00:00
[2025-06-01 07:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 07:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 08:00:17] Done :-)
[2025-06-01 08:00:17] Firmware ID: 0x37
[2025-06-01 08:00:17] Firmware Revison: 0x07
[2025-06-01 08:00:17] Current Vout=5.2V, Iout=0.08A
[2025-06-01 08:00:17] System starts up because power supply is newly connected.
[2025-06-01 08:02:22] Applying network time to system...
  Done :-)
[2025-06-01 08:02:25] Done :-)
[2025-06-01 08:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 08:02:25> Done :-)
[2025-06-01 08:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 08:02:25] Pending for incoming shutdown command...
[2025-06-01 08:02:25] Schedule next shutdown at: 2025-06-01 08:10:00
[2025-06-01 08:02:25] Schedule next startup at: 2025-06-01 08:20:00
[2025-06-01 08:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 08:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 08:20:18] Done :-)
[2025-06-01 08:20:18] Firmware ID: 0x37
[2025-06-01 08:20:18] Firmware Revison: 0x07
[2025-06-01 08:20:18] Current Vout=5.19V, Iout=0.43A
[2025-06-01 08:20:18] System starts up because power supply is newly connected.
[2025-06-01 08:22:24] Applying network time to system...
  Done :-)
[2025-06-01 08:22:25] Done :-)
[2025-06-01 08:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 08:22:25> Done :-)
[2025-06-01 08:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 08:22:25] Pending for incoming shutdown command...
[2025-06-01 08:22:25] Schedule next shutdown at: 2025-06-01 08:30:00
[2025-06-01 08:22:25] Schedule next startup at: 2025-06-01 08:40:00
[2025-06-01 08:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 08:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 08:40:17] Done :-)
[2025-06-01 08:40:17] Firmware ID: 0x37
[2025-06-01 08:40:17] Firmware Revison: 0x07
[2025-06-01 08:40:17] Current Vout=5.19V, Iout=0.62A
[2025-06-01 08:40:17] System starts up because power supply is newly connected.
[2025-06-01 08:42:39] Applying network time to system...
  Done :-)
[2025-06-01 08:42:41] Done :-)
[2025-06-01 08:42:41] Writing system time to RTC...
  Done :-)
<2025-06-01 08:42:41> Done :-)
[2025-06-01 08:42:41] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 08:42:41] Pending for incoming shutdown command...
[2025-06-01 08:42:41] Schedule next shutdown at: 2025-06-01 08:50:00
[2025-06-01 08:42:41] Schedule next startup at: 2025-06-01 09:00:00
[2025-06-01 08:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 08:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 09:00:18] Done :-)
[2025-06-01 09:00:18] Firmware ID: 0x37
[2025-06-01 09:00:18] Firmware Revison: 0x07
[2025-06-01 09:00:18] Current Vout=5.2V, Iout=0.51A
[2025-06-01 09:00:18] System starts up because power supply is newly connected.
[2025-06-01 09:02:23] Applying network time to system...
  Done :-)
[2025-06-01 09:02:25] Done :-)
[2025-06-01 09:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 09:02:25> Done :-)
[2025-06-01 09:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 09:02:25] Pending for incoming shutdown command...
[2025-06-01 09:02:25] Schedule next shutdown at: 2025-06-01 09:10:00
[2025-06-01 09:02:25] Schedule next startup at: 2025-06-01 09:20:00
[2025-06-01 09:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 09:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 09:20:17] Done :-)
[2025-06-01 09:20:17] Firmware ID: 0x37
[2025-06-01 09:20:17] Firmware Revison: 0x07
[2025-06-01 09:20:17] Current Vout=5.19V, Iout=0.4A
[2025-06-01 09:20:17] System starts up because power supply is newly connected.
[2025-06-01 09:22:38] Applying network time to system...
  Done :-)
[2025-06-01 09:22:40] Done :-)
[2025-06-01 09:22:40] Writing system time to RTC...
  Done :-)
<2025-06-01 09:22:40> Done :-)
[2025-06-01 09:22:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 09:22:40] Pending for incoming shutdown command...
[2025-06-01 09:22:40] Schedule next shutdown at: 2025-06-01 09:30:00
[2025-06-01 09:22:40] Schedule next startup at: 2025-06-01 09:40:00
[2025-06-01 09:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 09:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 09:40:17] Done :-)
[2025-06-01 09:40:17] Firmware ID: 0x37
[2025-06-01 09:40:17] Firmware Revison: 0x07
[2025-06-01 09:40:17] Current Vout=5.19V, Iout=0.58A
[2025-06-01 09:40:17] System starts up because power supply is newly connected.
[2025-06-01 09:42:39] Applying network time to system...
  Done :-)
[2025-06-01 09:42:41] Done :-)
[2025-06-01 09:42:41] Writing system time to RTC...
  Done :-)
<2025-06-01 09:42:41> Done :-)
[2025-06-01 09:42:41] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 09:42:41] Pending for incoming shutdown command...
[2025-06-01 09:42:41] Schedule next shutdown at: 2025-06-01 09:50:00
[2025-06-01 09:42:42] Schedule next startup at: 2025-06-01 10:00:00
[2025-06-01 09:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 09:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 10:00:17] Done :-)
[2025-06-01 10:00:17] Firmware ID: 0x37
[2025-06-01 10:00:17] Firmware Revison: 0x07
[2025-06-01 10:00:17] Current Vout=5.2V, Iout=0.08A
[2025-06-01 10:00:17] System starts up because power supply is newly connected.
[2025-06-01 10:02:22] Applying network time to system...
  Done :-)
[2025-06-01 10:02:25] Done :-)
[2025-06-01 10:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 10:02:25> Done :-)
[2025-06-01 10:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 10:02:25] Pending for incoming shutdown command...
[2025-06-01 10:02:25] Schedule next shutdown at: 2025-06-01 10:10:00
[2025-06-01 10:02:25] Schedule next startup at: 2025-06-01 10:20:00
[2025-06-01 10:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 10:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 10:20:18] Done :-)
[2025-06-01 10:20:18] Firmware ID: 0x37
[2025-06-01 10:20:18] Firmware Revison: 0x07
[2025-06-01 10:20:18] Current Vout=5.2V, Iout=0.34A
[2025-06-01 10:20:18] System starts up because power supply is newly connected.
[2025-06-01 10:22:39] Applying network time to system...
  Done :-)
[2025-06-01 10:22:42] Done :-)
[2025-06-01 10:22:42] Writing system time to RTC...
  Done :-)
<2025-06-01 10:22:42> Done :-)
[2025-06-01 10:22:42] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 10:22:42] Pending for incoming shutdown command...
[2025-06-01 10:22:42] Schedule next shutdown at: 2025-06-01 10:30:00
[2025-06-01 10:22:42] Schedule next startup at: 2025-06-01 10:40:00
[2025-06-01 10:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 10:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 10:40:17] Done :-)
[2025-06-01 10:40:17] Firmware ID: 0x37
[2025-06-01 10:40:17] Firmware Revison: 0x07
[2025-06-01 10:40:17] Current Vout=5.32V, Iout=0.45A
[2025-06-01 10:40:17] System starts up because power supply is newly connected.
[2025-06-01 10:42:23] Applying network time to system...
  Done :-)
[2025-06-01 10:42:24] Done :-)
[2025-06-01 10:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 10:42:24> Done :-)
[2025-06-01 10:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 10:42:24] Pending for incoming shutdown command...
[2025-06-01 10:42:24] Schedule next shutdown at: 2025-06-01 10:50:00
[2025-06-01 10:42:24] Schedule next startup at: 2025-06-01 11:00:00
[2025-06-01 10:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 10:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 11:00:17] Done :-)
[2025-06-01 11:00:17] Firmware ID: 0x37
[2025-06-01 11:00:17] Firmware Revison: 0x07
[2025-06-01 11:00:17] Current Vout=5.2V, Iout=0.47A
[2025-06-01 11:00:17] System starts up because power supply is newly connected.
[2025-06-01 11:02:22] Applying network time to system...
  Done :-)
[2025-06-01 11:02:25] Done :-)
[2025-06-01 11:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 11:02:25> Done :-)
[2025-06-01 11:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 11:02:25] Pending for incoming shutdown command...
[2025-06-01 11:02:25] Schedule next shutdown at: 2025-06-01 11:10:00
[2025-06-01 11:02:25] Schedule next startup at: 2025-06-01 11:20:00
[2025-06-01 11:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 11:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 11:20:18] Done :-)
[2025-06-01 11:20:18] Firmware ID: 0x37
[2025-06-01 11:20:18] Firmware Revison: 0x07
[2025-06-01 11:20:18] Current Vout=5.27V, Iout=0.45A
[2025-06-01 11:20:18] System starts up because power supply is newly connected.
[2025-06-01 11:22:23] Applying network time to system...
  Done :-)
[2025-06-01 11:22:25] Done :-)
[2025-06-01 11:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 11:22:25> Done :-)
[2025-06-01 11:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 11:22:25] Pending for incoming shutdown command...
[2025-06-01 11:22:25] Schedule next shutdown at: 2025-06-01 11:30:00
[2025-06-01 11:22:25] Schedule next startup at: 2025-06-01 11:40:00
[2025-06-01 11:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 11:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 11:40:17] Done :-)
[2025-06-01 11:40:17] Firmware ID: 0x37
[2025-06-01 11:40:17] Firmware Revison: 0x07
[2025-06-01 11:40:17] Current Vout=5.18V, Iout=0.32A
[2025-06-01 11:40:17] System starts up because power supply is newly connected.
[2025-06-01 11:42:22] Applying network time to system...
  Done :-)
[2025-06-01 11:42:24] Done :-)
[2025-06-01 11:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 11:42:24> Done :-)
[2025-06-01 11:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 11:42:24] Pending for incoming shutdown command...
[2025-06-01 11:42:24] Schedule next shutdown at: 2025-06-01 11:50:00
[2025-06-01 11:42:24] Schedule next startup at: 2025-06-01 12:00:00
[2025-06-01 11:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 11:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 12:00:18] Done :-)
[2025-06-01 12:00:18] Firmware ID: 0x37
[2025-06-01 12:00:18] Firmware Revison: 0x07
[2025-06-01 12:00:18] Current Vout=5.19V, Iout=0.49A
[2025-06-01 12:00:18] System starts up because power supply is newly connected.
[2025-06-01 12:02:23] Applying network time to system...
  Done :-)
[2025-06-01 12:02:25] Done :-)
[2025-06-01 12:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 12:02:25> Done :-)
[2025-06-01 12:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 12:02:25] Pending for incoming shutdown command...
[2025-06-01 12:02:25] Schedule next shutdown at: 2025-06-01 12:10:00
[2025-06-01 12:02:25] Schedule next startup at: 2025-06-01 12:20:00
[2025-06-01 12:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 12:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 12:20:17] Done :-)
[2025-06-01 12:20:17] Firmware ID: 0x37
[2025-06-01 12:20:17] Firmware Revison: 0x07
[2025-06-01 12:20:17] Current Vout=5.2V, Iout=0.53A
[2025-06-01 12:20:17] System starts up because power supply is newly connected.
[2025-06-01 12:22:23] Applying network time to system...
  Done :-)
[2025-06-01 12:22:24] Done :-)
[2025-06-01 12:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 12:22:24> Done :-)
[2025-06-01 12:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 12:22:24] Pending for incoming shutdown command...
[2025-06-01 12:22:24] Schedule next shutdown at: 2025-06-01 12:30:00
[2025-06-01 12:22:24] Schedule next startup at: 2025-06-01 12:40:00
[2025-06-01 12:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 12:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 12:40:17] Done :-)
[2025-06-01 12:40:17] Firmware ID: 0x37
[2025-06-01 12:40:17] Firmware Revison: 0x07
[2025-06-01 12:40:17] Current Vout=5.2V, Iout=0.47A
[2025-06-01 12:40:17] System starts up because power supply is newly connected.
[2025-06-01 12:42:23] Applying network time to system...
  Done :-)
[2025-06-01 12:42:25] Done :-)
[2025-06-01 12:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 12:42:25> Done :-)
[2025-06-01 12:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 12:42:25] Pending for incoming shutdown command...
[2025-06-01 12:42:25] Schedule next shutdown at: 2025-06-01 12:50:00
[2025-06-01 12:42:25] Schedule next startup at: 2025-06-01 13:00:00
[2025-06-01 12:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 12:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 13:00:17] Done :-)
[2025-06-01 13:00:17] Firmware ID: 0x37
[2025-06-01 13:00:17] Firmware Revison: 0x07
[2025-06-01 13:00:17] Current Vout=5.25V, Iout=0.4A
[2025-06-01 13:00:17] System starts up because power supply is newly connected.
[2025-06-01 13:02:22] Applying network time to system...
  Done :-)
[2025-06-01 13:02:24] Done :-)
[2025-06-01 13:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 13:02:24> Done :-)
[2025-06-01 13:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 13:02:24] Pending for incoming shutdown command...
[2025-06-01 13:02:24] Schedule next shutdown at: 2025-06-01 13:10:00
[2025-06-01 13:02:24] Schedule next startup at: 2025-06-01 13:20:00
[2025-06-01 13:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 13:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 13:20:17] Done :-)
[2025-06-01 13:20:17] Firmware ID: 0x37
[2025-06-01 13:20:17] Firmware Revison: 0x07
[2025-06-01 13:20:17] Current Vout=5.2V, Iout=0.53A
[2025-06-01 13:20:17] System starts up because power supply is newly connected.
[2025-06-01 13:22:28] Applying network time to system...
  Done :-)
[2025-06-01 13:22:30] Done :-)
[2025-06-01 13:22:30] Writing system time to RTC...
  Done :-)
<2025-06-01 13:22:30> Done :-)
[2025-06-01 13:22:30] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 13:22:30] Pending for incoming shutdown command...
[2025-06-01 13:22:30] Schedule next shutdown at: 2025-06-01 13:30:00
[2025-06-01 13:22:30] Schedule next startup at: 2025-06-01 13:40:00
[2025-06-01 13:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 13:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 13:40:18] Done :-)
[2025-06-01 13:40:18] Firmware ID: 0x37
[2025-06-01 13:40:18] Firmware Revison: 0x07
[2025-06-01 13:40:18] Current Vout=5.19V, Iout=0.4A
[2025-06-01 13:40:18] System starts up because power supply is newly connected.
[2025-06-01 13:42:24] Applying network time to system...
  Done :-)
[2025-06-01 13:42:24] Done :-)
[2025-06-01 13:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 13:42:24> Done :-)
[2025-06-01 13:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 13:42:24] Pending for incoming shutdown command...
[2025-06-01 13:42:24] Schedule next shutdown at: 2025-06-01 13:50:00
[2025-06-01 13:42:25] Schedule next startup at: 2025-06-01 14:00:00
[2025-06-01 13:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 13:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 14:00:18] Done :-)
[2025-06-01 14:00:18] Firmware ID: 0x37
[2025-06-01 14:00:18] Firmware Revison: 0x07
[2025-06-01 14:00:18] Current Vout=5.19V, Iout=0.47A
[2025-06-01 14:00:18] System starts up because power supply is newly connected.
[2025-06-01 14:02:23] Applying network time to system...
  Done :-)
[2025-06-01 14:02:25] Done :-)
[2025-06-01 14:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 14:02:25> Done :-)
[2025-06-01 14:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 14:02:25] Pending for incoming shutdown command...
[2025-06-01 14:02:25] Schedule next shutdown at: 2025-06-01 14:10:00
[2025-06-01 14:02:25] Schedule next startup at: 2025-06-01 14:20:00
[2025-06-01 14:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 14:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 14:20:17] Done :-)
[2025-06-01 14:20:17] Firmware ID: 0x37
[2025-06-01 14:20:17] Firmware Revison: 0x07
[2025-06-01 14:20:17] Current Vout=5.13V, Iout=0.58A
[2025-06-01 14:20:17] System starts up because power supply is newly connected.
[2025-06-01 14:22:22] Applying network time to system...
  Done :-)
[2025-06-01 14:22:24] Done :-)
[2025-06-01 14:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 14:22:24> Done :-)
[2025-06-01 14:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 14:22:24] Pending for incoming shutdown command...
[2025-06-01 14:22:24] Schedule next shutdown at: 2025-06-01 14:30:00
[2025-06-01 14:22:24] Schedule next startup at: 2025-06-01 14:40:00
[2025-06-01 14:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 14:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 14:40:17] Done :-)
[2025-06-01 14:40:17] Firmware ID: 0x37
[2025-06-01 14:40:17] Firmware Revison: 0x07
[2025-06-01 14:40:17] Current Vout=5.19V, Iout=0.36A
[2025-06-01 14:40:17] System starts up because power supply is newly connected.
[2025-06-01 14:42:22] Applying network time to system...
  Done :-)
[2025-06-01 14:42:25] Done :-)
[2025-06-01 14:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 14:42:25> Done :-)
[2025-06-01 14:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 14:42:25] Pending for incoming shutdown command...
[2025-06-01 14:42:25] Schedule next shutdown at: 2025-06-01 14:50:00
[2025-06-01 14:42:25] Schedule next startup at: 2025-06-01 15:00:00
[2025-06-01 14:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 14:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 15:00:17] Done :-)
[2025-06-01 15:00:17] Firmware ID: 0x37
[2025-06-01 15:00:17] Firmware Revison: 0x07
[2025-06-01 15:00:17] Current Vout=5.2V, Iout=0.19A
[2025-06-01 15:00:17] System starts up because power supply is newly connected.
[2025-06-01 15:02:22] Applying network time to system...
  Done :-)
[2025-06-01 15:02:24] Done :-)
[2025-06-01 15:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 15:02:24> Done :-)
[2025-06-01 15:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 15:02:24] Pending for incoming shutdown command...
[2025-06-01 15:02:24] Schedule next shutdown at: 2025-06-01 15:10:00
[2025-06-01 15:02:24] Schedule next startup at: 2025-06-01 15:20:00
[2025-06-01 15:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 15:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 15:20:17] Done :-)
[2025-06-01 15:20:17] Firmware ID: 0x37
[2025-06-01 15:20:17] Firmware Revison: 0x07
[2025-06-01 15:20:17] Current Vout=5.2V, Iout=0.55A
[2025-06-01 15:20:17] System starts up because power supply is newly connected.
[2025-06-01 15:22:23] Applying network time to system...
  Done :-)
[2025-06-01 15:22:25] Done :-)
[2025-06-01 15:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 15:22:25> Done :-)
[2025-06-01 15:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 15:22:25] Pending for incoming shutdown command...
[2025-06-01 15:22:25] Schedule next shutdown at: 2025-06-01 15:30:00
[2025-06-01 15:22:25] Schedule next startup at: 2025-06-01 15:40:00
[2025-06-01 15:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 15:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 15:40:17] Done :-)
[2025-06-01 15:40:17] Firmware ID: 0x37
[2025-06-01 15:40:17] Firmware Revison: 0x07
[2025-06-01 15:40:17] Current Vout=5.13V, Iout=0.36A
[2025-06-01 15:40:17] System starts up because power supply is newly connected.
[2025-06-01 15:42:22] Applying network time to system...
  Done :-)
[2025-06-01 15:42:25] Done :-)
[2025-06-01 15:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 15:42:25> Done :-)
[2025-06-01 15:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 15:42:25] Pending for incoming shutdown command...
[2025-06-01 15:42:25] Schedule next shutdown at: 2025-06-01 15:50:00
[2025-06-01 15:42:25] Schedule next startup at: 2025-06-01 16:00:00
[2025-06-01 15:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 15:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 15:50:32] Done :-)
[2025-06-01 15:50:32] Firmware ID: 0x37
[2025-06-01 15:50:32] Firmware Revison: 0x07
[2025-06-01 15:50:32] Current Vin=4.42V, Vout=5.19V, Iout=0.21A
[2025-06-01 15:50:32] System starts up because power supply is newly connected.
[2025-06-01 15:52:37] Applying network time to system...
  Done :-)
[2025-06-01 15:52:54] Done :-)
[2025-06-01 15:52:54] Writing system time to RTC...
  Done :-)
<2025-06-01 15:52:54> Done :-)
[2025-06-01 15:52:54] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 15:52:54] Schedule script is interrupted, revising the schedule...
[2025-06-01 15:52:54] Pending for incoming shutdown command...
[2025-06-01 15:52:54] Schedule next shutdown at: 2025-06-01 15:59:00
[2025-06-01 15:52:54] Schedule next startup at: 2025-06-01 16:00:00
[2025-06-01 15:59:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 15:59:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 16:00:17] Done :-)
[2025-06-01 16:00:17] Firmware ID: 0x37
[2025-06-01 16:00:17] Firmware Revison: 0x07
[2025-06-01 16:00:17] Current Vout=5.2V, Iout=0.4A
[2025-06-01 16:00:17] System starts up because power supply is newly connected.
[2025-06-01 16:02:22] Applying network time to system...
  Done :-)
[2025-06-01 16:02:25] Done :-)
[2025-06-01 16:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 16:02:25> Done :-)
[2025-06-01 16:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 16:02:25] Pending for incoming shutdown command...
[2025-06-01 16:02:25] Schedule next shutdown at: 2025-06-01 16:10:00
[2025-06-01 16:02:25] Schedule next startup at: 2025-06-01 16:20:00
[2025-06-01 16:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 16:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 16:20:17] Done :-)
[2025-06-01 16:20:17] Firmware ID: 0x37
[2025-06-01 16:20:17] Firmware Revison: 0x07
[2025-06-01 16:20:17] Current Vout=5.2V, Iout=0.62A
[2025-06-01 16:20:17] System starts up because power supply is newly connected.
[2025-06-01 16:22:22] Applying network time to system...
  Done :-)
[2025-06-01 16:22:24] Done :-)
[2025-06-01 16:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 16:22:24> Done :-)
[2025-06-01 16:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 16:22:24] Pending for incoming shutdown command...
[2025-06-01 16:22:24] Schedule next shutdown at: 2025-06-01 16:30:00
[2025-06-01 16:22:24] Schedule next startup at: 2025-06-01 16:40:00
[2025-06-01 16:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 16:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 16:40:17] Done :-)
[2025-06-01 16:40:17] Firmware ID: 0x37
[2025-06-01 16:40:17] Firmware Revison: 0x07
[2025-06-01 16:40:17] Current Vin=4.12V, Vout=5.13V, Iout=0.62A
[2025-06-01 16:40:17] System starts up because power supply is newly connected.
[2025-06-01 16:42:23] Applying network time to system...
  Done :-)
[2025-06-01 16:42:24] Done :-)
[2025-06-01 16:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 16:42:24> Done :-)
[2025-06-01 16:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 16:42:24] Pending for incoming shutdown command...
[2025-06-01 16:42:24] Schedule next shutdown at: 2025-06-01 16:50:00
[2025-06-01 16:42:24] Schedule next startup at: 2025-06-01 17:00:00
[2025-06-01 16:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 16:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 17:00:17] Done :-)
[2025-06-01 17:00:17] Firmware ID: 0x37
[2025-06-01 17:00:17] Firmware Revison: 0x07
[2025-06-01 17:00:17] Current Vout=5.2V, Iout=0.45A
[2025-06-01 17:00:17] System starts up because power supply is newly connected.
[2025-06-01 17:02:22] Applying network time to system...
  Done :-)
[2025-06-01 17:02:24] Done :-)
[2025-06-01 17:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 17:02:24> Done :-)
[2025-06-01 17:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 17:02:24] Pending for incoming shutdown command...
[2025-06-01 17:02:24] Schedule next shutdown at: 2025-06-01 17:10:00
[2025-06-01 17:02:24] Schedule next startup at: 2025-06-01 17:20:00
[2025-06-01 17:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 17:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 17:20:18] Done :-)
[2025-06-01 17:20:18] Firmware ID: 0x37
[2025-06-01 17:20:18] Firmware Revison: 0x07
[2025-06-01 17:20:18] Current Vout=5.14V, Iout=0.19A
[2025-06-01 17:20:18] System starts up because power supply is newly connected.
[2025-06-01 17:22:23] Applying network time to system...
  Done :-)
[2025-06-01 17:22:24] Done :-)
[2025-06-01 17:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 17:22:24> Done :-)
[2025-06-01 17:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 17:22:24] Pending for incoming shutdown command...
[2025-06-01 17:22:24] Schedule next shutdown at: 2025-06-01 17:30:00
[2025-06-01 17:22:24] Schedule next startup at: 2025-06-01 17:40:00
[2025-06-01 17:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 17:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 17:40:17] Done :-)
[2025-06-01 17:40:17] Firmware ID: 0x37
[2025-06-01 17:40:17] Firmware Revison: 0x07
[2025-06-01 17:40:17] Current Vout=5.25V, Iout=0.45A
[2025-06-01 17:40:17] System starts up because power supply is newly connected.
[2025-06-01 17:42:22] Applying network time to system...
  Done :-)
[2025-06-01 17:42:25] Done :-)
[2025-06-01 17:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 17:42:25> Done :-)
[2025-06-01 17:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 17:42:25] Pending for incoming shutdown command...
[2025-06-01 17:42:25] Schedule next shutdown at: 2025-06-01 17:50:00
[2025-06-01 17:42:25] Schedule next startup at: 2025-06-01 18:00:00
[2025-06-01 17:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 17:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 18:00:17] Done :-)
[2025-06-01 18:00:17] Firmware ID: 0x37
[2025-06-01 18:00:17] Firmware Revison: 0x07
[2025-06-01 18:00:17] Current Vin=4.36V, Vout=5.19V, Iout=0.3A
[2025-06-01 18:00:17] System starts up because power supply is newly connected.
[2025-06-01 18:02:22] Applying network time to system...
  Done :-)
[2025-06-01 18:02:24] Done :-)
[2025-06-01 18:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 18:02:24> Done :-)
[2025-06-01 18:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 18:02:24] Pending for incoming shutdown command...
[2025-06-01 18:02:24] Schedule next shutdown at: 2025-06-01 18:10:00
[2025-06-01 18:02:24] Schedule next startup at: 2025-06-01 18:20:00
[2025-06-01 18:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 18:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 18:20:17] Done :-)
[2025-06-01 18:20:17] Firmware ID: 0x37
[2025-06-01 18:20:17] Firmware Revison: 0x07
[2025-06-01 18:20:17] Current Vin=4.42V, Vout=5.19V, Iout=0.53A
[2025-06-01 18:20:17] System starts up because power supply is newly connected.
[2025-06-01 18:22:22] Applying network time to system...
  Done :-)
[2025-06-01 18:22:25] Done :-)
[2025-06-01 18:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 18:22:25> Done :-)
[2025-06-01 18:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 18:22:25] Pending for incoming shutdown command...
[2025-06-01 18:22:25] Schedule next shutdown at: 2025-06-01 18:30:00
[2025-06-01 18:22:25] Schedule next startup at: 2025-06-01 18:40:00
[2025-06-01 18:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 18:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 18:40:17] Done :-)
[2025-06-01 18:40:17] Firmware ID: 0x37
[2025-06-01 18:40:17] Firmware Revison: 0x07
[2025-06-01 18:40:17] Current Vin=4.42V, Vout=5.13V, Iout=0.17A
[2025-06-01 18:40:17] System starts up because power supply is newly connected.
[2025-06-01 18:42:22] Applying network time to system...
  Done :-)
[2025-06-01 18:42:26] Done :-)
[2025-06-01 18:42:26] Writing system time to RTC...
  Done :-)
<2025-06-01 18:42:26> Done :-)
[2025-06-01 18:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 18:42:26] Pending for incoming shutdown command...
[2025-06-01 18:42:26] Schedule next shutdown at: 2025-06-01 18:50:00
[2025-06-01 18:42:26] Schedule next startup at: 2025-06-01 19:00:00
[2025-06-01 18:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 18:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 19:00:17] Done :-)
[2025-06-01 19:00:17] Firmware ID: 0x37
[2025-06-01 19:00:17] Firmware Revison: 0x07
[2025-06-01 19:00:17] Current Vin=4.3V, Vout=5.26V, Iout=0.68A
[2025-06-01 19:00:17] System starts up because power supply is newly connected.
[2025-06-01 19:02:22] Applying network time to system...
  Done :-)
[2025-06-01 19:02:25] Done :-)
[2025-06-01 19:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 19:02:25> Done :-)
[2025-06-01 19:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 19:02:25] Pending for incoming shutdown command...
[2025-06-01 19:02:25] Schedule next shutdown at: 2025-06-01 19:10:00
[2025-06-01 19:02:25] Schedule next startup at: 2025-06-01 19:20:00
[2025-06-01 19:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 19:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 19:20:17] Done :-)
[2025-06-01 19:20:17] Firmware ID: 0x37
[2025-06-01 19:20:17] Firmware Revison: 0x07
[2025-06-01 19:20:17] Current Vout=5.2V, Iout=0.32A
[2025-06-01 19:20:17] System starts up because power supply is newly connected.
[2025-06-01 19:22:22] Applying network time to system...
  Done :-)
[2025-06-01 19:22:24] Done :-)
[2025-06-01 19:22:24] Writing system time to RTC...
  Done :-)
<2025-06-01 19:22:24> Done :-)
[2025-06-01 19:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 19:22:24] Pending for incoming shutdown command...
[2025-06-01 19:22:24] Schedule next shutdown at: 2025-06-01 19:30:00
[2025-06-01 19:22:24] Schedule next startup at: 2025-06-01 19:40:00
[2025-06-01 19:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 19:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 19:40:17] Done :-)
[2025-06-01 19:40:17] Firmware ID: 0x37
[2025-06-01 19:40:17] Firmware Revison: 0x07
[2025-06-01 19:40:17] Current Vout=5.26V, Iout=0.47A
[2025-06-01 19:40:17] System starts up because power supply is newly connected.
[2025-06-01 19:42:22] Applying network time to system...
  Done :-)
[2025-06-01 19:42:24] Done :-)
[2025-06-01 19:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 19:42:24> Done :-)
[2025-06-01 19:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 19:42:24] Pending for incoming shutdown command...
[2025-06-01 19:42:24] Schedule next shutdown at: 2025-06-01 19:50:00
[2025-06-01 19:42:24] Schedule next startup at: 2025-06-01 20:00:00
[2025-06-01 19:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 19:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 20:00:17] Done :-)
[2025-06-01 20:00:17] Firmware ID: 0x37
[2025-06-01 20:00:17] Firmware Revison: 0x07
[2025-06-01 20:00:17] Current Vout=5.2V, Iout=0.43A
[2025-06-01 20:00:17] System starts up because power supply is newly connected.
[2025-06-01 20:02:22] Applying network time to system...
  Done :-)
[2025-06-01 20:02:24] Done :-)
[2025-06-01 20:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 20:02:24> Done :-)
[2025-06-01 20:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 20:02:24] Pending for incoming shutdown command...
[2025-06-01 20:02:24] Schedule next shutdown at: 2025-06-01 20:10:00
[2025-06-01 20:02:24] Schedule next startup at: 2025-06-01 20:20:00
[2025-06-01 20:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 20:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 20:20:18] Done :-)
[2025-06-01 20:20:18] Firmware ID: 0x37
[2025-06-01 20:20:18] Firmware Revison: 0x07
[2025-06-01 20:20:18] Current Vout=5.19V, Iout=0.3A
[2025-06-01 20:20:18] System starts up because power supply is newly connected.
[2025-06-01 20:22:23] Applying network time to system...
  Done :-)
[2025-06-01 20:22:26] Done :-)
[2025-06-01 20:22:26] Writing system time to RTC...
  Done :-)
<2025-06-01 20:22:26> Done :-)
[2025-06-01 20:22:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 20:22:26] Pending for incoming shutdown command...
[2025-06-01 20:22:26] Schedule next shutdown at: 2025-06-01 20:30:00
[2025-06-01 20:22:26] Schedule next startup at: 2025-06-01 20:40:00
[2025-06-01 20:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 20:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 20:40:17] Done :-)
[2025-06-01 20:40:17] Firmware ID: 0x37
[2025-06-01 20:40:17] Firmware Revison: 0x07
[2025-06-01 20:40:17] Current Vout=5.25V, Iout=0.45A
[2025-06-01 20:40:17] System starts up because power supply is newly connected.
[2025-06-01 20:42:22] Applying network time to system...
  Done :-)
[2025-06-01 20:42:24] Done :-)
[2025-06-01 20:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 20:42:24> Done :-)
[2025-06-01 20:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 20:42:24] Pending for incoming shutdown command...
[2025-06-01 20:42:24] Schedule next shutdown at: 2025-06-01 20:50:00
[2025-06-01 20:42:24] Schedule next startup at: 2025-06-01 21:00:00
[2025-06-01 20:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 20:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 21:00:18] Done :-)
[2025-06-01 21:00:18] Firmware ID: 0x37
[2025-06-01 21:00:18] Firmware Revison: 0x07
[2025-06-01 21:00:18] Current Vin=4.49V, Vout=5.25V, Iout=0.32A
[2025-06-01 21:00:18] System starts up because power supply is newly connected.
[2025-06-01 21:02:24] Applying network time to system...
  Done :-)
[2025-06-01 21:02:25] Done :-)
[2025-06-01 21:02:25] Writing system time to RTC...
  Done :-)
<2025-06-01 21:02:25> Done :-)
[2025-06-01 21:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 21:02:25] Pending for incoming shutdown command...
[2025-06-01 21:02:25] Schedule next shutdown at: 2025-06-01 21:10:00
[2025-06-01 21:02:25] Schedule next startup at: 2025-06-01 21:20:00
[2025-06-01 21:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 21:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 21:20:17] Done :-)
[2025-06-01 21:20:17] Firmware ID: 0x37
[2025-06-01 21:20:17] Firmware Revison: 0x07
[2025-06-01 21:20:17] Current Vout=5.21V, Iout=0.15A
[2025-06-01 21:20:17] System starts up because power supply is newly connected.
[2025-06-01 21:22:22] Applying network time to system...
  Done :-)
[2025-06-01 21:22:25] Done :-)
[2025-06-01 21:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 21:22:25> Done :-)
[2025-06-01 21:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 21:22:25] Pending for incoming shutdown command...
[2025-06-01 21:22:25] Schedule next shutdown at: 2025-06-01 21:30:00
[2025-06-01 21:22:25] Schedule next startup at: 2025-06-01 21:40:00
[2025-06-01 21:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 21:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 21:40:17] Done :-)
[2025-06-01 21:40:17] Firmware ID: 0x37
[2025-06-01 21:40:17] Firmware Revison: 0x07
[2025-06-01 21:40:17] Current Vout=5.19V, Iout=0.51A
[2025-06-01 21:40:17] System starts up because power supply is newly connected.
[2025-06-01 21:42:22] Applying network time to system...
  Done :-)
[2025-06-01 21:42:25] Done :-)
[2025-06-01 21:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 21:42:25> Done :-)
[2025-06-01 21:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 21:42:25] Pending for incoming shutdown command...
[2025-06-01 21:42:25] Schedule next shutdown at: 2025-06-01 21:50:00
[2025-06-01 21:42:25] Schedule next startup at: 2025-06-01 22:00:00
[2025-06-01 21:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 21:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 22:00:17] Done :-)
[2025-06-01 22:00:17] Firmware ID: 0x37
[2025-06-01 22:00:17] Firmware Revison: 0x07
[2025-06-01 22:00:17] Current Vin=4.42V, Vout=5.19V, Iout=0.45A
[2025-06-01 22:00:17] System starts up because power supply is newly connected.
[2025-06-01 22:02:23] Applying network time to system...
  Done :-)
[2025-06-01 22:02:24] Done :-)
[2025-06-01 22:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 22:02:24> Done :-)
[2025-06-01 22:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 22:02:24] Pending for incoming shutdown command...
[2025-06-01 22:02:24] Schedule next shutdown at: 2025-06-01 22:10:00
[2025-06-01 22:02:24] Schedule next startup at: 2025-06-01 22:20:00
[2025-06-01 22:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 22:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 22:20:18] Done :-)
[2025-06-01 22:20:18] Firmware ID: 0x37
[2025-06-01 22:20:18] Firmware Revison: 0x07
[2025-06-01 22:20:18] Current Vout=5.2V, Iout=0.58A
[2025-06-01 22:20:18] System starts up because power supply is newly connected.
[2025-06-01 22:22:23] Applying network time to system...
  Done :-)
[2025-06-01 22:22:25] Done :-)
[2025-06-01 22:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 22:22:25> Done :-)
[2025-06-01 22:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 22:22:25] Pending for incoming shutdown command...
[2025-06-01 22:22:25] Schedule next shutdown at: 2025-06-01 22:30:00
[2025-06-01 22:22:25] Schedule next startup at: 2025-06-01 22:40:00
[2025-06-01 22:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-01 22:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 22:40:17] Done :-)
[2025-06-01 22:40:17] Firmware ID: 0x37
[2025-06-01 22:40:17] Firmware Revison: 0x07
[2025-06-01 22:40:17] Current Vout=5.2V, Iout=0.32A
[2025-06-01 22:40:17] System starts up because power supply is newly connected.
[2025-06-01 22:42:22] Applying network time to system...
  Done :-)
[2025-06-01 22:42:25] Done :-)
[2025-06-01 22:42:25] Writing system time to RTC...
  Done :-)
<2025-06-01 22:42:25> Done :-)
[2025-06-01 22:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 22:42:25] Pending for incoming shutdown command...
[2025-06-01 22:42:25] Schedule next shutdown at: 2025-06-01 22:50:00
[2025-06-01 22:42:25] Schedule next startup at: 2025-06-01 23:00:00
[2025-06-01 22:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 22:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 23:00:18] Done :-)
[2025-06-01 23:00:18] Firmware ID: 0x37
[2025-06-01 23:00:18] Firmware Revison: 0x07
[2025-06-01 23:00:18] Current Vout=5.2V, Iout=0.36A
[2025-06-01 23:00:18] System starts up because power supply is newly connected.
[2025-06-01 23:02:23] Applying network time to system...
  Done :-)
[2025-06-01 23:02:24] Done :-)
[2025-06-01 23:02:24] Writing system time to RTC...
  Done :-)
<2025-06-01 23:02:24> Done :-)
[2025-06-01 23:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 23:02:24] Pending for incoming shutdown command...
[2025-06-01 23:02:24] Schedule next shutdown at: 2025-06-01 23:10:00
[2025-06-01 23:02:24] Schedule next startup at: 2025-06-01 23:20:00
[2025-06-01 23:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 23:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 23:20:18] Done :-)
[2025-06-01 23:20:18] Firmware ID: 0x37
[2025-06-01 23:20:18] Firmware Revison: 0x07
[2025-06-01 23:20:18] Current Vout=5.19V, Iout=0.55A
[2025-06-01 23:20:18] System starts up because power supply is newly connected.
[2025-06-01 23:22:23] Applying network time to system...
  Done :-)
[2025-06-01 23:22:25] Done :-)
[2025-06-01 23:22:25] Writing system time to RTC...
  Done :-)
<2025-06-01 23:22:25> Done :-)
[2025-06-01 23:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 23:22:25] Pending for incoming shutdown command...
[2025-06-01 23:22:25] Schedule next shutdown at: 2025-06-01 23:30:00
[2025-06-01 23:22:25] Schedule next startup at: 2025-06-01 23:40:00
[2025-06-01 23:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 23:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-01 23:40:17] Done :-)
[2025-06-01 23:40:17] Firmware ID: 0x37
[2025-06-01 23:40:17] Firmware Revison: 0x07
[2025-06-01 23:40:17] Current Vout=5.25V, Iout=0.47A
[2025-06-01 23:40:17] System starts up because power supply is newly connected.
[2025-06-01 23:42:22] Applying network time to system...
  Done :-)
[2025-06-01 23:42:24] Done :-)
[2025-06-01 23:42:24] Writing system time to RTC...
  Done :-)
<2025-06-01 23:42:24> Done :-)
[2025-06-01 23:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-01 23:42:24] Pending for incoming shutdown command...
[2025-06-01 23:42:24] Schedule next shutdown at: 2025-06-01 23:50:00
[2025-06-01 23:42:24] Schedule next startup at: 2025-06-02 00:00:00
[2025-06-01 23:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-01 23:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 00:00:17] Done :-)
[2025-06-02 00:00:17] Firmware ID: 0x37
[2025-06-02 00:00:17] Firmware Revison: 0x07
[2025-06-02 00:00:17] Current Vin=4.36V, Vout=5.19V, Iout=0.62A
[2025-06-02 00:00:17] System starts up because power supply is newly connected.
[2025-06-02 00:02:22] Applying network time to system...
  Done :-)
[2025-06-02 00:02:25] Done :-)
[2025-06-02 00:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 00:02:25> Done :-)
[2025-06-02 00:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 00:02:25] Pending for incoming shutdown command...
[2025-06-02 00:02:25] Schedule next shutdown at: 2025-06-02 00:10:00
[2025-06-02 00:02:25] Schedule next startup at: 2025-06-02 00:20:00
[2025-06-02 00:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 00:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 00:20:18] Done :-)
[2025-06-02 00:20:18] Firmware ID: 0x37
[2025-06-02 00:20:18] Firmware Revison: 0x07
[2025-06-02 00:20:18] Current Vout=5.2V, Iout=0.12A
[2025-06-02 00:20:18] System starts up because power supply is newly connected.
[2025-06-02 00:22:23] Applying network time to system...
  Done :-)
[2025-06-02 00:22:25] Done :-)
[2025-06-02 00:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 00:22:25> Done :-)
[2025-06-02 00:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 00:22:25] Pending for incoming shutdown command...
[2025-06-02 00:22:25] Schedule next shutdown at: 2025-06-02 00:30:00
[2025-06-02 00:22:25] Schedule next startup at: 2025-06-02 00:40:00
[2025-06-02 00:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 00:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 00:40:17] Done :-)
[2025-06-02 00:40:17] Firmware ID: 0x37
[2025-06-02 00:40:17] Firmware Revison: 0x07
[2025-06-02 00:40:17] Current Vout=5.21V, Iout=0.45A
[2025-06-02 00:40:17] System starts up because power supply is newly connected.
[2025-06-02 00:42:38] Applying network time to system...
  Done :-)
[2025-06-02 00:42:40] Done :-)
[2025-06-02 00:42:40] Writing system time to RTC...
  Done :-)
<2025-06-02 00:42:40> Done :-)
[2025-06-02 00:42:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 00:42:40] Pending for incoming shutdown command...
[2025-06-02 00:42:40] Schedule next shutdown at: 2025-06-02 00:50:00
[2025-06-02 00:42:40] Schedule next startup at: 2025-06-02 01:00:00
[2025-06-02 00:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 00:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 01:00:18] Done :-)
[2025-06-02 01:00:18] Firmware ID: 0x37
[2025-06-02 01:00:18] Firmware Revison: 0x07
[2025-06-02 01:00:18] Current Vout=5.21V, Iout=0.62A
[2025-06-02 01:00:18] System starts up because power supply is newly connected.
[2025-06-02 01:02:37] Applying network time to system...
  Done :-)
[2025-06-02 01:02:39] Done :-)
[2025-06-02 01:02:39] Writing system time to RTC...
  Done :-)
<2025-06-02 01:02:39> Done :-)
[2025-06-02 01:02:39] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 01:02:39] Pending for incoming shutdown command...
[2025-06-02 01:02:39] Schedule next shutdown at: 2025-06-02 01:10:00
[2025-06-02 01:02:40] Schedule next startup at: 2025-06-02 01:20:00
[2025-06-02 01:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 01:10:00] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-06-02 01:20:17] Done :-)
[2025-06-02 01:20:17] Firmware ID: 0x37
[2025-06-02 01:20:17] Firmware Revison: 0x07
[2025-06-02 01:20:17] Current Vin=4.3V, Vout=5.2V, Iout=0.68A
[2025-06-02 01:20:17] System starts up because power supply is newly connected.
[2025-06-02 01:22:23] Applying network time to system...
  Done :-)
[2025-06-02 01:22:25] Done :-)
[2025-06-02 01:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 01:22:25> Done :-)
[2025-06-02 01:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 01:22:25] Pending for incoming shutdown command...
[2025-06-02 01:22:25] Schedule next shutdown at: 2025-06-02 01:30:00
[2025-06-02 01:22:25] Schedule next startup at: 2025-06-02 01:40:00
[2025-06-02 01:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 01:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 01:40:18] Done :-)
[2025-06-02 01:40:18] Firmware ID: 0x37
[2025-06-02 01:40:18] Firmware Revison: 0x07
[2025-06-02 01:40:18] Current Vout=5.26V, Iout=0.51A
[2025-06-02 01:40:18] System starts up because power supply is newly connected.
[2025-06-02 01:42:24] Applying network time to system...
  Done :-)
[2025-06-02 01:42:25] Done :-)
[2025-06-02 01:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 01:42:25> Done :-)
[2025-06-02 01:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 01:42:25] Pending for incoming shutdown command...
[2025-06-02 01:42:25] Schedule next shutdown at: 2025-06-02 01:50:00
[2025-06-02 01:42:25] Schedule next startup at: 2025-06-02 02:00:00
[2025-06-02 01:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 01:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 02:00:17] Done :-)
[2025-06-02 02:00:17] Firmware ID: 0x37
[2025-06-02 02:00:17] Firmware Revison: 0x07
[2025-06-02 02:00:17] Current Vout=5.25V, Iout=0.53A
[2025-06-02 02:00:17] System starts up because power supply is newly connected.
[2025-06-02 02:02:23] Applying network time to system...
  Done :-)
[2025-06-02 02:02:25] Done :-)
[2025-06-02 02:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 02:02:25> Done :-)
[2025-06-02 02:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 02:02:25] Pending for incoming shutdown command...
[2025-06-02 02:02:25] Schedule next shutdown at: 2025-06-02 02:10:00
[2025-06-02 02:02:25] Schedule next startup at: 2025-06-02 02:20:00
[2025-06-02 02:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 02:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 02:20:17] Done :-)
[2025-06-02 02:20:17] Firmware ID: 0x37
[2025-06-02 02:20:17] Firmware Revison: 0x07
[2025-06-02 02:20:17] Current Vout=5.19V, Iout=0.32A
[2025-06-02 02:20:17] System starts up because power supply is newly connected.
[2025-06-02 02:22:23] Applying network time to system...
  Done :-)
[2025-06-02 02:22:25] Done :-)
[2025-06-02 02:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 02:22:25> Done :-)
[2025-06-02 02:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 02:22:25] Pending for incoming shutdown command...
[2025-06-02 02:22:25] Schedule next shutdown at: 2025-06-02 02:30:00
[2025-06-02 02:22:26] Schedule next startup at: 2025-06-02 02:40:00
[2025-06-02 02:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 02:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 02:40:17] Done :-)
[2025-06-02 02:40:17] Firmware ID: 0x37
[2025-06-02 02:40:17] Firmware Revison: 0x07
[2025-06-02 02:40:17] Current Vout=5.15V, Iout=0.19A
[2025-06-02 02:40:17] System starts up because power supply is newly connected.
[2025-06-02 02:42:33] Applying network time to system...
  Done :-)
[2025-06-02 02:42:35] Done :-)
[2025-06-02 02:42:35] Writing system time to RTC...
  Done :-)
<2025-06-02 02:42:35> Done :-)
[2025-06-02 02:42:35] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 02:42:35] Pending for incoming shutdown command...
[2025-06-02 02:42:35] Schedule next shutdown at: 2025-06-02 02:50:00
[2025-06-02 02:42:36] Schedule next startup at: 2025-06-02 03:00:00
[2025-06-02 02:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 02:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 03:00:19] Done :-)
[2025-06-02 03:00:19] Firmware ID: 0x37
[2025-06-02 03:00:19] Firmware Revison: 0x07
[2025-06-02 03:00:19] Current Vout=5.21V, Iout=0.27A
[2025-06-02 03:00:19] System starts up because power supply is newly connected.
[2025-06-02 03:02:24] Applying network time to system...
  Done :-)
[2025-06-02 03:02:26] Done :-)
[2025-06-02 03:02:26] Writing system time to RTC...
  Done :-)
<2025-06-02 03:02:26> Done :-)
[2025-06-02 03:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 03:02:26] Pending for incoming shutdown command...
[2025-06-02 03:02:26] Schedule next shutdown at: 2025-06-02 03:10:00
[2025-06-02 03:02:26] Schedule next startup at: 2025-06-02 03:20:00
[2025-06-02 03:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 03:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 03:20:17] Done :-)
[2025-06-02 03:20:17] Firmware ID: 0x37
[2025-06-02 03:20:17] Firmware Revison: 0x07
[2025-06-02 03:20:17] Current Vout=5.25V, Iout=0.51A
[2025-06-02 03:20:17] System starts up because power supply is newly connected.
[2025-06-02 03:22:22] Applying network time to system...
  Done :-)
[2025-06-02 03:22:24] Done :-)
[2025-06-02 03:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 03:22:24> Done :-)
[2025-06-02 03:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 03:22:24] Pending for incoming shutdown command...
[2025-06-02 03:22:24] Schedule next shutdown at: 2025-06-02 03:30:00
[2025-06-02 03:22:24] Schedule next startup at: 2025-06-02 03:40:00
[2025-06-02 03:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 03:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 03:40:17] Done :-)
[2025-06-02 03:40:17] Firmware ID: 0x37
[2025-06-02 03:40:17] Firmware Revison: 0x07
[2025-06-02 03:40:17] Current Vout=5.26V, Iout=0.45A
[2025-06-02 03:40:17] System starts up because power supply is newly connected.
[2025-06-02 03:42:23] Applying network time to system...
  Done :-)
[2025-06-02 03:42:25] Done :-)
[2025-06-02 03:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 03:42:25> Done :-)
[2025-06-02 03:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 03:42:25] Pending for incoming shutdown command...
[2025-06-02 03:42:25] Schedule next shutdown at: 2025-06-02 03:50:00
[2025-06-02 03:42:25] Schedule next startup at: 2025-06-02 04:00:00
[2025-06-02 03:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 03:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 04:00:18] Done :-)
[2025-06-02 04:00:18] Firmware ID: 0x37
[2025-06-02 04:00:18] Firmware Revison: 0x07
[2025-06-02 04:00:18] Current Vout=5.2V, Iout=0.6A
[2025-06-02 04:00:18] System starts up because power supply is newly connected.
[2025-06-02 04:02:24] Applying network time to system...
  Done :-)
[2025-06-02 04:02:25] Done :-)
[2025-06-02 04:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 04:02:25> Done :-)
[2025-06-02 04:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 04:02:25] Pending for incoming shutdown command...
[2025-06-02 04:02:25] Schedule next shutdown at: 2025-06-02 04:10:00
[2025-06-02 04:02:25] Schedule next startup at: 2025-06-02 04:20:00
[2025-06-02 04:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 04:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 04:20:17] Done :-)
[2025-06-02 04:20:17] Firmware ID: 0x37
[2025-06-02 04:20:17] Firmware Revison: 0x07
[2025-06-02 04:20:17] Current Vout=5.13V, Iout=0.64A
[2025-06-02 04:20:17] System starts up because power supply is newly connected.
[2025-06-02 04:22:22] Applying network time to system...
  Done :-)
[2025-06-02 04:22:25] Done :-)
[2025-06-02 04:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 04:22:25> Done :-)
[2025-06-02 04:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 04:22:25] Pending for incoming shutdown command...
[2025-06-02 04:22:25] Schedule next shutdown at: 2025-06-02 04:30:00
[2025-06-02 04:22:26] Schedule next startup at: 2025-06-02 04:40:00
[2025-06-02 04:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 04:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 04:40:17] Done :-)
[2025-06-02 04:40:17] Firmware ID: 0x37
[2025-06-02 04:40:17] Firmware Revison: 0x07
[2025-06-02 04:40:17] Current Vout=5.2V, Iout=0.3A
[2025-06-02 04:40:17] System starts up because power supply is newly connected.
[2025-06-02 04:42:22] Applying network time to system...
  Done :-)
[2025-06-02 04:42:25] Done :-)
[2025-06-02 04:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 04:42:25> Done :-)
[2025-06-02 04:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 04:42:25] Pending for incoming shutdown command...
[2025-06-02 04:42:25] Schedule next shutdown at: 2025-06-02 04:50:00
[2025-06-02 04:42:25] Schedule next startup at: 2025-06-02 05:00:00
[2025-06-02 04:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 04:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 05:00:17] Done :-)
[2025-06-02 05:00:17] Firmware ID: 0x37
[2025-06-02 05:00:17] Firmware Revison: 0x07
[2025-06-02 05:00:17] Current Vin=4.55V, Vout=5.19V, Iout=0.34A
[2025-06-02 05:00:17] System starts up because power supply is newly connected.
[2025-06-02 05:02:34] Applying network time to system...
  Done :-)
[2025-06-02 05:02:35] Done :-)
[2025-06-02 05:02:35] Writing system time to RTC...
  Done :-)
<2025-06-02 05:02:35> Done :-)
[2025-06-02 05:02:35] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 05:02:35] Pending for incoming shutdown command...
[2025-06-02 05:02:35] Schedule next shutdown at: 2025-06-02 05:10:00
[2025-06-02 05:02:36] Schedule next startup at: 2025-06-02 05:20:00
[2025-06-02 05:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 05:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 05:20:17] Done :-)
[2025-06-02 05:20:17] Firmware ID: 0x37
[2025-06-02 05:20:17] Firmware Revison: 0x07
[2025-06-02 05:20:17] Current Vin=4.18V, Vout=5.2V, Iout=0.53A
[2025-06-02 05:20:17] System starts up because power supply is newly connected.
[2025-06-02 05:22:23] Applying network time to system...
  Done :-)
[2025-06-02 05:22:25] Done :-)
[2025-06-02 05:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 05:22:25> Done :-)
[2025-06-02 05:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 05:22:25] Pending for incoming shutdown command...
[2025-06-02 05:22:25] Schedule next shutdown at: 2025-06-02 05:30:00
[2025-06-02 05:22:25] Schedule next startup at: 2025-06-02 05:40:00
[2025-06-02 05:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 05:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 05:40:18] Done :-)
[2025-06-02 05:40:18] Firmware ID: 0x37
[2025-06-02 05:40:18] Firmware Revison: 0x07
[2025-06-02 05:40:18] Current Vout=5.25V, Iout=0.64A
[2025-06-02 05:40:18] System starts up because power supply is newly connected.
[2025-06-02 05:42:23] Applying network time to system...
  Done :-)
[2025-06-02 05:42:25] Done :-)
[2025-06-02 05:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 05:42:25> Done :-)
[2025-06-02 05:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 05:42:25] Pending for incoming shutdown command...
[2025-06-02 05:42:25] Schedule next shutdown at: 2025-06-02 05:50:00
[2025-06-02 05:42:25] Schedule next startup at: 2025-06-02 06:00:00
[2025-06-02 05:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 05:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 06:00:17] Done :-)
[2025-06-02 06:00:17] Firmware ID: 0x37
[2025-06-02 06:00:17] Firmware Revison: 0x07
[2025-06-02 06:00:17] Current Vin=4.49V, Vout=5.19V, Iout=0.62A
[2025-06-02 06:00:17] System starts up because power supply is newly connected.
[2025-06-02 06:02:23] Applying network time to system...
  Done :-)
[2025-06-02 06:02:24] Done :-)
[2025-06-02 06:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 06:02:24> Done :-)
[2025-06-02 06:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 06:02:24] Pending for incoming shutdown command...
[2025-06-02 06:02:24] Schedule next shutdown at: 2025-06-02 06:10:00
[2025-06-02 06:02:24] Schedule next startup at: 2025-06-02 06:20:00
[2025-06-02 06:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 06:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 06:20:17] Done :-)
[2025-06-02 06:20:17] Firmware ID: 0x37
[2025-06-02 06:20:17] Firmware Revison: 0x07
[2025-06-02 06:20:17] Current Vout=5.14V, Iout=0.68A
[2025-06-02 06:20:17] System starts up because power supply is newly connected.
[2025-06-02 06:22:23] Applying network time to system...
  Done :-)
[2025-06-02 06:22:24] Done :-)
[2025-06-02 06:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 06:22:24> Done :-)
[2025-06-02 06:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 06:22:24] Pending for incoming shutdown command...
[2025-06-02 06:22:24] Schedule next shutdown at: 2025-06-02 06:30:00
[2025-06-02 06:22:24] Schedule next startup at: 2025-06-02 06:40:00
[2025-06-02 06:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 06:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 06:40:18] Done :-)
[2025-06-02 06:40:18] Firmware ID: 0x37
[2025-06-02 06:40:18] Firmware Revison: 0x07
[2025-06-02 06:40:18] Current Vout=5.14V, Iout=0.53A
[2025-06-02 06:40:18] System starts up because power supply is newly connected.
[2025-06-02 06:42:23] Applying network time to system...
  Done :-)
[2025-06-02 06:42:26] Done :-)
[2025-06-02 06:42:26] Writing system time to RTC...
  Done :-)
<2025-06-02 06:42:26> Done :-)
[2025-06-02 06:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 06:42:26] Pending for incoming shutdown command...
[2025-06-02 06:42:26] Schedule next shutdown at: 2025-06-02 06:50:00
[2025-06-02 06:42:26] Schedule next startup at: 2025-06-02 07:00:00
[2025-06-02 06:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 06:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 07:00:18] Done :-)
[2025-06-02 07:00:18] Firmware ID: 0x37
[2025-06-02 07:00:18] Firmware Revison: 0x07
[2025-06-02 07:00:18] Current Vout=5.25V, Iout=0.43A
[2025-06-02 07:00:18] System starts up because power supply is newly connected.
[2025-06-02 07:02:40] Applying network time to system...
  Done :-)
[2025-06-02 07:02:41] Done :-)
[2025-06-02 07:02:41] Writing system time to RTC...
  Done :-)
<2025-06-02 07:02:41> Done :-)
[2025-06-02 07:02:41] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 07:02:41] Pending for incoming shutdown command...
[2025-06-02 07:02:41] Schedule next shutdown at: 2025-06-02 07:10:00
[2025-06-02 07:02:41] Schedule next startup at: 2025-06-02 07:20:00
[2025-06-02 07:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 07:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 07:20:17] Done :-)
[2025-06-02 07:20:17] Firmware ID: 0x37
[2025-06-02 07:20:17] Firmware Revison: 0x07
[2025-06-02 07:20:17] Current Vout=5.19V, Iout=0.47A
[2025-06-02 07:20:17] System starts up because power supply is newly connected.
[2025-06-02 07:22:22] Applying network time to system...
  Done :-)
[2025-06-02 07:22:25] Done :-)
[2025-06-02 07:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 07:22:25> Done :-)
[2025-06-02 07:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 07:22:25] Pending for incoming shutdown command...
[2025-06-02 07:22:25] Schedule next shutdown at: 2025-06-02 07:30:00
[2025-06-02 07:22:25] Schedule next startup at: 2025-06-02 07:40:00
[2025-06-02 07:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 07:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 07:40:17] Done :-)
[2025-06-02 07:40:17] Firmware ID: 0x37
[2025-06-02 07:40:17] Firmware Revison: 0x07
[2025-06-02 07:40:17] Current Vout=5.26V, Iout=0.12A
[2025-06-02 07:40:17] System starts up because power supply is newly connected.
[2025-06-02 07:42:36] Applying network time to system...
  Done :-)
[2025-06-02 07:42:38] Done :-)
[2025-06-02 07:42:38] Writing system time to RTC...
  Done :-)
<2025-06-02 07:42:38> Done :-)
[2025-06-02 07:42:38] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 07:42:38] Pending for incoming shutdown command...
[2025-06-02 07:42:38] Schedule next shutdown at: 2025-06-02 07:50:00
[2025-06-02 07:42:38] Schedule next startup at: 2025-06-02 08:00:00
[2025-06-02 07:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 07:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 08:00:17] Done :-)
[2025-06-02 08:00:17] Firmware ID: 0x37
[2025-06-02 08:00:17] Firmware Revison: 0x07
[2025-06-02 08:00:17] Current Vout=5.21V, Iout=0.4A
[2025-06-02 08:00:17] System starts up because power supply is newly connected.
[2025-06-02 08:02:22] Applying network time to system...
  Done :-)
[2025-06-02 08:02:24] Done :-)
[2025-06-02 08:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 08:02:24> Done :-)
[2025-06-02 08:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 08:02:24] Pending for incoming shutdown command...
[2025-06-02 08:02:24] Schedule next shutdown at: 2025-06-02 08:10:00
[2025-06-02 08:02:24] Schedule next startup at: 2025-06-02 08:20:00
[2025-06-02 08:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 08:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 08:20:17] Done :-)
[2025-06-02 08:20:17] Firmware ID: 0x37
[2025-06-02 08:20:17] Firmware Revison: 0x07
[2025-06-02 08:20:17] Current Vout=5.19V, Iout=0.73A
[2025-06-02 08:20:17] System starts up because power supply is newly connected.
[2025-06-02 08:22:23] Applying network time to system...
  Done :-)
[2025-06-02 08:22:24] Done :-)
[2025-06-02 08:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 08:22:24> Done :-)
[2025-06-02 08:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 08:22:24] Pending for incoming shutdown command...
[2025-06-02 08:22:24] Schedule next shutdown at: 2025-06-02 08:30:00
[2025-06-02 08:22:24] Schedule next startup at: 2025-06-02 08:40:00
[2025-06-02 08:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 08:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 08:40:18] Done :-)
[2025-06-02 08:40:18] Firmware ID: 0x37
[2025-06-02 08:40:18] Firmware Revison: 0x07
[2025-06-02 08:40:18] Current Vout=5.19V, Iout=0.6A
[2025-06-02 08:40:18] System starts up because power supply is newly connected.
[2025-06-02 08:42:23] Applying network time to system...
  Done :-)
[2025-06-02 08:42:25] Done :-)
[2025-06-02 08:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 08:42:25> Done :-)
[2025-06-02 08:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 08:42:25] Pending for incoming shutdown command...
[2025-06-02 08:42:25] Schedule next shutdown at: 2025-06-02 08:50:00
[2025-06-02 08:42:25] Schedule next startup at: 2025-06-02 09:00:00
[2025-06-02 08:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 08:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 09:00:17] Done :-)
[2025-06-02 09:00:17] Firmware ID: 0x37
[2025-06-02 09:00:17] Firmware Revison: 0x07
[2025-06-02 09:00:17] Current Vout=5.2V, Iout=0.51A
[2025-06-02 09:00:17] System starts up because power supply is newly connected.
[2025-06-02 09:02:22] Applying network time to system...
  Done :-)
[2025-06-02 09:02:25] Done :-)
[2025-06-02 09:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 09:02:25> Done :-)
[2025-06-02 09:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 09:02:25] Pending for incoming shutdown command...
[2025-06-02 09:02:25] Schedule next shutdown at: 2025-06-02 09:10:00
[2025-06-02 09:02:25] Schedule next startup at: 2025-06-02 09:20:00
[2025-06-02 09:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 09:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 09:20:17] Done :-)
[2025-06-02 09:20:17] Firmware ID: 0x37
[2025-06-02 09:20:17] Firmware Revison: 0x07
[2025-06-02 09:20:17] Current Vout=5.2V, Iout=0.38A
[2025-06-02 09:20:17] System starts up because power supply is newly connected.
[2025-06-02 09:22:22] Applying network time to system...
  Done :-)
[2025-06-02 09:22:24] Done :-)
[2025-06-02 09:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 09:22:24> Done :-)
[2025-06-02 09:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 09:22:24] Pending for incoming shutdown command...
[2025-06-02 09:22:24] Schedule next shutdown at: 2025-06-02 09:30:00
[2025-06-02 09:22:24] Schedule next startup at: 2025-06-02 09:40:00
[2025-06-02 09:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 09:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 09:40:17] Done :-)
[2025-06-02 09:40:17] Firmware ID: 0x37
[2025-06-02 09:40:17] Firmware Revison: 0x07
[2025-06-02 09:40:17] Current Vout=5.19V, Iout=0.45A
[2025-06-02 09:40:17] System starts up because power supply is newly connected.
[2025-06-02 09:42:22] Applying network time to system...
  Done :-)
[2025-06-02 09:42:24] Done :-)
[2025-06-02 09:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 09:42:24> Done :-)
[2025-06-02 09:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 09:42:24] Pending for incoming shutdown command...
[2025-06-02 09:42:24] Schedule next shutdown at: 2025-06-02 09:50:00
[2025-06-02 09:42:24] Schedule next startup at: 2025-06-02 10:00:00
[2025-06-02 09:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 09:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 10:00:18] Done :-)
[2025-06-02 10:00:18] Firmware ID: 0x37
[2025-06-02 10:00:18] Firmware Revison: 0x07
[2025-06-02 10:00:18] Current Vout=5.2V, Iout=0.58A
[2025-06-02 10:00:18] System starts up because power supply is newly connected.
[2025-06-02 10:02:23] Applying network time to system...
  Done :-)
[2025-06-02 10:02:25] Done :-)
[2025-06-02 10:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 10:02:25> Done :-)
[2025-06-02 10:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 10:02:25] Pending for incoming shutdown command...
[2025-06-02 10:02:25] Schedule next shutdown at: 2025-06-02 10:10:00
[2025-06-02 10:02:25] Schedule next startup at: 2025-06-02 10:20:00
[2025-06-02 10:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 10:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 10:20:17] Done :-)
[2025-06-02 10:20:17] Firmware ID: 0x37
[2025-06-02 10:20:17] Firmware Revison: 0x07
[2025-06-02 10:20:17] Current Vin=4.49V, Vout=5.19V, Iout=0.53A
[2025-06-02 10:20:17] System starts up because power supply is newly connected.
[2025-06-02 10:22:22] Applying network time to system...
  Done :-)
[2025-06-02 10:22:25] Done :-)
[2025-06-02 10:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 10:22:25> Done :-)
[2025-06-02 10:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 10:22:25] Pending for incoming shutdown command...
[2025-06-02 10:22:25] Schedule next shutdown at: 2025-06-02 10:30:00
[2025-06-02 10:22:25] Schedule next startup at: 2025-06-02 10:40:00
[2025-06-02 10:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 10:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 10:40:17] Done :-)
[2025-06-02 10:40:17] Firmware ID: 0x37
[2025-06-02 10:40:17] Firmware Revison: 0x07
[2025-06-02 10:40:17] Current Vin=4.3V, Vout=5.2V, Iout=0.66A
[2025-06-02 10:40:17] System starts up because power supply is newly connected.
[2025-06-02 10:42:22] Applying network time to system...
  Done :-)
[2025-06-02 10:42:24] Done :-)
[2025-06-02 10:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 10:42:24> Done :-)
[2025-06-02 10:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 10:42:24] Pending for incoming shutdown command...
[2025-06-02 10:42:24] Schedule next shutdown at: 2025-06-02 10:50:00
[2025-06-02 10:42:24] Schedule next startup at: 2025-06-02 11:00:00
[2025-06-02 10:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 10:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 11:00:17] Done :-)
[2025-06-02 11:00:17] Firmware ID: 0x37
[2025-06-02 11:00:17] Firmware Revison: 0x07
[2025-06-02 11:00:17] Current Vout=5.21V, Iout=0.25A
[2025-06-02 11:00:17] System starts up because power supply is newly connected.
[2025-06-02 11:02:23] Applying network time to system...
  Done :-)
[2025-06-02 11:02:25] Done :-)
[2025-06-02 11:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 11:02:25> Done :-)
[2025-06-02 11:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 11:02:25] Pending for incoming shutdown command...
[2025-06-02 11:02:25] Schedule next shutdown at: 2025-06-02 11:10:00
[2025-06-02 11:02:25] Schedule next startup at: 2025-06-02 11:20:00
[2025-06-02 11:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 11:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 11:20:17] Done :-)
[2025-06-02 11:20:17] Firmware ID: 0x37
[2025-06-02 11:20:17] Firmware Revison: 0x07
[2025-06-02 11:20:17] Current Vout=5.19V, Iout=0.34A
[2025-06-02 11:20:17] System starts up because power supply is newly connected.
[2025-06-02 11:22:22] Applying network time to system...
  Done :-)
[2025-06-02 11:22:25] Done :-)
[2025-06-02 11:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 11:22:25> Done :-)
[2025-06-02 11:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 11:22:25] Pending for incoming shutdown command...
[2025-06-02 11:22:25] Schedule next shutdown at: 2025-06-02 11:30:00
[2025-06-02 11:22:25] Schedule next startup at: 2025-06-02 11:40:00
[2025-06-02 11:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 11:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 11:40:18] Done :-)
[2025-06-02 11:40:18] Firmware ID: 0x37
[2025-06-02 11:40:18] Firmware Revison: 0x07
[2025-06-02 11:40:18] Current Vout=5.19V, Iout=0.38A
[2025-06-02 11:40:18] System starts up because power supply is newly connected.
[2025-06-02 11:42:23] Applying network time to system...
  Done :-)
[2025-06-02 11:42:25] Done :-)
[2025-06-02 11:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 11:42:25> Done :-)
[2025-06-02 11:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 11:42:25] Pending for incoming shutdown command...
[2025-06-02 11:42:25] Schedule next shutdown at: 2025-06-02 11:50:00
[2025-06-02 11:42:25] Schedule next startup at: 2025-06-02 12:00:00
[2025-06-02 11:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 11:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 12:00:18] Done :-)
[2025-06-02 12:00:18] Firmware ID: 0x37
[2025-06-02 12:00:18] Firmware Revison: 0x07
[2025-06-02 12:00:18] Current Vout=5.19V, Iout=0.53A
[2025-06-02 12:00:18] System starts up because power supply is newly connected.
[2025-06-02 12:02:39] Applying network time to system...
  Done :-)
[2025-06-02 12:02:40] Done :-)
[2025-06-02 12:02:40] Writing system time to RTC...
  Done :-)
<2025-06-02 12:02:40> Done :-)
[2025-06-02 12:02:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 12:02:40] Pending for incoming shutdown command...
[2025-06-02 12:02:40] Schedule next shutdown at: 2025-06-02 12:10:00
[2025-06-02 12:02:40] Schedule next startup at: 2025-06-02 12:20:00
[2025-06-02 12:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 12:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 12:20:17] Done :-)
[2025-06-02 12:20:17] Firmware ID: 0x37
[2025-06-02 12:20:17] Firmware Revison: 0x07
[2025-06-02 12:20:17] Current Vin=4.3V, Vout=5.19V, Iout=0.32A
[2025-06-02 12:20:17] System starts up because power supply is newly connected.
[2025-06-02 12:22:39] Applying network time to system...
  Done :-)
[2025-06-02 12:22:40] Done :-)
[2025-06-02 12:22:40] Writing system time to RTC...
  Done :-)
<2025-06-02 12:22:40> Done :-)
[2025-06-02 12:22:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 12:22:40] Pending for incoming shutdown command...
[2025-06-02 12:22:40] Schedule next shutdown at: 2025-06-02 12:30:00
[2025-06-02 12:22:41] Schedule next startup at: 2025-06-02 12:40:00
[2025-06-02 12:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 12:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 12:40:17] Done :-)
[2025-06-02 12:40:17] Firmware ID: 0x37
[2025-06-02 12:40:17] Firmware Revison: 0x07
[2025-06-02 12:40:17] Current Vout=5.2V, Iout=0.6A
[2025-06-02 12:40:17] System starts up because power supply is newly connected.
[2025-06-02 12:42:28] Applying network time to system...
  Done :-)
[2025-06-02 12:42:31] Done :-)
[2025-06-02 12:42:31] Writing system time to RTC...
  Done :-)
<2025-06-02 12:42:31> Done :-)
[2025-06-02 12:42:31] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 12:42:31] Pending for incoming shutdown command...
[2025-06-02 12:42:31] Schedule next shutdown at: 2025-06-02 12:50:00
[2025-06-02 12:42:31] Schedule next startup at: 2025-06-02 13:00:00
[2025-06-02 12:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 12:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 13:00:18] Done :-)
[2025-06-02 13:00:18] Firmware ID: 0x37
[2025-06-02 13:00:18] Firmware Revison: 0x07
[2025-06-02 13:00:18] Current Vout=5.19V, Iout=0.55A
[2025-06-02 13:00:18] System starts up because power supply is newly connected.
[2025-06-02 13:02:34] Applying network time to system...
  Done :-)
[2025-06-02 13:02:35] Done :-)
[2025-06-02 13:02:35] Writing system time to RTC...
  Done :-)
<2025-06-02 13:02:35> Done :-)
[2025-06-02 13:02:35] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 13:02:35] Pending for incoming shutdown command...
[2025-06-02 13:02:35] Schedule next shutdown at: 2025-06-02 13:10:00
[2025-06-02 13:02:35] Schedule next startup at: 2025-06-02 13:20:00
[2025-06-02 13:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 13:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 13:20:17] Done :-)
[2025-06-02 13:20:17] Firmware ID: 0x37
[2025-06-02 13:20:17] Firmware Revison: 0x07
[2025-06-02 13:20:17] Current Vout=5.19V, Iout=0.4A
[2025-06-02 13:20:17] System starts up because power supply is newly connected.
[2025-06-02 13:22:33] Applying network time to system...
  Done :-)
[2025-06-02 13:22:35] Done :-)
[2025-06-02 13:22:35] Writing system time to RTC...
  Done :-)
<2025-06-02 13:22:35> Done :-)
[2025-06-02 13:22:35] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 13:22:35] Pending for incoming shutdown command...
[2025-06-02 13:22:35] Schedule next shutdown at: 2025-06-02 13:30:00
[2025-06-02 13:22:35] Schedule next startup at: 2025-06-02 13:40:00
[2025-06-02 13:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 13:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 13:40:18] Done :-)
[2025-06-02 13:40:18] Firmware ID: 0x37
[2025-06-02 13:40:18] Firmware Revison: 0x07
[2025-06-02 13:40:18] Current Vin=4.49V, Vout=5.26V, Iout=0.19A
[2025-06-02 13:40:18] System starts up because power supply is newly connected.
[2025-06-02 13:42:24] Applying network time to system...
  Done :-)
[2025-06-02 13:42:26] Done :-)
[2025-06-02 13:42:26] Writing system time to RTC...
  Done :-)
<2025-06-02 13:42:26> Done :-)
[2025-06-02 13:42:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 13:42:26] Pending for incoming shutdown command...
[2025-06-02 13:42:26] Schedule next shutdown at: 2025-06-02 13:50:00
[2025-06-02 13:42:26] Schedule next startup at: 2025-06-02 14:00:00
[2025-06-02 13:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 13:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 14:00:18] Done :-)
[2025-06-02 14:00:18] Firmware ID: 0x37
[2025-06-02 14:00:18] Firmware Revison: 0x07
[2025-06-02 14:00:18] Current Vout=5.32V, Iout=0.45A
[2025-06-02 14:00:18] System starts up because power supply is newly connected.
[2025-06-02 14:02:23] Applying network time to system...
  Done :-)
[2025-06-02 14:02:24] Done :-)
[2025-06-02 14:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 14:02:24> Done :-)
[2025-06-02 14:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 14:02:24] Pending for incoming shutdown command...
[2025-06-02 14:02:24] Schedule next shutdown at: 2025-06-02 14:10:00
[2025-06-02 14:02:24] Schedule next startup at: 2025-06-02 14:20:00
[2025-06-02 14:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 14:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 14:20:18] Done :-)
[2025-06-02 14:20:18] Firmware ID: 0x37
[2025-06-02 14:20:18] Firmware Revison: 0x07
[2025-06-02 14:20:18] Current Vin=4.24V, Vout=5.13V, Iout=0.3A
[2025-06-02 14:20:18] System starts up because power supply is newly connected.
[2025-06-02 14:22:24] Applying network time to system...
  Done :-)
[2025-06-02 14:22:26] Done :-)
[2025-06-02 14:22:26] Writing system time to RTC...
  Done :-)
<2025-06-02 14:22:26> Done :-)
[2025-06-02 14:22:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 14:22:26] Pending for incoming shutdown command...
[2025-06-02 14:22:26] Schedule next shutdown at: 2025-06-02 14:30:00
[2025-06-02 14:22:26] Schedule next startup at: 2025-06-02 14:40:00
[2025-06-02 14:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 14:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 14:40:18] Done :-)
[2025-06-02 14:40:18] Firmware ID: 0x37
[2025-06-02 14:40:18] Firmware Revison: 0x07
[2025-06-02 14:40:18] Current Vout=5.2V, Iout=0.08A
[2025-06-02 14:40:18] System starts up because power supply is newly connected.
[2025-06-02 14:42:23] Applying network time to system...
  Done :-)
[2025-06-02 14:42:25] Done :-)
[2025-06-02 14:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 14:42:25> Done :-)
[2025-06-02 14:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 14:42:25] Pending for incoming shutdown command...
[2025-06-02 14:42:25] Schedule next shutdown at: 2025-06-02 14:50:00
[2025-06-02 14:42:25] Schedule next startup at: 2025-06-02 15:00:00
[2025-06-02 14:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 14:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 15:00:18] Done :-)
[2025-06-02 15:00:18] Firmware ID: 0x37
[2025-06-02 15:00:18] Firmware Revison: 0x07
[2025-06-02 15:00:18] Current Vout=5.19V, Iout=0.49A
[2025-06-02 15:00:18] System starts up because power supply is newly connected.
[2025-06-02 15:02:24] Applying network time to system...
  Done :-)
[2025-06-02 15:02:25] Done :-)
[2025-06-02 15:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 15:02:25> Done :-)
[2025-06-02 15:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 15:02:25] Pending for incoming shutdown command...
[2025-06-02 15:02:25] Schedule next shutdown at: 2025-06-02 15:10:00
[2025-06-02 15:02:25] Schedule next startup at: 2025-06-02 15:20:00
[2025-06-02 15:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 15:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 15:20:17] Done :-)
[2025-06-02 15:20:17] Firmware ID: 0x37
[2025-06-02 15:20:17] Firmware Revison: 0x07
[2025-06-02 15:20:17] Current Vout=5.2V, Iout=0.53A
[2025-06-02 15:20:17] System starts up because power supply is newly connected.
[2025-06-02 15:22:22] Applying network time to system...
  Done :-)
[2025-06-02 15:22:24] Done :-)
[2025-06-02 15:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 15:22:24> Done :-)
[2025-06-02 15:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 15:22:24] Pending for incoming shutdown command...
[2025-06-02 15:22:24] Schedule next shutdown at: 2025-06-02 15:30:00
[2025-06-02 15:22:24] Schedule next startup at: 2025-06-02 15:40:00
[2025-06-02 15:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 15:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 15:40:17] Done :-)
[2025-06-02 15:40:17] Firmware ID: 0x37
[2025-06-02 15:40:17] Firmware Revison: 0x07
[2025-06-02 15:40:17] Current Vout=5.2V, Iout=0.58A
[2025-06-02 15:40:17] System starts up because power supply is newly connected.
[2025-06-02 15:42:22] Applying network time to system...
  Done :-)
[2025-06-02 15:42:24] Done :-)
[2025-06-02 15:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 15:42:24> Done :-)
[2025-06-02 15:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 15:42:24] Pending for incoming shutdown command...
[2025-06-02 15:42:24] Schedule next shutdown at: 2025-06-02 15:50:00
[2025-06-02 15:42:24] Schedule next startup at: 2025-06-02 16:00:00
[2025-06-02 15:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 15:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 16:00:17] Done :-)
[2025-06-02 16:00:17] Firmware ID: 0x37
[2025-06-02 16:00:17] Firmware Revison: 0x07
[2025-06-02 16:00:17] Current Vout=5.2V, Iout=0.32A
[2025-06-02 16:00:17] System starts up because power supply is newly connected.
[2025-06-02 16:02:22] Applying network time to system...
  Done :-)
[2025-06-02 16:02:24] Done :-)
[2025-06-02 16:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 16:02:24> Done :-)
[2025-06-02 16:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 16:02:24] Pending for incoming shutdown command...
[2025-06-02 16:02:24] Schedule next shutdown at: 2025-06-02 16:10:00
[2025-06-02 16:02:24] Schedule next startup at: 2025-06-02 16:20:00
[2025-06-02 16:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 16:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 16:20:17] Done :-)
[2025-06-02 16:20:17] Firmware ID: 0x37
[2025-06-02 16:20:17] Firmware Revison: 0x07
[2025-06-02 16:20:17] Current Vout=5.2V, Iout=0.15A
[2025-06-02 16:20:17] System starts up because power supply is newly connected.
[2025-06-02 16:22:22] Applying network time to system...
  Done :-)
[2025-06-02 16:22:25] Done :-)
[2025-06-02 16:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 16:22:25> Done :-)
[2025-06-02 16:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 16:22:25] Pending for incoming shutdown command...
[2025-06-02 16:22:25] Schedule next shutdown at: 2025-06-02 16:30:00
[2025-06-02 16:22:25] Schedule next startup at: 2025-06-02 16:40:00
[2025-06-02 16:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 16:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 16:40:17] Done :-)
[2025-06-02 16:40:17] Firmware ID: 0x37
[2025-06-02 16:40:17] Firmware Revison: 0x07
[2025-06-02 16:40:17] Current Vout=5.2V, Iout=0.15A
[2025-06-02 16:40:17] System starts up because power supply is newly connected.
[2025-06-02 16:42:22] Applying network time to system...
  Done :-)
[2025-06-02 16:42:24] Done :-)
[2025-06-02 16:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 16:42:24> Done :-)
[2025-06-02 16:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 16:42:24] Pending for incoming shutdown command...
[2025-06-02 16:42:24] Schedule next shutdown at: 2025-06-02 16:50:00
[2025-06-02 16:42:24] Schedule next startup at: 2025-06-02 17:00:00
[2025-06-02 16:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 16:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 17:00:17] Done :-)
[2025-06-02 17:00:17] Firmware ID: 0x37
[2025-06-02 17:00:17] Firmware Revison: 0x07
[2025-06-02 17:00:17] Current Vout=5.2V, Iout=0.36A
[2025-06-02 17:00:17] System starts up because power supply is newly connected.
[2025-06-02 17:02:23] Applying network time to system...
  Done :-)
[2025-06-02 17:02:24] Done :-)
[2025-06-02 17:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 17:02:24> Done :-)
[2025-06-02 17:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 17:02:24] Pending for incoming shutdown command...
[2025-06-02 17:02:24] Schedule next shutdown at: 2025-06-02 17:10:00
[2025-06-02 17:02:24] Schedule next startup at: 2025-06-02 17:20:00
[2025-06-02 17:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 17:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 17:20:18] Done :-)
[2025-06-02 17:20:18] Firmware ID: 0x37
[2025-06-02 17:20:18] Firmware Revison: 0x07
[2025-06-02 17:20:18] Current Vout=5.19V, Iout=0.55A
[2025-06-02 17:20:18] System starts up because power supply is newly connected.
[2025-06-02 17:22:24] Applying network time to system...
  Done :-)
[2025-06-02 17:22:25] Done :-)
[2025-06-02 17:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 17:22:25> Done :-)
[2025-06-02 17:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 17:22:25] Pending for incoming shutdown command...
[2025-06-02 17:22:25] Schedule next shutdown at: 2025-06-02 17:30:00
[2025-06-02 17:22:25] Schedule next startup at: 2025-06-02 17:40:00
[2025-06-02 17:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 17:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 17:40:17] Done :-)
[2025-06-02 17:40:17] Firmware ID: 0x37
[2025-06-02 17:40:17] Firmware Revison: 0x07
[2025-06-02 17:40:17] Current Vout=5.19V, Iout=0.4A
[2025-06-02 17:40:17] System starts up because power supply is newly connected.
[2025-06-02 17:42:23] Applying network time to system...
  Done :-)
[2025-06-02 17:42:25] Done :-)
[2025-06-02 17:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 17:42:25> Done :-)
[2025-06-02 17:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 17:42:25] Pending for incoming shutdown command...
[2025-06-02 17:42:25] Schedule next shutdown at: 2025-06-02 17:50:00
[2025-06-02 17:42:25] Schedule next startup at: 2025-06-02 18:00:00
[2025-06-02 17:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 17:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 18:00:17] Done :-)
[2025-06-02 18:00:17] Firmware ID: 0x37
[2025-06-02 18:00:17] Firmware Revison: 0x07
[2025-06-02 18:00:17] Current Vout=5.26V, Iout=0.3A
[2025-06-02 18:00:17] System starts up because power supply is newly connected.
[2025-06-02 18:02:22] Applying network time to system...
  Done :-)
[2025-06-02 18:02:25] Done :-)
[2025-06-02 18:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 18:02:25> Done :-)
[2025-06-02 18:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 18:02:25] Pending for incoming shutdown command...
[2025-06-02 18:02:25] Schedule next shutdown at: 2025-06-02 18:10:00
[2025-06-02 18:02:25] Schedule next startup at: 2025-06-02 18:20:00
[2025-06-02 18:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 18:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 18:20:17] Done :-)
[2025-06-02 18:20:17] Firmware ID: 0x37
[2025-06-02 18:20:17] Firmware Revison: 0x07
[2025-06-02 18:20:17] Current Vout=5.26V, Iout=0.34A
[2025-06-02 18:20:17] System starts up because power supply is newly connected.
[2025-06-02 18:22:23] Applying network time to system...
  Done :-)
[2025-06-02 18:22:25] Done :-)
[2025-06-02 18:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 18:22:25> Done :-)
[2025-06-02 18:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 18:22:25] Pending for incoming shutdown command...
[2025-06-02 18:22:25] Schedule next shutdown at: 2025-06-02 18:30:00
[2025-06-02 18:22:25] Schedule next startup at: 2025-06-02 18:40:00
[2025-06-02 18:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 18:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 18:40:17] Done :-)
[2025-06-02 18:40:17] Firmware ID: 0x37
[2025-06-02 18:40:17] Firmware Revison: 0x07
[2025-06-02 18:40:17] Current Vout=5.14V, Iout=0.34A
[2025-06-02 18:40:17] System starts up because power supply is newly connected.
[2025-06-02 18:42:22] Applying network time to system...
  Done :-)
[2025-06-02 18:42:25] Done :-)
[2025-06-02 18:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 18:42:25> Done :-)
[2025-06-02 18:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 18:42:25] Pending for incoming shutdown command...
[2025-06-02 18:42:25] Schedule next shutdown at: 2025-06-02 18:50:00
[2025-06-02 18:42:25] Schedule next startup at: 2025-06-02 19:00:00
[2025-06-02 18:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 18:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 19:00:18] Done :-)
[2025-06-02 19:00:18] Firmware ID: 0x37
[2025-06-02 19:00:18] Firmware Revison: 0x07
[2025-06-02 19:00:18] Current Vin=4.42V, Vout=5.2V, Iout=0.36A
[2025-06-02 19:00:18] System starts up because power supply is newly connected.
[2025-06-02 19:02:24] Applying network time to system...
  Done :-)
[2025-06-02 19:02:25] Done :-)
[2025-06-02 19:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 19:02:25> Done :-)
[2025-06-02 19:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 19:02:25] Pending for incoming shutdown command...
[2025-06-02 19:02:25] Schedule next shutdown at: 2025-06-02 19:10:00
[2025-06-02 19:02:25] Schedule next startup at: 2025-06-02 19:20:00
[2025-06-02 19:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 19:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 19:20:17] Done :-)
[2025-06-02 19:20:17] Firmware ID: 0x37
[2025-06-02 19:20:17] Firmware Revison: 0x07
[2025-06-02 19:20:17] Current Vout=5.2V, Iout=0.32A
[2025-06-02 19:20:17] System starts up because power supply is newly connected.
[2025-06-02 19:22:22] Applying network time to system...
  Done :-)
[2025-06-02 19:22:24] Done :-)
[2025-06-02 19:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 19:22:24> Done :-)
[2025-06-02 19:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 19:22:24] Pending for incoming shutdown command...
[2025-06-02 19:22:24] Schedule next shutdown at: 2025-06-02 19:30:00
[2025-06-02 19:22:24] Schedule next startup at: 2025-06-02 19:40:00
[2025-06-02 19:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 19:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 19:40:18] Done :-)
[2025-06-02 19:40:18] Firmware ID: 0x37
[2025-06-02 19:40:18] Firmware Revison: 0x07
[2025-06-02 19:40:18] Current Vin=4.49V, Vout=5.13V, Iout=0.53A
[2025-06-02 19:40:18] System starts up because power supply is newly connected.
[2025-06-02 19:42:24] Applying network time to system...
  Done :-)
[2025-06-02 19:42:25] Done :-)
[2025-06-02 19:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 19:42:25> Done :-)
[2025-06-02 19:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 19:42:25] Pending for incoming shutdown command...
[2025-06-02 19:42:25] Schedule next shutdown at: 2025-06-02 19:50:00
[2025-06-02 19:42:25] Schedule next startup at: 2025-06-02 20:00:00
[2025-06-02 19:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 19:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 20:00:17] Done :-)
[2025-06-02 20:00:17] Firmware ID: 0x37
[2025-06-02 20:00:17] Firmware Revison: 0x07
[2025-06-02 20:00:17] Current Vout=5.25V, Iout=0.53A
[2025-06-02 20:00:17] System starts up because power supply is newly connected.
[2025-06-02 20:02:23] Applying network time to system...
  Done :-)
[2025-06-02 20:02:25] Done :-)
[2025-06-02 20:02:25] Writing system time to RTC...
  Done :-)
<2025-06-02 20:02:25> Done :-)
[2025-06-02 20:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 20:02:25] Pending for incoming shutdown command...
[2025-06-02 20:02:25] Schedule next shutdown at: 2025-06-02 20:10:00
[2025-06-02 20:02:25] Schedule next startup at: 2025-06-02 20:20:00
[2025-06-02 20:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 20:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 20:20:17] Done :-)
[2025-06-02 20:20:17] Firmware ID: 0x37
[2025-06-02 20:20:17] Firmware Revison: 0x07
[2025-06-02 20:20:17] Current Vout=5.19V, Iout=0.38A
[2025-06-02 20:20:17] System starts up because power supply is newly connected.
[2025-06-02 20:22:23] Applying network time to system...
  Done :-)
[2025-06-02 20:22:25] Done :-)
[2025-06-02 20:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 20:22:25> Done :-)
[2025-06-02 20:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 20:22:25] Pending for incoming shutdown command...
[2025-06-02 20:22:25] Schedule next shutdown at: 2025-06-02 20:30:00
[2025-06-02 20:22:25] Schedule next startup at: 2025-06-02 20:40:00
[2025-06-02 20:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 20:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 20:40:17] Done :-)
[2025-06-02 20:40:17] Firmware ID: 0x37
[2025-06-02 20:40:17] Firmware Revison: 0x07
[2025-06-02 20:40:17] Current Vout=5.2V, Iout=0.4A
[2025-06-02 20:40:17] System starts up because power supply is newly connected.
[2025-06-02 20:42:22] Applying network time to system...
  Done :-)
[2025-06-02 20:42:24] Done :-)
[2025-06-02 20:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 20:42:24> Done :-)
[2025-06-02 20:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 20:42:24] Pending for incoming shutdown command...
[2025-06-02 20:42:24] Schedule next shutdown at: 2025-06-02 20:50:00
[2025-06-02 20:42:24] Schedule next startup at: 2025-06-02 21:00:00
[2025-06-02 20:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 20:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 21:00:17] Done :-)
[2025-06-02 21:00:17] Firmware ID: 0x37
[2025-06-02 21:00:17] Firmware Revison: 0x07
[2025-06-02 21:00:17] Current Vout=5.26V, Iout=0.51A
[2025-06-02 21:00:17] System starts up because power supply is newly connected.
[2025-06-02 21:02:23] Applying network time to system...
  Done :-)
[2025-06-02 21:02:24] Done :-)
[2025-06-02 21:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 21:02:24> Done :-)
[2025-06-02 21:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 21:02:24] Pending for incoming shutdown command...
[2025-06-02 21:02:24] Schedule next shutdown at: 2025-06-02 21:10:00
[2025-06-02 21:02:24] Schedule next startup at: 2025-06-02 21:20:00
[2025-06-02 21:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 21:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 21:20:17] Done :-)
[2025-06-02 21:20:17] Firmware ID: 0x37
[2025-06-02 21:20:17] Firmware Revison: 0x07
[2025-06-02 21:20:17] Current Vin=4.42V, Vout=5.19V, Iout=0.6A
[2025-06-02 21:20:17] System starts up because power supply is newly connected.
[2025-06-02 21:22:23] Applying network time to system...
  Done :-)
[2025-06-02 21:22:25] Done :-)
[2025-06-02 21:22:25] Writing system time to RTC...
  Done :-)
<2025-06-02 21:22:25> Done :-)
[2025-06-02 21:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 21:22:25] Pending for incoming shutdown command...
[2025-06-02 21:22:25] Schedule next shutdown at: 2025-06-02 21:30:00
[2025-06-02 21:22:25] Schedule next startup at: 2025-06-02 21:40:00
[2025-06-02 21:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 21:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 21:40:18] Done :-)
[2025-06-02 21:40:18] Firmware ID: 0x37
[2025-06-02 21:40:18] Firmware Revison: 0x07
[2025-06-02 21:40:18] Current Vout=5.2V, Iout=0.3A
[2025-06-02 21:40:18] System starts up because power supply is newly connected.
[2025-06-02 21:42:27] Applying network time to system...
  Done :-)
[2025-06-02 21:42:29] Done :-)
[2025-06-02 21:42:29] Writing system time to RTC...
  Done :-)
<2025-06-02 21:42:29> Done :-)
[2025-06-02 21:42:29] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 21:42:29] Pending for incoming shutdown command...
[2025-06-02 21:42:29] Schedule next shutdown at: 2025-06-02 21:50:00
[2025-06-02 21:42:29] Schedule next startup at: 2025-06-02 22:00:00
[2025-06-02 21:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 21:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 22:00:17] Done :-)
[2025-06-02 22:00:17] Firmware ID: 0x37
[2025-06-02 22:00:17] Firmware Revison: 0x07
[2025-06-02 22:00:17] Current Vout=5.26V, Iout=0.38A
[2025-06-02 22:00:17] System starts up because power supply is newly connected.
[2025-06-02 22:02:22] Applying network time to system...
  Done :-)
[2025-06-02 22:02:24] Done :-)
[2025-06-02 22:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 22:02:24> Done :-)
[2025-06-02 22:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 22:02:24] Pending for incoming shutdown command...
[2025-06-02 22:02:24] Schedule next shutdown at: 2025-06-02 22:10:00
[2025-06-02 22:02:24] Schedule next startup at: 2025-06-02 22:20:00
[2025-06-02 22:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 22:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 22:20:17] Done :-)
[2025-06-02 22:20:17] Firmware ID: 0x37
[2025-06-02 22:20:17] Firmware Revison: 0x07
[2025-06-02 22:20:17] Current Vout=5.19V, Iout=0.3A
[2025-06-02 22:20:17] System starts up because power supply is newly connected.
[2025-06-02 22:22:22] Applying network time to system...
  Done :-)
[2025-06-02 22:22:24] Done :-)
[2025-06-02 22:22:24] Writing system time to RTC...
  Done :-)
<2025-06-02 22:22:24> Done :-)
[2025-06-02 22:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 22:22:24] Pending for incoming shutdown command...
[2025-06-02 22:22:24] Schedule next shutdown at: 2025-06-02 22:30:00
[2025-06-02 22:22:24] Schedule next startup at: 2025-06-02 22:40:00
[2025-06-02 22:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 22:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 22:40:17] Done :-)
[2025-06-02 22:40:17] Firmware ID: 0x37
[2025-06-02 22:40:17] Firmware Revison: 0x07
[2025-06-02 22:40:17] Current Vout=5.13V, Iout=0.77A
[2025-06-02 22:40:17] System starts up because power supply is newly connected.
[2025-06-02 22:42:22] Applying network time to system...
  Done :-)
[2025-06-02 22:42:25] Done :-)
[2025-06-02 22:42:25] Writing system time to RTC...
  Done :-)
<2025-06-02 22:42:25> Done :-)
[2025-06-02 22:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 22:42:25] Pending for incoming shutdown command...
[2025-06-02 22:42:25] Schedule next shutdown at: 2025-06-02 22:50:00
[2025-06-02 22:42:25] Schedule next startup at: 2025-06-02 23:00:00
[2025-06-02 22:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 22:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 23:00:17] Done :-)
[2025-06-02 23:00:17] Firmware ID: 0x37
[2025-06-02 23:00:17] Firmware Revison: 0x07
[2025-06-02 23:00:17] Current Vout=5.25V, Iout=0.3A
[2025-06-02 23:00:17] System starts up because power supply is newly connected.
[2025-06-02 23:02:22] Applying network time to system...
  Done :-)
[2025-06-02 23:02:24] Done :-)
[2025-06-02 23:02:24] Writing system time to RTC...
  Done :-)
<2025-06-02 23:02:24> Done :-)
[2025-06-02 23:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 23:02:24] Pending for incoming shutdown command...
[2025-06-02 23:02:24] Schedule next shutdown at: 2025-06-02 23:10:00
[2025-06-02 23:02:24] Schedule next startup at: 2025-06-02 23:20:00
[2025-06-02 23:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-02 23:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 23:20:18] Done :-)
[2025-06-02 23:20:18] Firmware ID: 0x37
[2025-06-02 23:20:18] Firmware Revison: 0x07
[2025-06-02 23:20:18] Current Vout=5.25V, Iout=0.51A
[2025-06-02 23:20:18] System starts up because power supply is newly connected.
[2025-06-02 23:22:38] Applying network time to system...
  Done :-)
[2025-06-02 23:22:40] Done :-)
[2025-06-02 23:22:40] Writing system time to RTC...
  Done :-)
<2025-06-02 23:22:40> Done :-)
[2025-06-02 23:22:40] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 23:22:40] Pending for incoming shutdown command...
[2025-06-02 23:22:40] Schedule next shutdown at: 2025-06-02 23:30:00
[2025-06-02 23:22:40] Schedule next startup at: 2025-06-02 23:40:00
[2025-06-02 23:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 23:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-02 23:40:18] Done :-)
[2025-06-02 23:40:18] Firmware ID: 0x37
[2025-06-02 23:40:18] Firmware Revison: 0x07
[2025-06-02 23:40:18] Current Vin=4.42V, Vout=5.19V, Iout=0.36A
[2025-06-02 23:40:18] System starts up because power supply is newly connected.
[2025-06-02 23:42:23] Applying network time to system...
  Done :-)
[2025-06-02 23:42:24] Done :-)
[2025-06-02 23:42:24] Writing system time to RTC...
  Done :-)
<2025-06-02 23:42:24> Done :-)
[2025-06-02 23:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-02 23:42:24] Pending for incoming shutdown command...
[2025-06-02 23:42:24] Schedule next shutdown at: 2025-06-02 23:50:00
[2025-06-02 23:42:24] Schedule next startup at: 2025-06-03 00:00:00
[2025-06-02 23:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-02 23:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 00:00:18] Done :-)
[2025-06-03 00:00:18] Firmware ID: 0x37
[2025-06-03 00:00:18] Firmware Revison: 0x07
[2025-06-03 00:00:18] Current Vin=4.24V, Vout=5.19V, Iout=0.66A
[2025-06-03 00:00:18] System starts up because power supply is newly connected.
[2025-06-03 00:02:24] Applying network time to system...
  Done :-)
[2025-06-03 00:02:26] Done :-)
[2025-06-03 00:02:26] Writing system time to RTC...
  Done :-)
<2025-06-03 00:02:26> Done :-)
[2025-06-03 00:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 00:02:26] Pending for incoming shutdown command...
[2025-06-03 00:02:26] Schedule next shutdown at: 2025-06-03 00:10:00
[2025-06-03 00:02:26] Schedule next startup at: 2025-06-03 00:20:00
[2025-06-03 00:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 00:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 00:20:18] Done :-)
[2025-06-03 00:20:18] Firmware ID: 0x37
[2025-06-03 00:20:18] Firmware Revison: 0x07
[2025-06-03 00:20:18] Current Vout=5.21V, Iout=0.34A
[2025-06-03 00:20:18] System starts up because power supply is newly connected.
[2025-06-03 00:22:23] Applying network time to system...
  Done :-)
[2025-06-03 00:22:24] Done :-)
[2025-06-03 00:22:24] Writing system time to RTC...
  Done :-)
<2025-06-03 00:22:24> Done :-)
[2025-06-03 00:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 00:22:24] Pending for incoming shutdown command...
[2025-06-03 00:22:24] Schedule next shutdown at: 2025-06-03 00:30:00
[2025-06-03 00:22:24] Schedule next startup at: 2025-06-03 00:40:00
[2025-06-03 00:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 00:30:00] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] System: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.12.25+rpt-rpi-v8, Architecture: arm64
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x7e
[2025-06-03 00:40:17] Done :-)
[2025-06-03 00:40:17] Firmware ID: 0x37
[2025-06-03 00:40:17] Firmware Revison: 0x07
[2025-06-03 00:40:17] Current Vin=4.49V, Vout=5.26V, Iout=0.53A
[2025-06-03 00:40:17] System starts up because power supply is newly connected.
[2025-06-03 00:42:23] Applying network time to system...
  Done :-)
[2025-06-03 00:42:25] Done :-)
[2025-06-03 00:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 00:42:25> Done :-)
[2025-06-03 00:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 00:42:25] Pending for incoming shutdown command...
[2025-06-03 00:42:25] Schedule next shutdown at: 2025-06-03 00:50:00
[2025-06-03 00:42:25] Schedule next startup at: 2025-06-03 01:00:00
[2025-06-03 00:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 00:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 01:00:17] Done :-)
[2025-06-03 01:00:17] Firmware ID: 0x37
[2025-06-03 01:00:17] Firmware Revison: 0x07
[2025-06-03 01:00:17] Current Vout=5.32V, Iout=0.6A
[2025-06-03 01:00:17] System starts up because power supply is newly connected.
[2025-06-03 01:02:22] Applying network time to system...
  Done :-)
[2025-06-03 01:02:24] Done :-)
[2025-06-03 01:02:24] Writing system time to RTC...
  Done :-)
<2025-06-03 01:02:24> Done :-)
[2025-06-03 01:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 01:02:24] Pending for incoming shutdown command...
[2025-06-03 01:02:24] Schedule next shutdown at: 2025-06-03 01:10:00
[2025-06-03 01:02:24] Schedule next startup at: 2025-06-03 01:20:00
[2025-06-03 01:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 01:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 01:20:18] Done :-)
[2025-06-03 01:20:18] Firmware ID: 0x37
[2025-06-03 01:20:18] Firmware Revison: 0x07
[2025-06-03 01:20:18] Current Vout=5.21V, Iout=0.27A
[2025-06-03 01:20:18] System starts up because power supply is newly connected.
[2025-06-03 01:22:23] Applying network time to system...
  Done :-)
[2025-06-03 01:22:24] Done :-)
[2025-06-03 01:22:24] Writing system time to RTC...
  Done :-)
<2025-06-03 01:22:24> Done :-)
[2025-06-03 01:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 01:22:24] Pending for incoming shutdown command...
[2025-06-03 01:22:24] Schedule next shutdown at: 2025-06-03 01:30:00
[2025-06-03 01:22:24] Schedule next startup at: 2025-06-03 01:40:00
[2025-06-03 01:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 01:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 01:40:18] Done :-)
[2025-06-03 01:40:18] Firmware ID: 0x37
[2025-06-03 01:40:18] Firmware Revison: 0x07
[2025-06-03 01:40:18] Current Vout=5.26V, Iout=0.21A
[2025-06-03 01:40:18] System starts up because power supply is newly connected.
[2025-06-03 01:42:23] Applying network time to system...
  Done :-)
[2025-06-03 01:42:25] Done :-)
[2025-06-03 01:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 01:42:25> Done :-)
[2025-06-03 01:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 01:42:25] Pending for incoming shutdown command...
[2025-06-03 01:42:25] Schedule next shutdown at: 2025-06-03 01:50:00
[2025-06-03 01:42:25] Schedule next startup at: 2025-06-03 02:00:00
[2025-06-03 01:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 01:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 02:00:17] Done :-)
[2025-06-03 02:00:17] Firmware ID: 0x37
[2025-06-03 02:00:17] Firmware Revison: 0x07
[2025-06-03 02:00:17] Current Vin=4.36V, Vout=5.2V, Iout=0.51A
[2025-06-03 02:00:17] System starts up because power supply is newly connected.
[2025-06-03 02:02:23] Applying network time to system...
  Done :-)
[2025-06-03 02:02:25] Done :-)
[2025-06-03 02:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 02:02:25> Done :-)
[2025-06-03 02:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 02:02:25] Pending for incoming shutdown command...
[2025-06-03 02:02:25] Schedule next shutdown at: 2025-06-03 02:10:00
[2025-06-03 02:02:25] Schedule next startup at: 2025-06-03 02:20:00
[2025-06-03 02:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 02:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 02:20:17] Done :-)
[2025-06-03 02:20:17] Firmware ID: 0x37
[2025-06-03 02:20:17] Firmware Revison: 0x07
[2025-06-03 02:20:17] Current Vin=4.42V, Vout=5.19V, Iout=0.06A
[2025-06-03 02:20:17] System starts up because power supply is newly connected.
[2025-06-03 02:22:22] Applying network time to system...
  Done :-)
[2025-06-03 02:22:25] Done :-)
[2025-06-03 02:22:25] Writing system time to RTC...
  Done :-)
<2025-06-03 02:22:25> Done :-)
[2025-06-03 02:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 02:22:25] Pending for incoming shutdown command...
[2025-06-03 02:22:25] Schedule next shutdown at: 2025-06-03 02:30:00
[2025-06-03 02:22:25] Schedule next startup at: 2025-06-03 02:40:00
[2025-06-03 02:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 02:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 02:40:17] Done :-)
[2025-06-03 02:40:17] Firmware ID: 0x37
[2025-06-03 02:40:17] Firmware Revison: 0x07
[2025-06-03 02:40:17] Current Vout=5.25V, Iout=0.45A
[2025-06-03 02:40:17] System starts up because power supply is newly connected.
[2025-06-03 02:42:22] Applying network time to system...
  Done :-)
[2025-06-03 02:42:25] Done :-)
[2025-06-03 02:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 02:42:25> Done :-)
[2025-06-03 02:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 02:42:25] Pending for incoming shutdown command...
[2025-06-03 02:42:25] Schedule next shutdown at: 2025-06-03 02:50:00
[2025-06-03 02:42:25] Schedule next startup at: 2025-06-03 03:00:00
[2025-06-03 02:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 02:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 03:00:18] Done :-)
[2025-06-03 03:00:18] Firmware ID: 0x37
[2025-06-03 03:00:18] Firmware Revison: 0x07
[2025-06-03 03:00:18] Current Vout=5.2V, Iout=0.45A
[2025-06-03 03:00:18] System starts up because power supply is newly connected.
[2025-06-03 03:02:23] Applying network time to system...
  Done :-)
[2025-06-03 03:02:26] Done :-)
[2025-06-03 03:02:26] Writing system time to RTC...
  Done :-)
<2025-06-03 03:02:26> Done :-)
[2025-06-03 03:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 03:02:26] Pending for incoming shutdown command...
[2025-06-03 03:02:26] Schedule next shutdown at: 2025-06-03 03:10:00
[2025-06-03 03:02:26] Schedule next startup at: 2025-06-03 03:20:00
[2025-06-03 03:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 03:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 03:20:17] Done :-)
[2025-06-03 03:20:17] Firmware ID: 0x37
[2025-06-03 03:20:17] Firmware Revison: 0x07
[2025-06-03 03:20:17] Current Vin=4.3V, Vout=5.25V, Iout=0.32A
[2025-06-03 03:20:17] System starts up because power supply is newly connected.
[2025-06-03 03:22:48] Applying network time to system...
  Done :-)
[2025-06-03 03:22:50] Done :-)
[2025-06-03 03:22:50] Writing system time to RTC...
  Done :-)
<2025-06-03 03:22:50> Done :-)
[2025-06-03 03:22:50] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 03:22:50] Pending for incoming shutdown command...
[2025-06-03 03:22:50] Schedule next shutdown at: 2025-06-03 03:30:00
[2025-06-03 03:22:51] Schedule next startup at: 2025-06-03 03:40:00
[2025-06-03 03:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 03:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 03:40:17] Done :-)
[2025-06-03 03:40:17] Firmware ID: 0x37
[2025-06-03 03:40:17] Firmware Revison: 0x07
[2025-06-03 03:40:17] Current Vin=4.42V, Vout=5.2V, Iout=0.51A
[2025-06-03 03:40:17] System starts up because power supply is newly connected.
[2025-06-03 03:42:22] Applying network time to system...
  Done :-)
[2025-06-03 03:42:25] Done :-)
[2025-06-03 03:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 03:42:25> Done :-)
[2025-06-03 03:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 03:42:25] Pending for incoming shutdown command...
[2025-06-03 03:42:25] Schedule next shutdown at: 2025-06-03 03:50:00
[2025-06-03 03:42:25] Schedule next startup at: 2025-06-03 04:00:00
[2025-06-03 03:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 03:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 04:00:18] Done :-)
[2025-06-03 04:00:18] Firmware ID: 0x37
[2025-06-03 04:00:18] Firmware Revison: 0x07
[2025-06-03 04:00:18] Current Vout=5.25V, Iout=0.08A
[2025-06-03 04:00:18] System starts up because power supply is newly connected.
[2025-06-03 04:02:44] Applying network time to system...
  Done :-)
[2025-06-03 04:02:45] Done :-)
[2025-06-03 04:02:45] Writing system time to RTC...
  Done :-)
<2025-06-03 04:02:45> Done :-)
[2025-06-03 04:02:45] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 04:02:45] Pending for incoming shutdown command...
[2025-06-03 04:02:45] Schedule next shutdown at: 2025-06-03 04:10:00
[2025-06-03 04:02:45] Schedule next startup at: 2025-06-03 04:20:00
[2025-06-03 04:20:18] Done :-)
[2025-06-03 04:20:18] Firmware ID: 0x37
[2025-06-03 04:20:18] Firmware Revison: 0x07
[2025-06-03 04:20:18] Current Vout=5.2V, Iout=0.38A
[2025-06-03 04:20:18] System starts up because power supply is newly connected.
[2025-06-03 04:22:25] Applying network time to system...
  Done :-)
[2025-06-03 04:22:27] Done :-)
[2025-06-03 04:22:27] Writing system time to RTC...
  Done :-)
<2025-06-03 04:22:27> Done :-)
[2025-06-03 04:22:27] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 04:22:27] Pending for incoming shutdown command...
[2025-06-03 04:22:27] Schedule next shutdown at: 2025-06-03 04:30:00
[2025-06-03 04:22:27] Schedule next startup at: 2025-06-03 04:40:00
[2025-06-03 04:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 04:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 04:40:17] Done :-)
[2025-06-03 04:40:17] Firmware ID: 0x37
[2025-06-03 04:40:17] Firmware Revison: 0x07
[2025-06-03 04:40:17] Current Vout=5.25V, Iout=0.51A
[2025-06-03 04:40:17] System starts up because power supply is newly connected.
[2025-06-03 04:42:23] Applying network time to system...
  Done :-)
[2025-06-03 04:42:25] Done :-)
[2025-06-03 04:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 04:42:25> Done :-)
[2025-06-03 04:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 04:42:25] Pending for incoming shutdown command...
[2025-06-03 04:42:25] Schedule next shutdown at: 2025-06-03 04:50:00
[2025-06-03 04:42:25] Schedule next startup at: 2025-06-03 05:00:00
[2025-06-03 04:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 04:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 05:00:17] Done :-)
[2025-06-03 05:00:17] Firmware ID: 0x37
[2025-06-03 05:00:17] Firmware Revison: 0x07
[2025-06-03 05:00:17] Current Vout=5.18V, Iout=0.47A
[2025-06-03 05:00:17] System starts up because power supply is newly connected.
[2025-06-03 05:02:22] Applying network time to system...
  Done :-)
[2025-06-03 05:02:24] Done :-)
[2025-06-03 05:02:24] Writing system time to RTC...
  Done :-)
<2025-06-03 05:02:24> Done :-)
[2025-06-03 05:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 05:02:24] Pending for incoming shutdown command...
[2025-06-03 05:02:24] Schedule next shutdown at: 2025-06-03 05:10:00
[2025-06-03 05:02:24] Schedule next startup at: 2025-06-03 05:20:00
[2025-06-03 05:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 05:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 05:20:17] Done :-)
[2025-06-03 05:20:17] Firmware ID: 0x37
[2025-06-03 05:20:17] Firmware Revison: 0x07
[2025-06-03 05:20:17] Current Vin=4.49V, Vout=5.26V, Iout=0.58A
[2025-06-03 05:20:17] System starts up because power supply is newly connected.
[2025-06-03 05:22:22] Applying network time to system...
  Done :-)
[2025-06-03 05:22:25] Done :-)
[2025-06-03 05:22:25] Writing system time to RTC...
  Done :-)
<2025-06-03 05:22:25> Done :-)
[2025-06-03 05:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 05:22:25] Pending for incoming shutdown command...
[2025-06-03 05:22:25] Schedule next shutdown at: 2025-06-03 05:30:00
[2025-06-03 05:22:25] Schedule next startup at: 2025-06-03 05:40:00
[2025-06-03 05:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 05:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 05:40:17] Done :-)
[2025-06-03 05:40:17] Firmware ID: 0x37
[2025-06-03 05:40:17] Firmware Revison: 0x07
[2025-06-03 05:40:17] Current Vin=4.24V, Vout=5.2V, Iout=0.49A
[2025-06-03 05:40:17] System starts up because power supply is newly connected.
[2025-06-03 05:42:23] Applying network time to system...
  Done :-)
[2025-06-03 05:42:24] Done :-)
[2025-06-03 05:42:24] Writing system time to RTC...
  Done :-)
<2025-06-03 05:42:24> Done :-)
[2025-06-03 05:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 05:42:24] Pending for incoming shutdown command...
[2025-06-03 05:42:24] Schedule next shutdown at: 2025-06-03 05:50:00
[2025-06-03 05:42:24] Schedule next startup at: 2025-06-03 06:00:00
[2025-06-03 05:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 05:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 06:00:17] Done :-)
[2025-06-03 06:00:17] Firmware ID: 0x37
[2025-06-03 06:00:17] Firmware Revison: 0x07
[2025-06-03 06:00:17] Current Vin=4.36V, Vout=5.19V, Iout=0.6A
[2025-06-03 06:00:17] System starts up because power supply is newly connected.
[2025-06-03 06:02:23] Applying network time to system...
  Done :-)
[2025-06-03 06:02:25] Done :-)
[2025-06-03 06:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 06:02:25> Done :-)
[2025-06-03 06:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 06:02:25] Pending for incoming shutdown command...
[2025-06-03 06:02:25] Schedule next shutdown at: 2025-06-03 06:10:00
[2025-06-03 06:02:25] Schedule next startup at: 2025-06-03 06:20:00
[2025-06-03 06:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 06:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 06:20:17] Done :-)
[2025-06-03 06:20:17] Firmware ID: 0x37
[2025-06-03 06:20:17] Firmware Revison: 0x07
[2025-06-03 06:20:17] Current Vout=5.25V, Iout=0.23A
[2025-06-03 06:20:17] System starts up because power supply is newly connected.
[2025-06-03 06:22:22] Applying network time to system...
  Done :-)
[2025-06-03 06:22:25] Done :-)
[2025-06-03 06:22:25] Writing system time to RTC...
  Done :-)
<2025-06-03 06:22:25> Done :-)
[2025-06-03 06:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 06:22:25] Pending for incoming shutdown command...
[2025-06-03 06:22:25] Schedule next shutdown at: 2025-06-03 06:30:00
[2025-06-03 06:22:26] Schedule next startup at: 2025-06-03 06:40:00
[2025-06-03 06:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 06:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 06:40:17] Done :-)
[2025-06-03 06:40:17] Firmware ID: 0x37
[2025-06-03 06:40:17] Firmware Revison: 0x07
[2025-06-03 06:40:17] Current Vout=5.25V, Iout=0.64A
[2025-06-03 06:40:17] System starts up because power supply is newly connected.
[2025-06-03 06:42:22] Applying network time to system...
  Done :-)
[2025-06-03 06:42:24] Done :-)
[2025-06-03 06:42:24] Writing system time to RTC...
  Done :-)
<2025-06-03 06:42:24> Done :-)
[2025-06-03 06:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 06:42:24] Pending for incoming shutdown command...
[2025-06-03 06:42:24] Schedule next shutdown at: 2025-06-03 06:50:00
[2025-06-03 06:42:24] Schedule next startup at: 2025-06-03 07:00:00
[2025-06-03 06:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 06:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 07:00:17] Done :-)
[2025-06-03 07:00:17] Firmware ID: 0x37
[2025-06-03 07:00:17] Firmware Revison: 0x07
[2025-06-03 07:00:17] Current Vout=5.19V, Iout=0.55A
[2025-06-03 07:00:17] System starts up because power supply is newly connected.
[2025-06-03 07:02:22] Applying network time to system...
  Done :-)
[2025-06-03 07:02:25] Done :-)
[2025-06-03 07:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 07:02:25> Done :-)
[2025-06-03 07:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 07:02:25] Pending for incoming shutdown command...
[2025-06-03 07:02:25] Schedule next shutdown at: 2025-06-03 07:10:00
[2025-06-03 07:02:25] Schedule next startup at: 2025-06-03 07:20:00
[2025-06-03 07:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 07:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 07:20:17] Done :-)
[2025-06-03 07:20:17] Firmware ID: 0x37
[2025-06-03 07:20:17] Firmware Revison: 0x07
[2025-06-03 07:20:17] Current Vout=5.19V, Iout=0.51A
[2025-06-03 07:20:17] System starts up because power supply is newly connected.
[2025-06-03 07:22:22] Applying network time to system...
  Done :-)
[2025-06-03 07:22:25] Done :-)
[2025-06-03 07:22:25] Writing system time to RTC...
  Done :-)
<2025-06-03 07:22:25> Done :-)
[2025-06-03 07:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 07:22:25] Pending for incoming shutdown command...
[2025-06-03 07:22:25] Schedule next shutdown at: 2025-06-03 07:30:00
[2025-06-03 07:22:25] Schedule next startup at: 2025-06-03 07:40:00
[2025-06-03 07:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 07:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 07:40:17] Done :-)
[2025-06-03 07:40:17] Firmware ID: 0x37
[2025-06-03 07:40:17] Firmware Revison: 0x07
[2025-06-03 07:40:17] Current Vout=5.14V, Iout=0.43A
[2025-06-03 07:40:17] System starts up because power supply is newly connected.
[2025-06-03 07:42:22] Applying network time to system...
  Done :-)
[2025-06-03 07:42:24] Done :-)
[2025-06-03 07:42:24] Writing system time to RTC...
  Done :-)
<2025-06-03 07:42:24> Done :-)
[2025-06-03 07:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 07:42:24] Pending for incoming shutdown command...
[2025-06-03 07:42:24] Schedule next shutdown at: 2025-06-03 07:50:00
[2025-06-03 07:42:24] Schedule next startup at: 2025-06-03 08:00:00
[2025-06-03 07:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 07:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 08:00:17] Done :-)
[2025-06-03 08:00:17] Firmware ID: 0x37
[2025-06-03 08:00:17] Firmware Revison: 0x07
[2025-06-03 08:00:17] Current Vout=5.13V, Iout=0.58A
[2025-06-03 08:00:17] System starts up because power supply is newly connected.
[2025-06-03 08:02:22] Applying network time to system...
  Done :-)
[2025-06-03 08:02:24] Done :-)
[2025-06-03 08:02:24] Writing system time to RTC...
  Done :-)
<2025-06-03 08:02:24> Done :-)
[2025-06-03 08:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 08:02:24] Pending for incoming shutdown command...
[2025-06-03 08:02:24] Schedule next shutdown at: 2025-06-03 08:10:00
[2025-06-03 08:02:24] Schedule next startup at: 2025-06-03 08:20:00
[2025-06-03 08:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 08:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 08:20:17] Done :-)
[2025-06-03 08:20:17] Firmware ID: 0x37
[2025-06-03 08:20:17] Firmware Revison: 0x07
[2025-06-03 08:20:17] Current Vin=4.24V, Vout=5.25V, Iout=0.7A
[2025-06-03 08:20:17] System starts up because power supply is newly connected.
[2025-06-03 08:22:23] Applying network time to system...
  Done :-)
[2025-06-03 08:22:25] Done :-)
[2025-06-03 08:22:25] Writing system time to RTC...
  Done :-)
<2025-06-03 08:22:25> Done :-)
[2025-06-03 08:22:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 08:22:25] Pending for incoming shutdown command...
[2025-06-03 08:22:25] Schedule next shutdown at: 2025-06-03 08:30:00
[2025-06-03 08:22:25] Schedule next startup at: 2025-06-03 08:40:00
[2025-06-03 08:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 08:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 08:40:17] Done :-)
[2025-06-03 08:40:17] Firmware ID: 0x37
[2025-06-03 08:40:17] Firmware Revison: 0x07
[2025-06-03 08:40:17] Current Vout=5.19V, Iout=0.62A
[2025-06-03 08:40:17] System starts up because power supply is newly connected.
[2025-06-03 08:42:23] Applying network time to system...
  Done :-)
[2025-06-03 08:42:24] Done :-)
[2025-06-03 08:42:24] Writing system time to RTC...
  Done :-)
<2025-06-03 08:42:24> Done :-)
[2025-06-03 08:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 08:42:24] Pending for incoming shutdown command...
[2025-06-03 08:42:24] Schedule next shutdown at: 2025-06-03 08:50:00
[2025-06-03 08:42:25] Schedule next startup at: 2025-06-03 09:00:00
[2025-06-03 08:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 08:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 09:00:17] Done :-)
[2025-06-03 09:00:17] Firmware ID: 0x37
[2025-06-03 09:00:17] Firmware Revison: 0x07
[2025-06-03 09:00:17] Current Vout=5.2V, Iout=0.45A
[2025-06-03 09:00:17] System starts up because power supply is newly connected.
[2025-06-03 09:02:22] Applying network time to system...
  Done :-)
[2025-06-03 09:02:24] Done :-)
[2025-06-03 09:02:24] Writing system time to RTC...
  Done :-)
<2025-06-03 09:02:24> Done :-)
[2025-06-03 09:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 09:02:24] Pending for incoming shutdown command...
[2025-06-03 09:02:24] Schedule next shutdown at: 2025-06-03 09:10:00
[2025-06-03 09:02:24] Schedule next startup at: 2025-06-03 09:20:00
[2025-06-03 09:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 09:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 09:20:18] Done :-)
[2025-06-03 09:20:18] Firmware ID: 0x37
[2025-06-03 09:20:18] Firmware Revison: 0x07
[2025-06-03 09:20:18] Current Vout=5.26V, Iout=0.4A
[2025-06-03 09:20:18] System starts up because power supply is newly connected.
[2025-06-03 09:22:24] Applying network time to system...
  Done :-)
[2025-06-03 09:22:24] Done :-)
[2025-06-03 09:22:24] Writing system time to RTC...
  Done :-)
<2025-06-03 09:22:24> Done :-)
[2025-06-03 09:22:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 09:22:24] Pending for incoming shutdown command...
[2025-06-03 09:22:24] Schedule next shutdown at: 2025-06-03 09:30:00
[2025-06-03 09:22:24] Schedule next startup at: 2025-06-03 09:40:00
[2025-06-03 09:30:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 09:30:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 09:40:17] Done :-)
[2025-06-03 09:40:17] Firmware ID: 0x37
[2025-06-03 09:40:17] Firmware Revison: 0x07
[2025-06-03 09:40:17] Current Vin=4.12V, Vout=5.19V, Iout=0.06A
[2025-06-03 09:40:17] System starts up because power supply is newly connected.
[2025-06-03 09:42:23] Applying network time to system...
  Done :-)
[2025-06-03 09:42:25] Done :-)
[2025-06-03 09:42:25] Writing system time to RTC...
  Done :-)
<2025-06-03 09:42:25> Done :-)
[2025-06-03 09:42:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 09:42:25] Pending for incoming shutdown command...
[2025-06-03 09:42:25] Schedule next shutdown at: 2025-06-03 09:50:00
[2025-06-03 09:42:25] Schedule next startup at: 2025-06-03 10:00:00
[2025-06-03 09:50:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 09:50:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 10:00:17] Done :-)
[2025-06-03 10:00:17] Firmware ID: 0x37
[2025-06-03 10:00:17] Firmware Revison: 0x07
[2025-06-03 10:00:17] Current Vout=5.19V, Iout=0.4A
[2025-06-03 10:00:17] System starts up because power supply is newly connected.
[2025-06-03 10:02:22] Applying network time to system...
  Done :-)
[2025-06-03 10:02:25] Done :-)
[2025-06-03 10:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 10:02:25> Done :-)
[2025-06-03 10:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 10:02:25] Pending for incoming shutdown command...
[2025-06-03 10:02:25] Schedule next shutdown at: 2025-06-03 10:10:00
[2025-06-03 10:02:25] Schedule next startup at: 2025-06-03 10:20:00
[2025-06-03 10:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 10:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 10:20:18] Done :-)
[2025-06-03 10:20:18] Firmware ID: 0x37
[2025-06-03 10:20:18] Firmware Revison: 0x07
[2025-06-03 10:20:18] Current Vin=4.55V, Vout=5.26V, Iout=0.6A
[2025-06-03 10:20:18] System starts up because power supply is newly connected.
[2025-06-03 10:22:24] Applying network time to system...
  Done :-)
[2025-06-03 10:22:26] Done :-)
[2025-06-03 10:22:26] Writing system time to RTC...
  Done :-)
<2025-06-03 10:22:26> Done :-)
[2025-06-03 10:22:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 10:22:26] Pending for incoming shutdown command...
[2025-06-03 10:22:26] Schedule next shutdown at: 2025-06-03 10:30:00
[2025-06-03 10:22:27] Schedule next startup at: 2025-06-03 10:40:00
[2025-06-03 10:29:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 10:29:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 10:40:17] Done :-)
[2025-06-03 10:40:17] Firmware ID: 0x37
[2025-06-03 10:40:17] Firmware Revison: 0x07
[2025-06-03 10:40:17] Current Vin=4.49V, Vout=5.19V, Iout=0.49A
[2025-06-03 10:40:17] System starts up because power supply is newly connected.
[2025-06-03 10:42:22] Applying network time to system...
  Done :-)
[2025-06-03 10:42:24] Done :-)
[2025-06-03 10:42:24] Writing system time to RTC...
  Done :-)
<2025-06-03 10:42:24> Done :-)
[2025-06-03 10:42:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 10:42:24] Pending for incoming shutdown command...
[2025-06-03 10:42:24] Schedule next shutdown at: 2025-06-03 10:50:00
[2025-06-03 10:42:24] Schedule next startup at: 2025-06-03 11:00:00
[2025-06-03 10:49:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 10:49:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 11:00:18] Done :-)
[2025-06-03 11:00:18] Firmware ID: 0x37
[2025-06-03 11:00:18] Firmware Revison: 0x07
[2025-06-03 11:00:18] Current Vout=5.21V, Iout=0.06A
[2025-06-03 11:00:18] System starts up because power supply is newly connected.
[2025-06-03 11:02:24] Applying network time to system...
  Done :-)
[2025-06-03 11:02:25] Done :-)
[2025-06-03 11:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 11:02:25> Done :-)
[2025-06-03 11:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 11:02:25] Pending for incoming shutdown command...
[2025-06-03 11:02:25] Schedule next shutdown at: 2025-06-03 11:10:00
[2025-06-03 11:02:25] Schedule next startup at: 2025-06-03 11:20:00
[2025-06-03 11:09:29] Copying "on_10m_every_2h.wpi" to "schedule.wpi"...
[2025-06-03 11:09:29] Running the script...
[2025-06-03 11:09:30] Schedule next shutdown at: 2025-06-03 12:10:00
[2025-06-03 11:09:30] Schedule next startup at: 2025-06-03 14:00:00
[2025-06-03 11:09:30] Done :-)
[2025-06-03 12:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 12:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 14:00:18] Done :-)
[2025-06-03 14:00:18] Firmware ID: 0x37
[2025-06-03 14:00:18] Firmware Revison: 0x07
[2025-06-03 14:00:18] Current Vout=5.21V, Iout=0.64A
[2025-06-03 14:00:18] System starts up because power supply is newly connected.
[2025-06-03 14:02:23] Applying network time to system...
  Done :-)
[2025-06-03 14:02:25] Done :-)
[2025-06-03 14:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 14:02:25> Done :-)
[2025-06-03 14:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 14:02:25] Pending for incoming shutdown command...
[2025-06-03 14:02:25] Schedule next shutdown at: 2025-06-03 14:10:00
[2025-06-03 14:02:25] Schedule next startup at: 2025-06-03 16:00:00
[2025-06-03 14:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 14:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 16:00:17] Done :-)
[2025-06-03 16:00:17] Firmware ID: 0x37
[2025-06-03 16:00:17] Firmware Revison: 0x07
[2025-06-03 16:00:17] Current Vout=5.2V, Iout=0.4A
[2025-06-03 16:00:17] System starts up because power supply is newly connected.
[2025-06-03 16:02:23] Applying network time to system...
  Done :-)
[2025-06-03 16:02:25] Done :-)
[2025-06-03 16:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 16:02:25> Done :-)
[2025-06-03 16:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 16:02:25] Pending for incoming shutdown command...
[2025-06-03 16:02:25] Schedule next shutdown at: 2025-06-03 16:10:00
[2025-06-03 16:02:25] Schedule next startup at: 2025-06-03 18:00:00
[2025-06-03 16:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 16:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 18:00:17] Done :-)
[2025-06-03 18:00:17] Firmware ID: 0x37
[2025-06-03 18:00:17] Firmware Revison: 0x07
[2025-06-03 18:00:17] Current Vout=5.21V, Iout=0.3A
[2025-06-03 18:00:17] System starts up because power supply is newly connected.
[2025-06-03 18:02:22] Applying network time to system...
  Done :-)
[2025-06-03 18:02:25] Done :-)
[2025-06-03 18:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 18:02:25> Done :-)
[2025-06-03 18:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 18:02:25] Pending for incoming shutdown command...
[2025-06-03 18:02:25] Schedule next shutdown at: 2025-06-03 18:10:00
[2025-06-03 18:02:25] Schedule next startup at: 2025-06-03 20:00:00
[2025-06-03 18:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-03 18:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 20:00:18] Done :-)
[2025-06-03 20:00:18] Firmware ID: 0x37
[2025-06-03 20:00:18] Firmware Revison: 0x07
[2025-06-03 20:00:18] Current Vout=5.2V, Iout=0.55A
[2025-06-03 20:00:18] System starts up because power supply is newly connected.
[2025-06-03 20:02:23] Applying network time to system...
  Done :-)
[2025-06-03 20:02:24] Done :-)
[2025-06-03 20:02:24] Writing system time to RTC...
  Done :-)
<2025-06-03 20:02:24> Done :-)
[2025-06-03 20:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 20:02:24] Pending for incoming shutdown command...
[2025-06-03 20:02:24] Schedule next shutdown at: 2025-06-03 20:10:00
[2025-06-03 20:02:24] Schedule next startup at: 2025-06-03 22:00:00
[2025-06-03 20:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 20:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-03 22:00:18] Done :-)
[2025-06-03 22:00:18] Firmware ID: 0x37
[2025-06-03 22:00:18] Firmware Revison: 0x07
[2025-06-03 22:00:18] Current Vout=5.26V, Iout=0.49A
[2025-06-03 22:00:18] System starts up because power supply is newly connected.
[2025-06-03 22:02:23] Applying network time to system...
  Done :-)
[2025-06-03 22:02:25] Done :-)
[2025-06-03 22:02:25] Writing system time to RTC...
  Done :-)
<2025-06-03 22:02:25> Done :-)
[2025-06-03 22:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-03 22:02:25] Pending for incoming shutdown command...
[2025-06-03 22:02:25] Schedule next shutdown at: 2025-06-03 22:10:00
[2025-06-03 22:02:25] Schedule next startup at: 2025-06-04 00:00:00
[2025-06-03 22:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-03 22:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 00:00:18] Done :-)
[2025-06-04 00:00:18] Firmware ID: 0x37
[2025-06-04 00:00:18] Firmware Revison: 0x07
[2025-06-04 00:00:18] Current Vout=5.2V, Iout=0.64A
[2025-06-04 00:00:18] System starts up because power supply is newly connected.
[2025-06-04 00:02:24] Applying network time to system...
  Done :-)
[2025-06-04 00:02:26] Done :-)
[2025-06-04 00:02:26] Writing system time to RTC...
  Done :-)
<2025-06-04 00:02:26> Done :-)
[2025-06-04 00:02:26] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 00:02:26] Pending for incoming shutdown command...
[2025-06-04 00:02:26] Schedule next shutdown at: 2025-06-04 00:10:00
[2025-06-04 00:02:26] Schedule next startup at: 2025-06-04 02:00:00
[2025-06-04 00:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-04 00:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 02:00:17] Done :-)
[2025-06-04 02:00:17] Firmware ID: 0x37
[2025-06-04 02:00:17] Firmware Revison: 0x07
[2025-06-04 02:00:17] Current Vin=4.3V, Vout=5.19V, Iout=0.58A
[2025-06-04 02:00:17] System starts up because power supply is newly connected.
[2025-06-04 02:02:22] Applying network time to system...
  Done :-)
[2025-06-04 02:02:25] Done :-)
[2025-06-04 02:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 02:02:25> Done :-)
[2025-06-04 02:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 02:02:25] Pending for incoming shutdown command...
[2025-06-04 02:02:25] Schedule next shutdown at: 2025-06-04 02:10:00
[2025-06-04 02:02:25] Schedule next startup at: 2025-06-04 04:00:00
[2025-06-04 02:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-04 02:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 04:00:17] Done :-)
[2025-06-04 04:00:17] Firmware ID: 0x37
[2025-06-04 04:00:17] Firmware Revison: 0x07
[2025-06-04 04:00:17] Current Vin=4.3V, Vout=5.26V, Iout=0.34A
[2025-06-04 04:00:17] System starts up because power supply is newly connected.
[2025-06-04 04:02:44] Applying network time to system...
  Done :-)
[2025-06-04 04:02:46] Done :-)
[2025-06-04 04:02:46] Writing system time to RTC...
  Done :-)
<2025-06-04 04:02:46> Done :-)
[2025-06-04 04:02:46] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 04:02:46] Pending for incoming shutdown command...
[2025-06-04 04:02:46] Schedule next shutdown at: 2025-06-04 04:10:00
[2025-06-04 04:02:46] Schedule next startup at: 2025-06-04 06:00:00
[2025-06-04 04:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 04:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 06:00:17] Done :-)
[2025-06-04 06:00:17] Firmware ID: 0x37
[2025-06-04 06:00:17] Firmware Revison: 0x07
[2025-06-04 06:00:17] Current Vout=5.21V, Iout=0.15A
[2025-06-04 06:00:17] System starts up because power supply is newly connected.
[2025-06-04 06:02:22] Applying network time to system...
  Done :-)
[2025-06-04 06:02:25] Done :-)
[2025-06-04 06:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 06:02:25> Done :-)
[2025-06-04 06:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 06:02:25] Pending for incoming shutdown command...
[2025-06-04 06:02:25] Schedule next shutdown at: 2025-06-04 06:10:00
[2025-06-04 06:02:25] Schedule next startup at: 2025-06-04 08:00:00
[2025-06-04 06:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 06:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 08:00:17] Done :-)
[2025-06-04 08:00:17] Firmware ID: 0x37
[2025-06-04 08:00:17] Firmware Revison: 0x07
[2025-06-04 08:00:17] Current Vin=4.49V, Vout=5.19V, Iout=0.62A
[2025-06-04 08:00:17] System starts up because power supply is newly connected.
[2025-06-04 08:02:22] Applying network time to system...
  Done :-)
[2025-06-04 08:02:24] Done :-)
[2025-06-04 08:02:24] Writing system time to RTC...
  Done :-)
<2025-06-04 08:02:24> Done :-)
[2025-06-04 08:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 08:02:24] Pending for incoming shutdown command...
[2025-06-04 08:02:24] Schedule next shutdown at: 2025-06-04 08:10:00
[2025-06-04 08:02:24] Schedule next startup at: 2025-06-04 10:00:00
[2025-06-04 08:10:00] Shutting down system because scheduled shutdown is due.
[2025-06-04 08:10:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 10:00:17] Done :-)
[2025-06-04 10:00:17] Firmware ID: 0x37
[2025-06-04 10:00:17] Firmware Revison: 0x07
[2025-06-04 10:00:17] Current Vout=5.21V, Iout=0.23A
[2025-06-04 10:00:17] System starts up because power supply is newly connected.
[2025-06-04 10:02:22] Applying network time to system...
  Done :-)
[2025-06-04 10:02:25] Done :-)
[2025-06-04 10:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 10:02:25> Done :-)
[2025-06-04 10:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 10:02:25] Pending for incoming shutdown command...
[2025-06-04 10:02:25] Schedule next shutdown at: 2025-06-04 10:10:00
[2025-06-04 10:02:25] Schedule next startup at: 2025-06-04 12:00:00
[2025-06-04 10:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 10:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 12:00:18] Done :-)
[2025-06-04 12:00:18] Firmware ID: 0x37
[2025-06-04 12:00:18] Firmware Revison: 0x07
[2025-06-04 12:00:18] Current Vin=4.24V, Vout=5.13V, Iout=0.45A
[2025-06-04 12:00:18] System starts up because power supply is newly connected.
[2025-06-04 12:02:24] Applying network time to system...
  Done :-)
[2025-06-04 12:02:25] Done :-)
[2025-06-04 12:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 12:02:25> Done :-)
[2025-06-04 12:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 12:02:25] Pending for incoming shutdown command...
[2025-06-04 12:02:25] Schedule next shutdown at: 2025-06-04 12:10:00
[2025-06-04 12:02:25] Schedule next startup at: 2025-06-04 14:00:00
[2025-06-04 12:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 12:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 14:00:17] Done :-)
[2025-06-04 14:00:17] Firmware ID: 0x37
[2025-06-04 14:00:17] Firmware Revison: 0x07
[2025-06-04 14:00:17] Current Vout=5.2V, Iout=0.34A
[2025-06-04 14:00:17] System starts up because power supply is newly connected.
[2025-06-04 14:02:23] Applying network time to system...
  Done :-)
[2025-06-04 14:02:25] Done :-)
[2025-06-04 14:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 14:02:25> Done :-)
[2025-06-04 14:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 14:02:25] Pending for incoming shutdown command...
[2025-06-04 14:02:25] Schedule next shutdown at: 2025-06-04 14:10:00
[2025-06-04 14:02:25] Schedule next startup at: 2025-06-04 16:00:00
[2025-06-04 14:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 14:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 16:00:17] Done :-)
[2025-06-04 16:00:17] Firmware ID: 0x37
[2025-06-04 16:00:17] Firmware Revison: 0x07
[2025-06-04 16:00:17] Current Vin=4.36V, Vout=5.13V, Iout=0.49A
[2025-06-04 16:00:17] System starts up because power supply is newly connected.
[2025-06-04 16:02:23] Applying network time to system...
  Done :-)
[2025-06-04 16:02:25] Done :-)
[2025-06-04 16:02:25] Writing system time to RTC...
  Done :-)
<2025-06-04 16:02:25> Done :-)
[2025-06-04 16:02:25] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 16:02:25] Pending for incoming shutdown command...
[2025-06-04 16:02:25] Schedule next shutdown at: 2025-06-04 16:10:00
[2025-06-04 16:02:25] Schedule next startup at: 2025-06-04 18:00:00
[2025-06-04 16:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 16:09:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 18:00:17] Done :-)
[2025-06-04 18:00:17] Firmware ID: 0x37
[2025-06-04 18:00:17] Firmware Revison: 0x07
[2025-06-04 18:00:17] Current Vin=4.36V, Vout=5.26V, Iout=0.36A
[2025-06-04 18:00:17] System starts up because power supply is newly connected.
[2025-06-04 18:02:23] Applying network time to system...
  Done :-)
[2025-06-04 18:02:24] Done :-)
[2025-06-04 18:02:24] Writing system time to RTC...
  Done :-)
<2025-06-04 18:02:24> Done :-)
[2025-06-04 18:02:24] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 18:02:24] Pending for incoming shutdown command...
[2025-06-04 18:02:24] Schedule next shutdown at: 2025-06-04 18:10:00
[2025-06-04 18:02:24] Schedule next startup at: 2025-06-04 20:00:00
[2025-06-04 18:09:59] Shutting down system because scheduled shutdown is due.
[2025-06-04 18:09:59] Halting all processes and then shutdown Raspberry Pi...
[xxxx-xx-xx xx:xx:xx] RTC offset register has value 0x79
[xxxx-xx-xx xx:xx:xx] RTC has bad time, write system time into RTC
[xxxx-xx-xx xx:xx:xx] Writing system time to RTC...
<2025-06-04 18:10:31> Done :-)
<2025-06-04 18:10:31> Firmware ID: 0x37
<2025-06-04 18:10:31> Firmware Revison: 0x07
<2025-06-04 18:10:31> Current Vout=5.21V, Iout=0.23A
<2025-06-04 18:10:32> System starts up because USB 5V is connected.
[2025-06-04 18:12:38] Applying network time to system...
  Done :-)
[2025-06-04 21:06:10] Done :-)
[2025-06-04 21:06:10] Writing system time to RTC...
  Done :-)
<2025-06-04 21:06:10> Done :-)
<2025-06-04 21:06:10> Send out the SYS_UP signal via GPIO-17 pin.
<2025-06-04 21:06:10> Pending for incoming shutdown command...
[2025-06-04 21:06:10] Schedule next shutdown at: 2025-06-04 22:10:00
[2025-06-04 21:06:10] Schedule next startup at: 2025-06-05 00:00:00
[2025-06-04 21:12:21] Copying "on_5m_every_20m.wpi" to "schedule.wpi"...
[2025-06-04 21:12:21] Running the script...
[2025-06-04 21:12:21] Schedule next shutdown at: 2025-06-04 21:25:00
[2025-06-04 21:12:22] Schedule next startup at: 2025-06-04 21:40:00
[2025-06-04 21:12:22] Done :-)
<2025-06-04 21:25:00> Shutting down system because scheduled shutdown is due.
<2025-06-04 21:25:00> Halting all processes and then shutdown Raspberry Pi...
[2025-06-04 23:47:20] Done :-)
[2025-06-04 23:47:20] Firmware ID: 0x37
[2025-06-04 23:47:20] Firmware Revison: 0x07
[2025-06-04 23:47:20] Current Vout=5.2V, Iout=0.55A
[2025-06-04 23:47:20] System starts up because the button is clicked.
[2025-06-04 23:48:13] Internet detected, apply network time to system and Witty Pi...
[2025-06-04 23:48:13] Applying network time to system...
[2025-06-04 23:48:15] Done :-)
[2025-06-04 23:48:15] Writing system time to RTC...
<2025-06-04 23:48:15> Done :-)
<2025-06-04 23:48:43> Copying "on_5m_every_20m.wpi" to "schedule.wpi"...
<2025-06-04 23:48:44> Running the script...
<2025-06-04 23:48:44> Schedule next shutdown at: 2025-06-05 00:05:00
<2025-06-04 23:48:44> Schedule next startup at: 2025-06-05 00:20:00
<2025-06-04 23:48:45> Done :-)
[2025-06-04 23:49:27] Applying network time to system...
  Done :-)
[2025-06-04 23:49:28] Done :-)
[2025-06-04 23:49:28] Writing system time to RTC...
  Done :-)
<2025-06-04 23:49:28> Done :-)
[2025-06-04 23:49:28] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-04 23:49:28] Pending for incoming shutdown command...
[2025-06-04 23:49:28] Schedule next shutdown at: 2025-06-05 00:05:00
[2025-06-04 23:49:28] Schedule next startup at: 2025-06-05 00:20:00
[2025-06-05 00:05:00] Shutting down system because scheduled shutdown is due.
[2025-06-05 00:05:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-05 17:35:36] Done :-)
[2025-06-05 17:35:36] Firmware ID: 0x37
[2025-06-05 17:35:36] Firmware Revison: 0x07
[2025-06-05 17:35:36] Current Vout=5.2V, Iout=0.45A
[2025-06-05 17:35:36] System starts up because the button is clicked.
[2025-06-05 17:37:41] Applying network time to system...
  Done :-)
[2025-06-05 17:37:44] Done :-)
[2025-06-05 17:37:44] Writing system time to RTC...
  Done :-)
<2025-06-05 17:37:44> Done :-)
[2025-06-05 17:37:44] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-05 17:37:44] Pending for incoming shutdown command...
[2025-06-05 17:37:44] Schedule next shutdown at: 2025-06-05 17:45:00
[2025-06-05 17:37:44] Schedule next startup at: 2025-06-05 18:00:00
[2025-06-05 17:44:59] Shutting down system because scheduled shutdown is due.
[2025-06-05 17:44:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-06 20:49:47] Done :-)
[2025-06-06 20:49:47] Firmware ID: 0x37
[2025-06-06 20:49:47] Firmware Revison: 0x07
[2025-06-06 20:49:47] Current Vin=4.18V, Vout=5.19V, Iout=0.55A
[2025-06-06 20:49:47] System starts up because the button is clicked.
[2025-06-06 20:51:53] Applying network time to system...
  Done :-)
[2025-06-06 20:51:54] Done :-)
[2025-06-06 20:51:54] Writing system time to RTC...
  Done :-)
<2025-06-06 20:51:54> Done :-)
[2025-06-06 20:51:54] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-06 20:51:54] Pending for incoming shutdown command...
[2025-06-06 20:51:54] Schedule next shutdown at: 2025-06-06 21:05:00
[2025-06-06 20:51:54] Schedule next startup at: 2025-06-06 21:20:00
[2025-06-06 21:05:00] Shutting down system because scheduled shutdown is due.
[2025-06-06 21:05:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-10 17:26:01] Done :-)
[2025-06-10 17:26:01] Firmware ID: 0x37
[2025-06-10 17:26:01] Firmware Revison: 0x07
[2025-06-10 17:26:01] Current Vin=4.36V, Vout=5.19V, Iout=0.55A
[2025-06-10 17:26:01] System starts up because USB 5V is connected.
[2025-06-10 17:28:07] Applying network time to system...
  Done :-)
[2025-06-10 17:32:27] Done :-)
[2025-06-10 17:32:27] Writing system time to RTC...
  Done :-)
<2025-06-10 17:32:27> Done :-)
[2025-06-10 17:32:27] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-10 17:32:27] Pending for incoming shutdown command...
[2025-06-10 17:32:27] Schedule next shutdown at: 2025-06-10 17:45:00
[2025-06-10 17:32:27] Schedule next startup at: 2025-06-10 18:00:00
[2025-06-10 17:44:59] Shutting down system because scheduled shutdown is due.
[2025-06-10 17:44:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-10 18:34:53] Done :-)
[2025-06-10 18:34:53] Firmware ID: 0x37
[2025-06-10 18:34:53] Firmware Revison: 0x07
[2025-06-10 18:34:53] Current Vout=5.19V, Iout=0.3A
[2025-06-10 18:34:53] System starts up because the button is clicked.
[2025-06-10 18:36:58] Applying network time to system...
  Done :-)
[2025-06-10 18:37:00] Done :-)
[2025-06-10 18:37:00] Writing system time to RTC...
  Done :-)
<2025-06-10 18:37:00> Done :-)
[2025-06-10 18:37:00] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-10 18:37:00] Pending for incoming shutdown command...
[2025-06-10 18:37:00] Schedule next shutdown at: 2025-06-10 18:45:00
[2025-06-10 18:37:00] Schedule next startup at: 2025-06-10 19:00:00
[2025-06-10 18:44:59] Shutting down system because scheduled shutdown is due.
[2025-06-10 18:44:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-10 19:11:40] Done :-)
[2025-06-10 19:11:40] Firmware ID: 0x37
[2025-06-10 19:11:40] Firmware Revison: 0x07
[2025-06-10 19:11:40] Current Vout=5.21V, Iout=0.17A
[2025-06-10 19:11:40] System starts up because the button is clicked.
[2025-06-10 19:13:46] Applying network time to system...
  Done :-)
[2025-06-10 19:13:48] Done :-)
[2025-06-10 19:13:48] Writing system time to RTC...
  Done :-)
<2025-06-10 19:13:48> Done :-)
[2025-06-10 19:13:48] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-10 19:13:48] Pending for incoming shutdown command...
[2025-06-10 19:13:48] Schedule next shutdown at: 2025-06-10 19:25:00
[2025-06-10 19:13:48] Schedule next startup at: 2025-06-10 19:40:00
[2025-06-10 19:24:59] Shutting down system because scheduled shutdown is due.
[2025-06-10 19:24:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-10 19:41:45] Done :-)
[2025-06-10 19:41:45] Firmware ID: 0x37
[2025-06-10 19:41:45] Firmware Revison: 0x07
[2025-06-10 19:41:45] Current Vout=5.19V, Iout=0.51A
[2025-06-10 19:41:45] System starts up because the button is clicked.
[2025-06-10 19:43:52] Applying network time to system...
  Done :-)
[2025-06-10 19:43:54] Done :-)
[2025-06-10 19:43:54] Writing system time to RTC...
  Done :-)
<2025-06-10 19:43:54> Done :-)
[2025-06-10 19:43:54] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-10 19:43:54] Pending for incoming shutdown command...
[2025-06-10 19:43:54] Schedule next shutdown at: 2025-06-10 19:45:00
[2025-06-10 19:43:54] Schedule next startup at: 2025-06-10 20:00:00
[2025-06-10 19:45:00] Shutting down system because scheduled shutdown is due.
[2025-06-10 19:45:01] Halting all processes and then shutdown Raspberry Pi...
[2025-06-11 16:53:47] Done :-)
[2025-06-11 16:53:47] Firmware ID: 0x37
[2025-06-11 16:53:47] Firmware Revison: 0x07
[2025-06-11 16:53:47] Current Vout=5.19V, Iout=0.6A
[2025-06-11 16:53:47] System starts up because the button is clicked.
[2025-06-11 16:55:52] Applying network time to system...
  Done :-)
[2025-06-11 16:55:57] Done :-)
[2025-06-11 16:55:57] Writing system time to RTC...
  Done :-)
<2025-06-11 16:55:57> Done :-)
[2025-06-11 16:55:57] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-11 16:55:57] Pending for incoming shutdown command...
[2025-06-11 16:55:57] Schedule next shutdown at: 2025-06-11 17:05:00
[2025-06-11 16:55:57] Schedule next startup at: 2025-06-11 17:20:00
[2025-06-11 17:04:59] Shutting down system because scheduled shutdown is due.
[2025-06-11 17:04:59] Halting all processes and then shutdown Raspberry Pi...
[2025-06-11 17:22:24] Done :-)
[2025-06-11 17:22:24] Firmware ID: 0x37
[2025-06-11 17:22:24] Firmware Revison: 0x07
[2025-06-11 17:22:24] Current Vout=5.19V, Iout=0.38A
[2025-06-11 17:22:24] System starts up because the button is clicked.
[2025-06-11 17:24:29] Applying network time to system...
  Done :-)
[2025-06-11 17:24:31] Done :-)
[2025-06-11 17:24:31] Writing system time to RTC...
  Done :-)
<2025-06-11 17:24:31> Done :-)
[2025-06-11 17:24:31] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-11 17:24:31] Pending for incoming shutdown command...
[2025-06-11 17:24:31] Schedule next shutdown at: 2025-06-11 17:25:00
[2025-06-11 17:24:31] Schedule next startup at: 2025-06-11 17:40:00
[2025-06-11 17:25:00] Shutting down system because scheduled shutdown is due.
[2025-06-11 17:25:00] Halting all processes and then shutdown Raspberry Pi...
[2025-06-11 17:25:52] Done :-)
[2025-06-11 17:25:52] Firmware ID: 0x37
[2025-06-11 17:25:52] Firmware Revison: 0x07
[2025-06-11 17:25:52] Current Vout=5.2V, Iout=0.47A
[2025-06-11 17:25:52] System starts up because the button is clicked.
[2025-06-11 17:27:57] Applying network time to system...
  Done :-)
[2025-06-11 17:28:00] Done :-)
[2025-06-11 17:28:00] Writing system time to RTC...
  Done :-)
<2025-06-11 17:28:00> Done :-)
[2025-06-11 17:28:00] Send out the SYS_UP signal via GPIO-17 pin.
[2025-06-11 17:28:00] Schedule script is interrupted, revising the schedule...
[2025-06-11 17:28:00] Pending for incoming shutdown command...
[2025-06-11 17:28:00] Schedule next shutdown at: 2025-06-11 17:39:00
[2025-06-11 17:28:00] Schedule next startup at: 2025-06-11 17:40:00
This topic was modified 10 months ago by Konstantinos Belivanis
Posted : 11/06/2025 4:41 pm
In your log, every time it wakes up as scheduled, it will show
How could this happen? Isn't your 5V power supply always connected?
Posted : 12/06/2025 11:41 am
(@konstantinos-belivanis)
Very good point. USB-C is always connected.
Posted : 12/06/2025 11:47 am
@konstantinos-belivanis Don't you think this is a sign that the voltage on your USB-C might be missing/disconnected for some reason?
Posted : 12/06/2025 3:47 pm
The solution that (for the moment) is working is that I changed the "Default State when Powered" to ON.
Posted : 12/06/2025 5:44 pm
Posted by: @konstantinos-belivanis
This also matches my guess: your 5V power supply appears to be in "sleep" mode and has a load detection mechanism. When the scheduled startup is due, your power supply does not output 5V to the Witty Pi. The Witty Pi's firmware emulates a button click (by pulling down the GPIO-4), which applies load to your power supply and activates it (output 5V). Because you set the default status to ON, the device can be turned on and then print "System starts up because power supply is newly connected" in the log.
If for any reason the load detection failes to activate the power supply, the device will not start up.
Posted : 13/06/2025 8:25 am
