[Mark Solved / Archieved] Witty Pi 4 Mini P3 unpopulated pins not functioning
(@pi_in_the_sky)
Hi Guys,
The story is that I have installed a button (2 legs) to the 2 pins (GND and Switch) on the P3 solder pads.
The problem is that it does turn the witty pi off when I press the button (the pi was on), but it wont turn on when I press the button (the pi was off).
I have waited for the system to fully turn off (like 5 mins) then only then I press the button one time to turn it on but it just wont do anything.
Sometimes it does turn on after I press the button 5 times in the row ( on -> off -> on -> off -> on).
I tried to measure the voltage between Switch and GND. When the button is pressed, it is 0v between switch and GND. When not pressed, it is 3.3v
P/s: The cable to the button is short (5cm), the solder join are secured and there is no bridging between 2 pins. I pressed and released the button as quickly as I can. The button is a push button, press then it stay in pressed states and vice versa.
I am suspecting that I may use the wrong button
Posted : 28/04/2026 3:18 am
How do you power your device? What kind of power source is used?
Posted : 28/04/2026 6:23 am
(@arjenr)
Trusted Member Customer
The button is supposed to be a “normally off” momentary push button, IMO.
When I first installed a button on one of my witty pi 4 L3V7’s, I happened to pick a “normally connected” momentary button from my collection of push buttons not realising it was the wrong type. It took quite some time before I found out what was wrong. The button was nice and small, and not as easy to accidentally push when handling the case as the correct type I replaced it with, but of course it didn’t work as intended.
Posted : 28/04/2026 6:48 am
@arjenr according to what he/she said:
Posted by: @pi_in_the_sky
Seems the correct button type is used. I am thinking maybe the power source was cut, which has rather big chance if it is a powerbank.
Posted : 28/04/2026 7:08 am
(@arjenr)
It struck me most that the OP described it as a locking button instead of a momentary one. Not quite the right type, at least not the most suitable type, but in a pinch it could probably work. Some locking pushbuttons have very little to no visible feedback as to which position they are in at any time, which would be a problem.
Posted : 28/04/2026 9:17 am
(@pi_in_the_sky)
@admin I used a 12V battery connected via a buck converter, it is quite stable
Posted : 29/04/2026 2:05 am
(@pi_in_the_sky)
@arjenr Thank you! It is now solved, I changed to a N/O momentary button and it worked! seems like the locking mechanism on the button is the cause of the issue.
Thanks @admin
Posted : 29/04/2026 2:06 am
