[Mark Solved / Archieved] Witty Pi 4 L3V7 Disabling White LED does not work?
I have done these things:
./wittyPi.sh
Option [11] (other settings...)
Option [4] (White LED duration
set value to zero.
nothing happened.
rebooted
Still nothing changed.
I then run this:
i2cset -y 1 0x08 39 0
nothing happened.
i did this:
sudo nano /etc/rc.local
rebooted
I finally checked with this:
i2cget -y 1 0x08 39
which returned:
0x00
So now well and truly stumped 🙂
This topic was modified 7 months ago 2 times by andrew.simpson17
Posted : 17/04/2026 12:46 pm
On the user manual, it is said that:
"White LED duration This parameter will decide how long the white LED should stay on, when Witty Pi blinks it during the sleep. "
So it only affects the blinking during the sleep state. It doesn't make sure the white LED will never get lighted up. If you don't want to see the white LED to light up, you will need to either modify the firmware, or you physically remove the white LED.
By the way, the I2C register with index 39 is not the correct one, the one you wanted to use has index 20 instead.
Posted : 17/04/2026 2:01 pm
thanks for quick reply.
In a way I am glad I got this question completely wrong as i had asked an AI engine. Which means I am not going to be replaced just yet.
this light was triggering my radar sensor you see. I have now covered the LED up.
I do not think anyone here will benefit from this question so feel free to delete it. I will not be offended.
Cheers.
Posted : 17/04/2026 5:00 pm
